Volumio 3.378 (30/09/2022) stops playing after installation of pydPiper for LCD
On my system (a rapsberry PI 3 with HifiBerry DAC+ Pro) I had a version previous of the 3.378 that was working quite well in combination with the sw pydPiper (https://github.com/dhrone/pydPiper/archive/v0.3-alpha.tar.gz) to show song informations on a LCD 20x4 i2c HD44780 display.
After the last OTA upgrade, unfortunately, the player has started to have this strange problem:
  • when I try to start playing music (from the library or a web radio) after a while (about ten seconds) the music stops and the player goes on pause; if I restart the reproduction the problems reoccurs each time…
I’ve done a fresh reinstall directly with the Volumio 3.378 (without pydPiper) and the reproduction is ok.
When I reinstall also pydPiper the problem reappears.
I think it could be something related with a compatibility issue of Docker with the last version of Volumio…
I’ve used this procedure to install pydPiper : pydPiper installation LCD 20x4 i2c HD44780
Any suggestion to solve?
Thanks a lot!
Antonio
