What do you mean with the keyboard?
There is no keyboard connected.
I test the Raspberry from a PC via LAN.
Changing configurations I do via ssh within Powershell.
Because I have activated the Plugin for Touch Display I seen in parallel the HMI via Raspberry HDMI.
The Xorg log shows a Logitech K400 Plus:
If such a keyboard is not connected: Do you have any idea where these messages come from?
Ahh, sorry at that time I had the K400 connected for a short time.
Here I is the actual Xorg.
[ 44.996]
X.Org X Server 1.20.4
[ 44.998] Build Operating System: Linux 5.4.0-109-generic armv8l Raspbian
[ 44.998] Current Operating System: Linux myvolumio 5.10.92-v7+ #1514 SMP Mon Jan 17 17:36:39 GMT 2022 armv7l
[ 44.999] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 bcm2708_fb.fbwidth=1824 bcm2708_fb.fbheight=984 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 splash plymouth.ignore-serial-consoles dwc_otg.fiq_enable=1 dwc_otg.fiq_fsm_enable=1 dwc_otg.fiq_fsm_mask=0xF dwc_otg.nak_holdoff=1 quiet console=ttyS0,115200 console=tty1 imgpart=/dev/mmcblk0p2 imgfile=/volumio_current.sqsh rootwait bootdelay=5 elevator=noop logo.nologo vt.global_cursor_default=0 net.ifnames=0 snd-bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 loglevel=0
[ 45.001] Build Date: 04 August 2022 12:56:42PM
[ 45.001] xorg-server 2:1.20.4-1+rpt4+deb10u5 (https://www.debian.org/support)
[ 45.003] Current version of pixman: 0.36.0
[ 45.003] Before reporting problems, check http://wiki.x.org
[ 45.003] Markers: (--) probed, (**) from config file, (==) default setting,
[ 45.005] (==) Log file: "/var/log/Xorg.0.log", Time: Tue Sep 20 08:55:46 2022
[ 45.017] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 45.017] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 45.023] (==) No Layout section. Using the first Screen section.
[ 45.023] (==) No screen section available. Using defaults.
[ 45.023] (**) |-->Screen "Default Screen Section" (0)
[ 45.023] (**) | |-->Monitor "<default monitor>"
[ 45.030] (==) No monitor specified for screen "Default Screen Section".
[ 45.030] (==) Automatically adding devices
[ 45.030] (==) Automatically enabling devices
[ 45.030] (==) Automatically adding GPU devices
[ 45.030] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 45.031] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
[ 45.031] Entry deleted from font path.
[ 45.037] (==) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/Type1,
/usr/share/fonts/X11/100dpi,
/usr/share/fonts/X11/75dpi,
built-ins
[ 45.037] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 45.037] (II) The server relies on udev to provide the list of input devices.
[ 45.037] (II) Loader magic: 0x1fdf80
[ 45.037] (II) Module ABI versions:
[ 45.037] X.Org ANSI C Emulation: 0.4
[ 45.037] X.Org Video Driver: 24.0
[ 45.037] X.Org XInput driver : 24.1
[ 45.037] X.Org Server Extension : 10.0
[ 45.040] (--) using VT number 2
[ 45.040] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[ 45.041] (II) no primary bus or device found
[ 45.041] (II) LoadModule: "glx"
[ 45.044] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 45.110] (II) Module glx: vendor="X.Org Foundation"
[ 45.110] compiled for 1.20.4, module version = 1.0.0
[ 45.110] ABI class: X.Org Server Extension, version 10.0
[ 45.110] (==) Matched modesetting as autoconfigured driver 0
[ 45.110] (==) Matched fbdev as autoconfigured driver 1
[ 45.110] (==) Assigned the driver to the xf86ConfigLayout
[ 45.111] (II) LoadModule: "modesetting"
[ 45.118] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[ 45.124] (II) Module modesetting: vendor="X.Org Foundation"
[ 45.124] compiled for 1.20.4, module version = 1.20.4
[ 45.124] Module class: X.Org Video Driver
[ 45.124] ABI class: X.Org Video Driver, version 24.0
[ 45.124] (II) LoadModule: "fbdev"
[ 45.124] (II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so
[ 45.127] (II) Module fbdev: vendor="X.Org Foundation"
[ 45.127] compiled for 1.20.3, module version = 0.5.0
[ 45.127] Module class: X.Org Video Driver
[ 45.127] ABI class: X.Org Video Driver, version 24.0
[ 45.127] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 45.127] (II) FBDEV: driver for framebuffer: fbdev
[ 45.143] (WW) Falling back to old probe method for modesetting
[ 45.143] (EE) open /dev/dri/card0: No such file or directory
[ 45.143] (WW) Falling back to old probe method for fbdev
[ 45.143] (II) Loading sub module "fbdevhw"
[ 45.143] (II) LoadModule: "fbdevhw"
[ 45.143] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so
[ 45.147] (II) Module fbdevhw: vendor="X.Org Foundation"
[ 45.147] compiled for 1.20.4, module version = 0.0.2
[ 45.147] ABI class: X.Org Video Driver, version 24.0
[ 45.147] (II) FBDEV(0): using default device
[ 45.147] (WW) VGA arbiter: cannot open kernel arbiter, no multi-card support
[ 45.147] (II) FBDEV(0): Creating default Display subsection in Screen section
[ 45.147] (==) FBDEV(0): Depth 24, (==) framebuffer bpp 32
[ 45.147] (==) FBDEV(0): RGB weight 888
[ 45.147] (==) FBDEV(0): Default visual is TrueColor
[ 45.147] (==) FBDEV(0): Using gamma correction (1.0, 1.0, 1.0)
[ 45.147] (II) FBDEV(0): hardware: BCM2708 FB (video memory: 7011kB)
[ 45.147] (DB) xf86MergeOutputClassOptions unsupported bus type 0
[ 45.147] (II) FBDEV(0): checking modes against framebuffer device...
[ 45.147] (II) FBDEV(0): checking modes against monitor...
