[aid] network, outgoing to: http://192.168.1.73:1400/xml/device_description.xml
stack: at Agent.createSocket (_http_agent.js:323:26)
at Agent.addRequest (_http_agent.js:274:10)
at new ClientRequest (_http_client.js:306:16)
at Object.request (http.js:50:10)
at Request.start (/volumio/node_modules/request/request.js:751:32)
at Request.end (/volumio/node_modules/request/request.js:1505:10)
at end (/volumio/node_modules/request/request.js:564:14)
at Immediate._onImmediate (/volumio/node_modules/request/request.js:578:7)
at processImmediate (internal/timers.js:461:21)
[aid] network, outgoing to: http://192.168.1.71:1400/xml/device_description.xml
[aid] network, outgoing to: http://192.168.1.72:1400/xml/device_description.xml
[aid] network, outgoing to: http://192.168.1.70:1400/xml/device_description.xml
[aid] network, outgoing to: http://192.168.1.89:80/description.xml
info: CoreCommandRouter::executeOnPlugin: mpd , getMyCollectionStats
error: MPD error: The expression evaluated to a falsy value:
assert.ok(self.idling)
[aid] network, outgoing to: undefined//undefined:undefinedundefined
stack: at Function.MpdClient.connect (/volumio/app/plugins/music_service/mpd/lib/mpd.js:38:23)
at ControllerMpd.mpdConnect (/volumio/app/plugins/music_service/mpd/index.js:762:27)
at ControllerMpd.mpdEstablish (/volumio/app/plugins/music_service/mpd/index.js:668:8)
at Timeout._onTimeout (/volumio/app/plugins/music_service/mpd/index.js:687:14)
at listOnTimeout (internal/timers.js:554:17)
at processTimers (internal/timers.js:497:7)
[aid] network, outgoing to: https://ubesolwbwzdytipsq85sbr4lrax1-ee73f489126ef9e0bd0fb1fb1d6ea476.as1.myvolumio.org/api/v1/ping
stack: at Agent.createConnection (https.js:129:22)
at Object.request (https.js:313:10)
info: [MyVolumio PluginManager] Device activated, enabling myvolumio plugins...
info: MyVolumio status changed
info: Streaming services startup
info: Re-Starting Streaming Daemon
[aid] network, outgoing to: http://127.0.0.1:7777/restart
info: CoreCommandRouter::executeOnPlugin: my_volumio , getHwuuid
info: [MyVolumio PluginManager] Loading plugin "bluetooth"...
info: [1641654430583] Starting BluetoothController
info: [MyVolumio PluginManager] Loading plugin "multiroom"...
info: [MyVolumio PluginManager] Applying required configuration parameters for plugin multiroom
info: MultiRoom plugin initialized
STOPPING SNAPCLIENT
info: [MyVolumio PluginManager] Loading plugin "metavolumio"...
info: [MyVolumio PluginManager] Loading plugin "cd_controller"...
info: [MyVolumio PluginManager] Loading plugin "smart_inputs"...
info: [MyVolumio PluginManager] Loading plugin "hi_res_audio"...
info: [MyVolumio PluginManager] Applying required configuration parameters for plugin hi_res_audio
info: [MyVolumio PluginManager] Loading plugin "tidal"...
info: [MyVolumio PluginManager] Loading plugin "qobuz"...
info: [MyVolumio PluginManager] Loading plugin "tidalconnect"...
