I upgraded the software version 3.757 yesterday (28.09.2024) and now I can see Qobuz playlists, albums etc but nothing plays. The system also does not see the USB harddrive, even the radios do not play. I have RPI 3b+, PecanPi+ DAC and iFi Power Supply. Can it be that RPI is not enough anymore? Previous version worked like a charm. Maybe if there is a way to go back to previous version that may work for me too.
You can rerun setup wizard and reselect your dac.
Or in playback settings choose an other output device, save. Now select your dac and save.
If still not ok, please provide log link
This I did… No help. I strongly believe it’s not about DAC setting… The system just does not respond… Music Library does not load, Web Radio does not play… Really strange
Seems like a good plan, I have used many configs. Too embarresed to say but how to do I clean my boot config? So sorry for the novice level. Shall I take out SD card and put it to a reader and delete by hand or is there another method?