[ 45.147] (II) FBDEV(0): Virtual size is 1824x984 (pitch 1824)
[ 45.147] (**) FBDEV(0): Built-in mode "current"
[ 45.147] (==) FBDEV(0): DPI set to (96, 96)
[ 45.147] (II) Loading sub module "fb"
[ 45.147] (II) LoadModule: "fb"
[ 45.148] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 45.158] (II) Module fb: vendor="X.Org Foundation"
[ 45.158] compiled for 1.20.4, module version = 1.0.0
[ 45.159] ABI class: X.Org ANSI C Emulation, version 0.4
[ 45.159] (**) FBDEV(0): using shadow framebuffer
[ 45.159] (II) Loading sub module "shadow"
[ 45.159] (II) LoadModule: "shadow"
[ 45.159] (II) Loading /usr/lib/xorg/modules/libshadow.so
[ 45.162] (II) Module shadow: vendor="X.Org Foundation"
[ 45.162] compiled for 1.20.4, module version = 1.1.0
[ 45.162] ABI class: X.Org ANSI C Emulation, version 0.4
[ 45.163] (II) UnloadModule: "modesetting"
[ 45.163] (II) Unloading modesetting
[ 45.191] (==) FBDEV(0): Backing store enabled
[ 45.195] (==) FBDEV(0): DPMS enabled
[ 45.197] (II) Initializing extension Generic Event Extension
[ 45.198] (II) Initializing extension SHAPE
[ 45.199] (II) Initializing extension MIT-SHM
[ 45.199] (II) Initializing extension XInputExtension
[ 45.204] (II) Initializing extension XTEST
[ 45.205] (II) Initializing extension BIG-REQUESTS
[ 45.206] (II) Initializing extension SYNC
[ 45.207] (II) Initializing extension XKEYBOARD
[ 45.208] (II) Initializing extension XC-MISC
[ 45.209] (II) Initializing extension SECURITY
[ 45.210] (II) Initializing extension XFIXES
[ 45.212] (II) Initializing extension RENDER
[ 45.212] (II) Initializing extension RANDR
[ 45.214] (II) Initializing extension COMPOSITE
[ 45.216] (II) Initializing extension DAMAGE
[ 45.217] (II) Initializing extension MIT-SCREEN-SAVER
[ 45.218] (II) Initializing extension DOUBLE-BUFFER
[ 45.219] (II) Initializing extension RECORD
[ 45.220] (II) Initializing extension DPMS
[ 45.221] (II) Initializing extension Present
[ 45.222] (II) Initializing extension DRI3
[ 45.222] (II) Initializing extension X-Resource
[ 45.223] (II) Initializing extension XVideo
[ 45.224] (II) Initializing extension XVideo-MotionCompensation
[ 45.224] (II) Initializing extension SELinux
[ 45.224] (II) SELinux: Disabled on system
[ 45.224] (II) Initializing extension GLX
[ 45.225] (II) AIGLX: Screen 0 is not DRI2 capable
[ 46.648] (II) IGLX: Loaded and initialized swrast
[ 46.648] (II) GLX: Initialized DRISWRAST GL provider for screen 0
[ 46.648] (II) Initializing extension XFree86-VidModeExtension
[ 46.649] (II) Initializing extension XFree86-DGA
[ 46.650] (II) Initializing extension XFree86-DRI
[ 46.653] (II) Initializing extension DRI2
[ 46.965] (II) config/udev: Adding input device gpio_ir_recv (/dev/input/event1)
[ 46.965] (**) gpio_ir_recv: Applying InputClass "libinput keyboard catchall"
[ 46.965] (II) LoadModule: "libinput"
[ 46.966] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[ 47.016] (II) Module libinput: vendor="X.Org Foundation"
[ 47.016] compiled for 1.20.3, module version = 0.28.2
[ 47.016] Module class: X.Org XInput Driver
[ 47.016] ABI class: X.Org XInput driver, version 24.1
[ 47.016] (II) Using input driver 'libinput' for 'gpio_ir_recv'
[ 47.017] (**) gpio_ir_recv: always reports core events
[ 47.017] (**) Option "Device" "/dev/input/event1"
[ 47.017] (**) Option "_source" "server/udev"
[ 47.046] (II) event1 - gpio_ir_recv: is tagged by udev as: Keyboard Pointingstick
[ 47.047] (II) event1 - gpio_ir_recv: device is a pointer
[ 47.047] (II) event1 - gpio_ir_recv: device is a keyboard
[ 47.048] (II) event1 - gpio_ir_recv: device removed
[ 47.101] (II) libinput: gpio_ir_recv: needs a virtual subdevice
[ 47.101] (**) Option "config_info" "udev:/sys/devices/platform/ir-receiver@11/rc/rc0/input1/event1"
[ 47.101] (II) XINPUT: Adding extended input device "gpio_ir_recv" (type: MOUSE, id 6)
[ 47.101] (**) Option "AccelerationScheme" "none"
[ 47.101] (**) gpio_ir_recv: (accel) selected scheme none/0
[ 47.101] (**) gpio_ir_recv: (accel) acceleration factor: 2.000
[ 47.101] (**) gpio_ir_recv: (accel) acceleration threshold: 4
[ 47.105] (II) event1 - gpio_ir_recv: is tagged by udev as: Keyboard Pointingstick
[ 47.106] (II) event1 - gpio_ir_recv: device is a pointer