info: Preparing to generate the ALSA configuration file
[aid] network, outgoing to: http://0.0.0.0:1901/index.html
at request (http.js:50:10)
at Object.get (http.js:54:15)
at SsdpClient.<anonymous> (/myvolumio/plugins/audio_interface/multiroom/node_modules/chromecast-api/lib/client.js:120:12)
at SsdpClient.emit (events.js:315:20)
at SsdpClient.parseResponse [as _parseResponse] (/myvolumio/plugins/audio_interface/multiroom/node_modules/node-ssdp/lib/index.js:457:8)
at SsdpClient.SSDP._parseMessage (/myvolumio/plugins/audio_interface/multiroom/node_modules/node-ssdp/lib/index.js:298:10)
at Socket.onSocketMessage (/myvolumio/plugins/audio_interface/multiroom/node_modules/node-ssdp/lib/index.js:244:12)
at Socket.emit (events.js:315:20)
at UDP.onMessage [as onmessage] (dgram.js:919:8)
[aid] network, outgoing to: http://192.168.1.55:7678/nservice/
info: MRS: SNAPCLIENT STOPPED
info: Snap server and client installed
|||||||||||||||||||||||| WARNING: FATAL ERROR |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Error: connect ECONNREFUSED 0.0.0.0:1901
at TCPConnectWrap.afterConnect [as oncomplete] (net.js:1146:16) {
errno: -111,
code: 'ECONNREFUSED',
syscall: 'connect',
address: '0.0.0.0',
port: 1901
Please have a look. A lot of MPD errors,
Having moved the same 2 * Pi4B Volumio hosts that are failing above over to a separate / isolated network with only one other (IOS) device to manage and control, I can confirm that the Piās do in fact activate and are able to stream seemingly as normal ⦠when isolated !
The indication is therefore that something on the home network is affecting Volumio v3 operation on a Pi.
But what ? Back to basics and turn everything off and then back on again until I find the culprit ?
If you find the source to the problem, please repost.
I have found a workaround. Since some said the problems come from the network, I started a firewall to allow only the most important accesses to the Volumio PI.
I installed a fresh Volumio 3 PI and configurated everything, but not logged into the premium account.
With the following commands the firewall is started:
sudo /sbin/iptables -A INPUT -i lo -j ACCEPT
sudo /sbin/iptables -A INPUT -p tcp --dport 22 -j ACCEPT
sudo /sbin/iptables -A INPUT -p tcp --dport 80 -j ACCEPT
sudo /sbin/iptables -A INPUT -p tcp --dport 3000 -j ACCEPT
sudo /sbin/iptables -A INPUT -p udp --sport 53 -j ACCEPT
sudo /sbin/iptables -A INPUT -p udp --dport 53 -j ACCEPT
sudo /sbin/iptables -A INPUT -m state --state RELATED,ESTABLISHED -j ACCEPT
sudo /sbin/iptables -A INPUT -j DROP
after that, i logged into the account.
about 1-2 minutes later i stopped the firewall
sudo /sbin/iptables -F
everything still works as expected.
maybe this will help to narrow down the causes further?
for the experienced networkers among you, maybe someone who knows the protocols used by Volumio 3, here is another variant that allows to log and evaluate the blocked packets: (the bold line)
sudo /sbin/iptables -A INPUT -j LOG --log-prefix "iptables dropped INPUT "
now watch the log of dropped packets:
sudo journalctl -f | grep iptables
Hi
I tested this and for me itĀ“s stable too , but I could not activate any premium sources like Tidal, so it appears to me that it doesnāt activate the plugins. I havenāt looked in to it further due to the fā¦king covid. Thanks for the tip it maybe helps to find the source.
/Mikael
Volumio 3 activated Pi + Ikea Tradfri gateway on same network = constant āconfiguration updatesā
At least thatās the case on my own network.
Whenever I restart a Volumio 3 activated Pi with the Tradfri already running, Volumio becomes basically useless.
Powering up Tradfri only AFTER the Piās are up and running does not seem to affect Volumio operations. Will observe whether this remains the case over a longer period.
Thanks it working, It was IKEA gateway, I had never problem with Volumio 2 so I“ll hope they can find a fix. Very nice to be able to evaluate Volumio 3.
Good news gentlemen, we might have been able to track down the issue (and hopefully fix it).
The issue is due to devices on the network which advertise specific services and then cannot receive connections from other devices.
Those devices triggered a bug in a library we use.
Hopefully this is fixed now. We will release a new build shortly.
Thanks so far for your patience
Good News indeed
Tried the Beta, works perfect
Where / how can I get the latest beta version that resolves this problem ?
By putting your device into test mode and update.
Now a big BUT: test mode is not recommended for all users, better wait for the released version.
With test mode you risk updating to unreleased versions which could potentially break your system. Only do this when asked by devs to verify fixes.
What version was this issue resolved in? Iām currently having this issue on a Pi 3+ and a Wyze 3040. I was excited to see a fix was coming soon until I realized this thread is a year old.
Others seem not to have this issueā¦
Just upgrade to the latest version V3.396
