You should check under http://volumio.local/dev or http://yourvolumioip/dev so you have not enabled beta releases.
Beta updates are meant for people which can bear with software being currently tested. While we try to release beta updates only when we are sure they donāt have any obvious bug, if you want 100% stability just donāt update to test releases, but disable test mode.
PS: We do test each of these updates with all Volumio products and we didnāt have this problem. It would be useful to know few infos about your issue:
- Is it Primo V1 or V2?
- How is your device connected? Eth or Wlan?
- Are you using the app? Where do you get the error?
It is a Primo v1. Used as a bridge, on WIFI, connected SPDIF to a Lyngdorf 1120. Most of the time I use the Browser version via a MacBook m1, sometimes the app on iphone. The two Wolfman links donāt work. The first does not load and the 2nd reports server not found. Do you have a better idea to disable beta update? I canāt find any setting for this in the browser. And yes please get me rid of the BETA stuff
What do you mean with Wolfman links?
This is how to disable test mode:
done, thank you.
Wolfman74 wrote above the links.
Hi, sorry I must have missed this. Iāll have a look at getting a log file on the weekend. Itās been ok lately after the last reboot. Thanks
Dear volumio,
I did an upgrade to version 3.506, but there is no any sign of supersearch in my Volumio. So I guess I did or do something wrong. It is not a big deal but Iāam curious.
this is a Premium only feature. The main reason is due to the high cost of OpenAiās API, which we cannot afford on Virtuoso aloneā¦
I forgot to mention, I do have a premium account.
Please check
yeah nice feature thank you team, will test ASAP
Hi mate, the issue isnāt an issue anymore
If this AI works well I may have to consider an upgrade from Virtuoso (although that seems to be a pretty good sweetspot). Roon lifetime is too expenisve these days and have heard the algorthym isnāt as good as the Tital Connect one, but would be neat to integrate my own collection and streaming.
Does premium give you the ability to steam own collection when out and about, similar to Roon Arc, over cellular data or save for offline?
Ps. Have you considered a āstop playback after current trackā button?
I did check, a fresh reinstall and an update to the latest alfa version of Volumio. During update it shows that there is supersearch. But still in my Volumio Version it does not show up. As a premium discriber Iam very curiousā¦
And of course the system is in test mode = trueā¦
And that was the trick I needed. Supersearch works⦠thanks a lott
I happy volumio fan.
such funā¦
Are you enjoying it?
What you like? What you donāt like? How are you using it?
Very curious!