[ 47.106] (II) event1 - gpio_ir_recv: device is a keyboard
[ 47.125] (**) gpio_ir_recv: Applying InputClass "libinput keyboard catchall"
[ 47.125] (II) Using input driver 'libinput' for 'gpio_ir_recv'
[ 47.125] (**) gpio_ir_recv: always reports core events
[ 47.125] (**) Option "Device" "/dev/input/event1"
[ 47.125] (**) Option "_source" "_driver/libinput"
[ 47.125] (II) libinput: gpio_ir_recv: is a virtual subdevice
[ 47.125] (**) Option "config_info" "udev:/sys/devices/platform/ir-receiver@11/rc/rc0/input1/event1"
[ 47.125] (II) XINPUT: Adding extended input device "gpio_ir_recv" (type: KEYBOARD, id 7)
[ 47.125] (**) Option "xkb_model" "pc105"
[ 47.125] (**) Option "xkb_layout" "us"
[ 47.139] (II) config/udev: removing device gpio_ir_recv
[ 47.139] (II) UnloadModule: "libinput"
[ 47.140] (II) event1 - gpio_ir_recv: device removed
[ 47.181] (II) UnloadModule: "libinput"
[ 47.182] (II) config/udev: Adding input device gpio_ir_recv (/dev/input/event1)
[ 47.182] (**) gpio_ir_recv: Applying InputClass "libinput keyboard catchall"
[ 47.182] (II) Using input driver 'libinput' for 'gpio_ir_recv'
[ 47.182] (**) gpio_ir_recv: always reports core events
[ 47.182] (**) Option "Device" "/dev/input/event1"
[ 47.183] (**) Option "_source" "server/udev"
[ 47.190] (II) event1 - gpio_ir_recv: is tagged by udev as: Keyboard Pointingstick
[ 47.191] (II) event1 - gpio_ir_recv: device is a pointer
[ 47.191] (II) event1 - gpio_ir_recv: device is a keyboard
[ 47.192] (II) event1 - gpio_ir_recv: device removed
[ 47.250] (II) libinput: gpio_ir_recv: needs a virtual subdevice
[ 47.250] (**) Option "config_info" "udev:/sys/devices/platform/ir-receiver@11/rc/rc0/input1/event1"
[ 47.250] (II) XINPUT: Adding extended input device "gpio_ir_recv" (type: MOUSE, id 6)
[ 47.251] (**) Option "AccelerationScheme" "none"
[ 47.251] (**) gpio_ir_recv: (accel) selected scheme none/0
[ 47.251] (**) gpio_ir_recv: (accel) acceleration factor: 2.000
[ 47.251] (**) gpio_ir_recv: (accel) acceleration threshold: 4
[ 47.255] (II) event1 - gpio_ir_recv: is tagged by udev as: Keyboard Pointingstick
[ 47.256] (II) event1 - gpio_ir_recv: device is a pointer
[ 47.256] (II) event1 - gpio_ir_recv: device is a keyboard
[ 47.257] (**) gpio_ir_recv: Applying InputClass "libinput keyboard catchall"
[ 47.257] (II) Using input driver 'libinput' for 'gpio_ir_recv'
[ 47.257] (**) gpio_ir_recv: always reports core events
[ 47.257] (**) Option "Device" "/dev/input/event1"
[ 47.257] (**) Option "_source" "_driver/libinput"
[ 47.257] (II) libinput: gpio_ir_recv: is a virtual subdevice
[ 47.257] (**) Option "config_info" "udev:/sys/devices/platform/ir-receiver@11/rc/rc0/input1/event1"
[ 47.257] (II) XINPUT: Adding extended input device "gpio_ir_recv" (type: KEYBOARD, id 7)
[ 47.257] (**) Option "xkb_model" "pc105"
[ 47.257] (**) Option "xkb_layout" "us"
[ 47.257] (WW) Option "xkb_variant" requires a string value
[ 47.257] (WW) Option "xkb_options" requires a string value
Please reboot, manually start ālircmd.serviceā and post the output of
sudo journalctl -f --no-tail | grep lirc
I did that, but the journalctl doesnāt come to an end.
After a while I interrupted it via Ctrl C.
This is what I got:
volumio@myvolumio:~$ systemctl restart lircmd.service
volumio@myvolumio:~$ sudo journalctl -f --no-tail | grep lirc
Sep 20 14:08:40 myvolumio systemd[1]: Listening on lircd.socket.
Sep 20 14:08:42 myvolumio lircmd[497]: lircd-0.10.1[497]: Notice: lircmd: Opening log, level: Notice
Sep 20 14:08:42 myvolumio lircd-0.10.1[497]: Notice: lircmd: Opening log, level: Notice
Sep 20 14:08:42 myvolumio kernel: input: lircmd as /devices/virtual/input/input0
Sep 20 14:08:42 myvolumio systemd[1]: Starting lircd(8) initialization helper tool...
Sep 20 14:08:46 myvolumio lircd-setup[565]: /usr/sbin/lircd-setup:37: DeprecationWarning: The SafeConfigParser class has been renamed to ConfigParser in Python 3.2. This alias will be removed in future versions. Use ConfigParser directly instead.
Sep 20 14:08:46 myvolumio lircd-setup[565]: parser = configparser.SafeConfigParser()
Sep 20 14:08:46 myvolumio systemd[1]: lircd-setup.service: Succeeded.
Sep 20 14:08:46 myvolumio systemd[1]: Started lircd(8) initialization helper tool.
