Hi all,
I can’t get the Volumio UI to show on the official Raspberry Pi 7" touchscreen (v1.1) connected via DSI to a Raspberry Pi 4. The display works, but it only shows the Linux console/TTY.
Setup:
Raspberry Pi 4 Model B
Display: official Raspberry Pi 7" DSI touchscreen (v1.1), connected to DSI0
Volumio: 4.084-2025-12-25-pi
The screen shows only the console/TTY (looks like “Raspbian terminal”).
I ran the Pi Screen Setup tool in the Plugin options multiple times and tried all available settings/options, but it made no difference (still only console on the screen).
Hallo Sebastian,
konntest du dein Problem lösen? Wenn nicht: Hast du mal andere SD-Karten ausprobiert? Wie hast du das Volumio-Image auf die SD-Karte gebracht? Je nachdem welches Tool man benutzt kann das auch Probleme machen. Sitzt die SD-Karte fest im Slot?
Please post in English if you need support. There are many tools available to translate your message into English. Do not expect others to translate your post for you.
Hello Sebastian,
Were you able to resolve your issue? If not, have you tried other SD cards? How did you transfer the Volumio image to the SD card? Depending on which tool you use, this can also cause problems. Is the SD card firmly seated in the slot?