Sep 20 14:08:46 myvolumio lircd-0.10.1[660]: Info: lircd: Opening log, level: Info
Sep 20 14:08:46 myvolumio lircd-0.10.1[660]: Notice: Version: lircd 0.10.1
Sep 20 14:08:46 myvolumio lircd-0.10.1[660]: Notice: System info: Linux myvolumio 5.10.92-v7+ #1514 SMP Mon Jan 17 17:36:39 GMT 2022 armv7l GNU/Linux
Sep 20 14:08:46 myvolumio lircd-0.10.1[660]: Info: Initial device: /dev/lirc0
Sep 20 14:08:46 myvolumio lircd-0.10.1[660]: Warning: Cannot access device: /dev/lirc0
Sep 20 14:08:46 myvolumio lircd-0.10.1[660]: Notice: Options: driver: default
Sep 20 14:08:46 myvolumio lircd[660]: lircd-0.10.1[660]: Info: lircd: Opening log, level: Info
Sep 20 14:08:46 myvolumio lircd[660]: lircd-0.10.1[660]: Notice: Using systemd fd
Sep 20 14:08:46 myvolumio lircd[660]: lircd-0.10.1[660]: Warning: Running as root
Sep 20 14:08:46 myvolumio lircd-0.10.1[660]: Notice: Options: output: /var/run/lirc/lircd
Sep 20 14:08:46 myvolumio lircd-0.10.1[660]: Notice: Options: nodaemon: 1
Sep 20 14:08:46 myvolumio lircd-0.10.1[660]: Notice: Options: plugindir: /usr/lib/arm-linux-gnueabihf/lirc/plugins
Sep 20 14:08:46 myvolumio lircd-0.10.1[660]: Notice: Options: logfile: syslog
Sep 20 14:08:46 myvolumio lircd-0.10.1[660]: Notice: Options: immediate-init: 0
Sep 20 14:08:46 myvolumio lircd-0.10.1[660]: Notice: Options: permission: 666
Sep 20 14:08:46 myvolumio lircd-0.10.1[660]: Notice: Options: driver-options:
Sep 20 14:08:46 myvolumio lircd-0.10.1[660]: Notice: Options: pidfile: /var/run/lirc/lircd.pid
Sep 20 14:08:46 myvolumio lircd-0.10.1[660]: Notice: Options: listen: 0
Sep 20 14:08:46 myvolumio lircd-0.10.1[660]: Notice: Options: connect: (null)
Sep 20 14:08:46 myvolumio lircd-0.10.1[660]: Notice: Options: userelease: 0
Sep 20 14:08:46 myvolumio lircd-0.10.1[660]: Notice: Options: effective_user: (null)
Sep 20 14:08:46 myvolumio lircd-0.10.1[660]: Notice: Options: release_suffix: _EVUP
Sep 20 14:08:46 myvolumio lircd-0.10.1[660]: Notice: Options: allow_simulate: 0
Sep 20 14:08:46 myvolumio lircd-0.10.1[660]: Notice: Options: repeat_max: 600
Sep 20 14:08:46 myvolumio lircd-0.10.1[660]: Notice: Options: configfile: /etc/lirc/lircd.conf
Sep 20 14:08:46 myvolumio lircd-0.10.1[660]: Notice: Options: dynamic_codes: (null)
Sep 20 14:08:46 myvolumio lircd-0.10.1[660]: Notice: Current driver: default
Sep 20 14:08:46 myvolumio lircd-0.10.1[660]: Notice: Driver API version: 3
Sep 20 14:08:46 myvolumio lircd[660]: lircd-0.10.1[660]: Info: Using remote: Apple_A1294.
Sep 20 14:08:46 myvolumio lircd-0.10.1[660]: Notice: Driver version: 0.10.0
Sep 20 14:08:46 myvolumio lircd[660]: lircd-0.10.1[660]: Notice: lircd(default) ready, using /var/run/lirc/lircd
Sep 20 14:08:46 myvolumio lircd[660]: lircd-0.10.1[660]: Notice: accepted new client on /var/run/lirc/lircd
Sep 20 14:08:46 myvolumio lircd[660]: lircd-0.10.1[660]: Info: Cannot configure the rc device for /dev/lirc0
Sep 20 14:08:46 myvolumio lircd[660]: lircd-0.10.1[660]: Error: could not get file information for /dev/lirc0
Sep 20 14:08:46 myvolumio lircd[660]: lircd-0.10.1[660]: default_init(): No such file or directory
Sep 20 14:08:46 myvolumio lircd[660]: lircd-0.10.1[660]: Warning: Failed to initialize hardware
Sep 20 14:08:46 myvolumio lircd-0.10.1[660]: Notice: Driver info: See file:///usr/share/doc/lirc/plugindocs/default.html
Sep 20 14:08:46 myvolumio lircd-0.10.1[660]: Notice: Using systemd fd
Sep 20 14:08:46 myvolumio lircd-0.10.1[660]: Warning: Running as root
Sep 20 14:08:46 myvolumio lircd-0.10.1[660]: Info: Using remote: Apple_A1294.
Sep 20 14:08:46 myvolumio lircd-0.10.1[660]: Notice: lircd(default) ready, using /var/run/lirc/lircd
Sep 20 14:08:46 myvolumio lircd-0.10.1[660]: Notice: accepted new client on /var/run/lirc/lircd
Sep 20 14:08:46 myvolumio lircd-0.10.1[660]: Info: Cannot configure the rc device for /dev/lirc0
Sep 20 14:08:46 myvolumio lircd-0.10.1[660]: Error: could not get file information for /dev/lirc0
Sep 20 14:08:46 myvolumio lircd-0.10.1[660]: default_init(): No such file or directory
Sep 20 14:08:46 myvolumio lircd-0.10.1[660]: Warning: Failed to initialize hardware
Sep 20 14:08:47 myvolumio lircd[660]: lircd-0.10.1[660]: Error: could not get file information for /dev/lirc0
Sep 20 14:08:47 myvolumio lircd[660]: lircd-0.10.1[660]: default_init(): No such file or directory
Sep 20 14:08:47 myvolumio lircd-0.10.1[660]: Error: could not get file information for /dev/lirc0
Sep 20 14:08:47 myvolumio lircd-0.10.1[660]: default_init(): No such file or directory
Sep 20 14:08:48 myvolumio lircd[660]: lircd-0.10.1[660]: Error: could not get file information for /dev/lirc0
Sep 20 14:08:48 myvolumio lircd[660]: lircd-0.10.1[660]: default_init(): No such file or directory
Sep 20 14:08:48 myvolumio lircd-0.10.1[660]: Error: could not get file information for /dev/lirc0
Sep 20 14:08:48 myvolumio lircd-0.10.1[660]: default_init(): No such file or directory
Sep 20 14:08:49 myvolumio lircd[660]: lircd-0.10.1[660]: Error: could not get file information for /dev/lirc0
Sep 20 14:08:49 myvolumio lircd[660]: lircd-0.10.1[660]: default_init(): No such file or directory
Sep 20 14:08:49 myvolumio lircd-0.10.1[660]: Error: could not get file information for /dev/lirc0
Sep 20 14:08:49 myvolumio lircd-0.10.1[660]: default_init(): No such file or directory
Sep 20 14:08:50 myvolumio lircd[660]: lircd-0.10.1[660]: Error: could not get file information for /dev/lirc0
Sep 20 14:08:50 myvolumio lircd[660]: lircd-0.10.1[660]: default_init(): No such file or directory
Sep 20 14:08:50 myvolumio lircd-0.10.1[660]: Error: could not get file information for /dev/lirc0
Sep 20 14:08:50 myvolumio lircd-0.10.1[660]: default_init(): No such file or directory
Sep 20 14:08:51 myvolumio lircd[660]: lircd-0.10.1[660]: Error: could not get file information for /dev/lirc0
Sep 20 14:08:51 myvolumio lircd[660]: lircd-0.10.1[660]: default_init(): No such file or directory
Sep 20 14:08:51 myvolumio lircd-0.10.1[660]: Error: could not get file information for /dev/lirc0
Sep 20 14:08:51 myvolumio lircd-0.10.1[660]: default_init(): No such file or directory
Sep 20 14:08:52 myvolumio lircd[660]: lircd-0.10.1[660]: Error: could not get file information for /dev/lirc0
Sep 20 14:08:52 myvolumio lircd[660]: lircd-0.10.1[660]: default_init(): No such file or directory
Sep 20 14:08:52 myvolumio lircd-0.10.1[660]: Error: could not get file information for /dev/lirc0
Sep 20 14:08:52 myvolumio lircd-0.10.1[660]: default_init(): No such file or directory
Sep 20 14:08:53 myvolumio lircd-0.10.1[660]: Error: could not get file information for /dev/lirc0
Sep 20 14:08:53 myvolumio lircd[660]: lircd-0.10.1[660]: Error: could not get file information for /dev/lirc0
Sep 20 14:08:53 myvolumio lircd[660]: lircd-0.10.1[660]: default_init(): No such file or directory
Sep 20 14:08:53 myvolumio lircd-0.10.1[660]: default_init(): No such file or directory
Sep 20 14:08:54 myvolumio lircd[660]: lircd-0.10.1[660]: Error: could not get file information for /dev/lirc0
Sep 20 14:08:54 myvolumio lircd[660]: lircd-0.10.1[660]: default_init(): No such file or directory
Sep 20 14:08:54 myvolumio lircd-0.10.1[660]: Error: could not get file information for /dev/lirc0
Sep 20 14:08:54 myvolumio lircd-0.10.1[660]: default_init(): No such file or directory
Sep 20 14:08:55 myvolumio lircd[660]: lircd-0.10.1[660]: Error: could not get file information for /dev/lirc0
Sep 20 14:08:55 myvolumio lircd[660]: lircd-0.10.1[660]: default_init(): No such file or directory
Sep 20 14:08:55 myvolumio lircd-0.10.1[660]: Error: could not get file information for /dev/lirc0
Sep 20 14:08:55 myvolumio lircd-0.10.1[660]: default_init(): No such file or directory
Sep 20 14:08:56 myvolumio lircd[660]: lircd-0.10.1[660]: Error: could not get file information for /dev/lirc0
Sep 20 14:08:56 myvolumio lircd[660]: lircd-0.10.1[660]: default_init(): No such file or directory
Sep 20 14:08:56 myvolumio lircd-0.10.1[660]: Error: could not get file information for /dev/lirc0
Sep 20 14:08:56 myvolumio lircd-0.10.1[660]: default_init(): No such file or directory
Sep 20 14:08:57 myvolumio lircd[660]: lircd-0.10.1[660]: Error: could not get file information for /dev/lirc0
Sep 20 14:08:57 myvolumio lircd[660]: lircd-0.10.1[660]: default_init(): No such file or directory
Sep 20 14:08:57 myvolumio lircd-0.10.1[660]: Error: could not get file information for /dev/lirc0
Sep 20 14:08:57 myvolumio lircd-0.10.1[660]: default_init(): No such file or directory
Sep 20 14:08:58 myvolumio lircd[660]: lircd-0.10.1[660]: Error: could not get file information for /dev/lirc0
Sep 20 14:08:58 myvolumio lircd[660]: lircd-0.10.1[660]: default_init(): No such file or directory
Sep 20 14:08:58 myvolumio lircd-0.10.1[660]: Error: could not get file information for /dev/lirc0
Sep 20 14:08:58 myvolumio lircd-0.10.1[660]: default_init(): No such file or directory
Sep 20 14:08:59 myvolumio lircd[660]: lircd-0.10.1[660]: Error: could not get file information for /dev/lirc0
Sep 20 14:08:59 myvolumio lircd[660]: lircd-0.10.1[660]: default_init(): No such file or directory
Sep 20 14:08:59 myvolumio lircd-0.10.1[660]: Error: could not get file information for /dev/lirc0
Sep 20 14:08:59 myvolumio lircd-0.10.1[660]: default_init(): No such file or directory
Sep 20 14:09:00 myvolumio lircd[660]: lircd-0.10.1[660]: Error: could not get file information for /dev/lirc0
Sep 20 14:09:00 myvolumio lircd[660]: lircd-0.10.1[660]: default_init(): No such file or directory
Sep 20 14:09:00 myvolumio lircd-0.10.1[660]: Error: could not get file information for /dev/lirc0
Sep 20 14:09:00 myvolumio lircd-0.10.1[660]: default_init(): No such file or directory
Sep 20 14:09:01 myvolumio lircd[660]: lircd-0.10.1[660]: Error: could not get file information for /dev/lirc0
Sep 20 14:09:01 myvolumio lircd[660]: lircd-0.10.1[660]: default_init(): No such file or directory
Sep 20 14:09:01 myvolumio lircd-0.10.1[660]: Error: could not get file information for /dev/lirc0
Sep 20 14:09:01 myvolumio lircd-0.10.1[660]: default_init(): No such file or directory
Sep 20 14:09:02 myvolumio lircd[660]: lircd-0.10.1[660]: Error: could not get file information for /dev/lirc0
Sep 20 14:09:02 myvolumio lircd[660]: lircd-0.10.1[660]: default_init(): No such file or directory
Sep 20 14:09:02 myvolumio lircd-0.10.1[660]: Error: could not get file information for /dev/lirc0
Sep 20 14:09:02 myvolumio lircd-0.10.1[660]: default_init(): No such file or directory
Sep 20 14:09:03 myvolumio lircd[660]: lircd-0.10.1[660]: Error: could not get file information for /dev/lirc0
Sep 20 14:09:03 myvolumio lircd[660]: lircd-0.10.1[660]: default_init(): No such file or directory
Sep 20 14:09:03 myvolumio lircd-0.10.1[660]: Error: could not get file information for /dev/lirc0
Sep 20 14:09:03 myvolumio lircd-0.10.1[660]: default_init(): No such file or directory
Sep 20 14:09:04 myvolumio lircd[660]: lircd-0.10.1[660]: Error: could not get file information for /dev/lirc0
Sep 20 14:09:04 myvolumio lircd[660]: lircd-0.10.1[660]: default_init(): No such file or directory
Sep 20 14:09:04 myvolumio lircd-0.10.1[660]: Error: could not get file information for /dev/lirc0
Sep 20 14:09:04 myvolumio lircd-0.10.1[660]: default_init(): No such file or directory
Sep 20 14:09:04 myvolumio sudo[970]: volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/bin/chmod -R a+rwX /etc/lirc/irexec.lircrc /etc/lirc/lirc_options.conf /etc/lirc/lircd.conf /etc/lirc/lircd.conf.d /etc/lirc/lircd.conf.sicher /etc/lirc/lircmd.conf /etc/lirc/lircrc
Sep 20 14:09:04 myvolumio volumio[799]: info: ir_controller: File permissions successfully set on /etc/lirc/*.
Sep 20 14:09:05 myvolumio lircd[660]: lircd-0.10.1[660]: Error: could not get file information for /dev/lirc0
Sep 20 14:09:05 myvolumio lircd[660]: lircd-0.10.1[660]: default_init(): No such file or directory
Sep 20 14:09:05 myvolumio lircd-0.10.1[660]: Error: could not get file information for /dev/lirc0
Sep 20 14:09:05 myvolumio lircd-0.10.1[660]: default_init(): No such file or directory
Sep 20 14:09:05 myvolumio kernel: rc rc0: lirc_dev: driver gpio_ir_recv registered at minor = 0, raw IR receiver, no transmitter
Sep 20 14:09:05 myvolumio sudo[1050]: volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/bin/systemctl restart lircd.service
Sep 20 14:09:05 myvolumio lircd[660]: lircd-0.10.1[660]: Notice: caught signal
Sep 20 14:09:05 myvolumio lircd-0.10.1[660]: Notice: caught signal
Sep 20 14:09:05 myvolumio systemd[1]: lircd.service: Main process exited, code=killed, status=15/TERM
Sep 20 14:09:05 myvolumio systemd[1]: lircd.service: Succeeded.
Sep 20 14:09:06 myvolumio systemd[1]: lircmd.service: Main process exited, code=killed, status=15/TERM
Sep 20 14:09:06 myvolumio systemd[1]: lircmd.service: Succeeded.
Sep 20 14:09:06 myvolumio systemd[1]: Starting lircd(8) initialization helper tool...
Sep 20 14:09:06 myvolumio lircd-setup[1084]: /usr/sbin/lircd-setup:37: DeprecationWarning: The SafeConfigParser class has been renamed to ConfigParser in Python 3.2. This alias will be removed in future versions. Use ConfigParser directly instead.
Sep 20 14:09:06 myvolumio lircd-setup[1084]: parser = configparser.SafeConfigParser()
Sep 20 14:09:06 myvolumio systemd[1]: lircd-setup.service: Succeeded.
Sep 20 14:09:06 myvolumio systemd[1]: Started lircd(8) initialization helper tool.
Sep 20 14:09:06 myvolumio lircd-0.10.1[1097]: Info: lircd: Opening log, level: Info
Sep 20 14:09:06 myvolumio lircd-0.10.1[1097]: Notice: Version: lircd 0.10.1
Sep 20 14:09:06 myvolumio lircd-0.10.1[1097]: Notice: System info: Linux myvolumio 5.10.92-v7+ #1514 SMP Mon Jan 17 17:36:39 GMT 2022 armv7l GNU/Linux
Sep 20 14:09:06 myvolumio lircd-0.10.1[1097]: Info: Initial device: /dev/lirc0
Sep 20 14:09:06 myvolumio lircd-0.10.1[1097]: Notice: 'lirc' written to protocols file /sys/class/rc/rc0/protocols
Sep 20 14:09:06 myvolumio lircd-0.10.1[1097]: Info: [lirc] protocol is enabled
Sep 20 14:09:06 myvolumio lircd-0.10.1[1097]: Notice: Options: driver: default
Sep 20 14:09:06 myvolumio lircd[1097]: lircd-0.10.1[1097]: Info: lircd: Opening log, level: Info
Sep 20 14:09:06 myvolumio lircd[1097]: lircd-0.10.1[1097]: Notice: Using systemd fd
Sep 20 14:09:06 myvolumio lircd-0.10.1[1097]: Notice: Options: output: /var/run/lirc/lircd
Sep 20 14:09:06 myvolumio lircd[1097]: lircd-0.10.1[1097]: Warning: Running as root
Sep 20 14:09:06 myvolumio lircd[1097]: lircd-0.10.1[1097]: Info: Using remote: Apple_A1294.
Sep 20 14:09:06 myvolumio lircd-0.10.1[1097]: Notice: Options: nodaemon: 1
Sep 20 14:09:06 myvolumio lircd[1097]: lircd-0.10.1[1097]: Notice: lircd(default) ready, using /var/run/lirc/lircd
Sep 20 14:09:06 myvolumio lircd-0.10.1[1097]: Notice: Options: plugindir: /usr/lib/arm-linux-gnueabihf/lirc/plugins
Sep 20 14:09:06 myvolumio lircd-0.10.1[1097]: Notice: Options: logfile: syslog
Sep 20 14:09:06 myvolumio lircd-0.10.1[1097]: Notice: Options: immediate-init: 0
Sep 20 14:09:06 myvolumio lircd-0.10.1[1097]: Notice: Options: permission: 666
Sep 20 14:09:06 myvolumio lircd-0.10.1[1097]: Notice: Options: driver-options:
Sep 20 14:09:06 myvolumio lircd-0.10.1[1097]: Notice: Options: pidfile: /var/run/lirc/lircd.pid
Sep 20 14:09:06 myvolumio lircd-0.10.1[1097]: Notice: Options: listen: 0
Sep 20 14:09:06 myvolumio lircd-0.10.1[1097]: Notice: Options: connect: (null)
Sep 20 14:09:06 myvolumio lircd-0.10.1[1097]: Notice: Options: userelease: 0
Sep 20 14:09:06 myvolumio lircd-0.10.1[1097]: Notice: Options: effective_user: (null)
Sep 20 14:09:06 myvolumio lircd-0.10.1[1097]: Notice: Options: release_suffix: _EVUP
Sep 20 14:09:06 myvolumio lircd-0.10.1[1097]: Notice: Options: allow_simulate: 0
Sep 20 14:09:06 myvolumio lircd-0.10.1[1097]: Notice: Options: repeat_max: 600
Sep 20 14:09:06 myvolumio lircd-0.10.1[1097]: Notice: Options: configfile: /etc/lirc/lircd.conf
Sep 20 14:09:06 myvolumio lircd-0.10.1[1097]: Notice: Options: dynamic_codes: (null)
Sep 20 14:09:06 myvolumio lircd-0.10.1[1097]: Notice: Current driver: default
Sep 20 14:09:06 myvolumio lircd-0.10.1[1097]: Notice: Driver API version: 3
Sep 20 14:09:06 myvolumio lircd-0.10.1[1097]: Notice: Driver version: 0.10.0
Sep 20 14:09:06 myvolumio lircd-0.10.1[1097]: Notice: Driver info: See file:///usr/share/doc/lirc/plugindocs/default.html
Sep 20 14:09:06 myvolumio lircd-0.10.1[1097]: Notice: Using systemd fd
Sep 20 14:09:06 myvolumio lircd-0.10.1[1097]: Warning: Running as root
Sep 20 14:09:06 myvolumio lircd-0.10.1[1097]: Info: Using remote: Apple_A1294.
Sep 20 14:09:06 myvolumio lircd-0.10.1[1097]: Notice: lircd(default) ready, using /var/run/lirc/lircd
Sep 20 14:09:06 myvolumio volumio[799]: info: ir_controller: systemctl restart lircd.service succeeded.
Sep 20 14:09:06 myvolumio sudo[1105]: volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/bin/systemctl restart lircd.service
Sep 20 14:09:06 myvolumio lircd[1097]: lircd-0.10.1[1097]: Notice: caught signal
Sep 20 14:09:06 myvolumio lircd-0.10.1[1097]: Notice: caught signal
Sep 20 14:09:06 myvolumio systemd[1]: lircd.service: Main process exited, code=killed, status=15/TERM
Sep 20 14:09:06 myvolumio systemd[1]: lircd.service: Succeeded.
Sep 20 14:09:06 myvolumio systemd[1]: Started Handle events from IR remotes decoded by lircd(8).
Sep 20 14:09:06 myvolumio lircd-setup[1109]: /usr/sbin/lircd-setup:37: DeprecationWarning: The SafeConfigParser class has been renamed to ConfigParser in Python 3.2. This alias will be removed in future versions. Use ConfigParser directly instead.
Sep 20 14:09:06 myvolumio lircd-setup[1109]: parser = configparser.SafeConfigParser()
Sep 20 14:09:06 myvolumio lircd-0.10.1[1112]: Info: lircd: Opening log, level: Info
Sep 20 14:09:06 myvolumio lircd-0.10.1[1112]: Notice: Version: lircd 0.10.1
Sep 20 14:09:06 myvolumio lircd-0.10.1[1112]: Notice: System info: Linux myvolumio 5.10.92-v7+ #1514 SMP Mon Jan 17 17:36:39 GMT 2022 armv7l GNU/Linux
Sep 20 14:09:06 myvolumio lircd-0.10.1[1112]: Info: Initial device: /dev/lirc0
Sep 20 14:09:06 myvolumio lircd-0.10.1[1112]: Info: [lirc] protocol is enabled
Sep 20 14:09:06 myvolumio lircd-0.10.1[1112]: Notice: Options: driver: default
Sep 20 14:09:06 myvolumio lircd[1112]: lircd-0.10.1[1112]: Info: lircd: Opening log, level: Info
Sep 20 14:09:06 myvolumio lircd[1112]: lircd-0.10.1[1112]: Notice: Using systemd fd
Sep 20 14:09:06 myvolumio lircd[1112]: lircd-0.10.1[1112]: Warning: Running as root
Sep 20 14:09:06 myvolumio lircd-0.10.1[1112]: Notice: Options: output: /var/run/lirc/lircd
Sep 20 14:09:06 myvolumio lircd[1112]: lircd-0.10.1[1112]: Info: Using remote: Apple_A1294.
Sep 20 14:09:06 myvolumio lircd[1112]: lircd-0.10.1[1112]: Notice: lircd(default) ready, using /var/run/lirc/lircd
Sep 20 14:09:06 myvolumio lircd-0.10.1[1112]: Notice: Options: nodaemon: 1
Sep 20 14:09:06 myvolumio lircd[1112]: lircd-0.10.1[1112]: Notice: accepted new client on /var/run/lirc/lircd
Sep 20 14:09:06 myvolumio lircd[1112]: lircd-0.10.1[1112]: Info: [lirc] protocol is enabled
Sep 20 14:09:06 myvolumio lircd-0.10.1[1112]: Notice: Options: plugindir: /usr/lib/arm-linux-gnueabihf/lirc/plugins
Sep 20 14:09:06 myvolumio lircd-0.10.1[1112]: Notice: Options: logfile: syslog
Sep 20 14:09:06 myvolumio lircd-0.10.1[1112]: Notice: Options: immediate-init: 0
Sep 20 14:09:06 myvolumio lircd-0.10.1[1112]: Notice: Options: permission: 666
Sep 20 14:09:06 myvolumio lircd-0.10.1[1112]: Notice: Options: driver-options:
Sep 20 14:09:06 myvolumio lircd-0.10.1[1112]: Notice: Options: pidfile: /var/run/lirc/lircd.pid
Sep 20 14:09:06 myvolumio lircd-0.10.1[1112]: Notice: Options: listen: 0
Sep 20 14:09:06 myvolumio lircd-0.10.1[1112]: Notice: Options: connect: (null)
Sep 20 14:09:06 myvolumio lircd-0.10.1[1112]: Notice: Options: userelease: 0
Sep 20 14:09:06 myvolumio lircd-0.10.1[1112]: Notice: Options: effective_user: (null)
Sep 20 14:09:06 myvolumio lircd-0.10.1[1112]: Notice: Options: release_suffix: _EVUP
Sep 20 14:09:06 myvolumio lircd-0.10.1[1112]: Notice: Options: allow_simulate: 0
Sep 20 14:09:06 myvolumio lircd-0.10.1[1112]: Notice: Options: repeat_max: 600
Sep 20 14:09:06 myvolumio lircd-0.10.1[1112]: Notice: Options: configfile: /etc/lirc/lircd.conf
Sep 20 14:09:06 myvolumio lircd-0.10.1[1112]: Notice: Options: dynamic_codes: (null)
Sep 20 14:09:06 myvolumio lircd-0.10.1[1112]: Notice: Current driver: default
Sep 20 14:09:06 myvolumio lircd-0.10.1[1112]: Notice: Driver API version: 3
Sep 20 14:09:06 myvolumio lircd-0.10.1[1112]: Notice: Driver version: 0.10.0
Sep 20 14:09:06 myvolumio lircd-0.10.1[1112]: Notice: Driver info: See file:///usr/share/doc/lirc/plugindocs/default.html
Sep 20 14:09:06 myvolumio lircd-0.10.1[1112]: Notice: Using systemd fd
Sep 20 14:09:06 myvolumio lircd-0.10.1[1112]: Warning: Running as root
Sep 20 14:09:06 myvolumio lircd-0.10.1[1112]: Info: Using remote: Apple_A1294.
Sep 20 14:09:06 myvolumio lircd-0.10.1[1112]: Notice: lircd(default) ready, using /var/run/lirc/lircd
Sep 20 14:09:06 myvolumio lircd-0.10.1[1112]: Notice: accepted new client on /var/run/lirc/lircd
Sep 20 14:09:06 myvolumio lircd[1112]: lircd-0.10.1[1112]: Info: removed client
Sep 20 14:09:06 myvolumio lircd-0.10.1[1112]: Info: removed client
Sep 20 14:09:06 myvolumio systemd[1]: Stopping Handle events from IR remotes decoded by lircd(8)...
Sep 20 14:09:06 myvolumio systemd[1]: Stopped Handle events from IR remotes decoded by lircd(8).
Sep 20 14:09:07 myvolumio systemd[1]: Started Handle events from IR remotes decoded by lircd(8).
Sep 20 14:09:07 myvolumio lircd[1112]: lircd-0.10.1[1112]: Notice: accepted new client on /var/run/lirc/lircd
Sep 20 14:09:07 myvolumio lircd-0.10.1[1112]: Notice: accepted new client on /var/run/lirc/lircd
Sep 20 14:09:07 myvolumio lircd[1112]: lircd-0.10.1[1112]: Info: [lirc] protocol is enabled
Sep 20 14:09:07 myvolumio lircd-0.10.1[1112]: Info: [lirc] protocol is enabled
Sep 20 16:03:21 myvolumio sudo[2031]: volumio : TTY=pts/0 ; PWD=/home/volumio ; USER=root ; COMMAND=/bin/systemctl restart lircmd.service
Sep 20 16:03:21 myvolumio lircmd[2034]: lircd-0.10.1[2034]: Notice: lircmd: Opening log, level: Notice
Sep 20 16:03:21 myvolumio lircd-0.10.1[2034]: Notice: lircmd: Opening log, level: Notice
Sep 20 16:03:21 myvolumio lircd[1112]: lircd-0.10.1[1112]: Notice: accepted new client on /var/run/lirc/lircd
Sep 20 16:03:21 myvolumio lircd-0.10.1[1112]: Notice: accepted new client on /var/run/lirc/lircd
Sep 20 16:03:21 myvolumio kernel: input: lircmd as /devices/virtual/input/input2
Thatās ok. Sorry I forgot to mention that you have to enter Ctrl+c.
Okay, then I did it right
In the first half of the log a lot of errors appear which I do not see on my system. Did you modify the lirc installation after installing the IR Controller plugin apart from adding your own A1294 profile and carrying out my suggestions from this thread?
At first I tried to get success only by installing the plugin and adjust it to my GIPO.
But that was not successfull, even aber a reboot it dosnāt do anything.
Then I created a subdir: āApple Remote A1294ā
under /data/INTERNAL/ir_controller/configurations
and created at first only the lircd.conf with the content from the github.
After a reboot my IR Remote Control starts to work.
That is all I did before our chat.
Should I try to remove my complete subdir āApple Remote A1294ā ?
So you may not have run systemctl enable lircd.service?
No, I donāt think that it is the culprit.
No, I didnāt enable the lircd.service
But after creating ā/data/INTERNAL/ir_controller/configurations/Apple Remote A1294ā and creating lircd.conf
it works
Do you get any output when you run
cat /dev/input/mice
and then press the menu button and up or down keys?
I get control signs ā¦
MENU:
volumio@myvolumio:~$ cat /dev/input/mice
(((((((((((((8(888888
UP
DOWN
LEFT
RIGHT
again MENU
8888(8(((((((((
Because these are control signs, the chat does not show signs like I see them.
Therefore here an image:
Hmmm,
you write:
I press the MENU button and as a second action I press the UP button,
NOT IN PARALLEL
Can you get the text in utf-8 ? It could remove the ? Marks
How do I do that?
For that we have to wait @gvolt maybe knows a other way.
Normally i use a text editor for changing formats.
Not in parallel is correct: First press the menu button to activate mouse pointer control than press up or down buttons to move the pointer. To deactivate mouse pointer control press the menu button again.
