Nice to see that more people are interested in version 2 of volumio on S905
I will try to find the time to build one this or next week.
How does it go with the build?
on my to-do list, but have not come to that task yet.
Looking forward to your volomio-2 for aml9xxx.
Many will be grateful to you, see this by the number of downloads.
Your volumio-2 will be the only one and will fly around the whole world.
thank.
still on the list…
I will spend time on the weekend to build up this idea, if successful I will be able to experience the cinema android app on tv box in a great way. Thanks for the sharing and the article.
Are we moving up on the todo list?
Hello, can you reupload volumio v2 for s905, because link your share not found ,link dead, please sir… help
niet zeuren, komt er niet sneller door
Unfortunately I can’t, that version does not exist anymore.
A new version need to be built first, it’s on my to do list.
Please do not ask for ETAs.
OK, getting nearer. Started a build a few moments ago.
It does not support aml805 and aml812 devices, only the original @balbes150 aml9xxx scripts.
NOTE: I do not take responsibility for his scripts, I am only running them as a service.
Also, as I do not own any of his targeted devices, feedback from you, users, is very very welcome.
Download link:
http://updates.volumio.org/aml9xxxarmv7/volumio/2.806/volumio-2.806-2020-08-02-aml9xxxarmv7.img.zip
this is a 10usd/pc AML S905 tvbox phicomm N1
Can volumio be install to its EMMC?
Hello gkkpch,
Thanks for the work. I will test this build this week and will post my findings.
Start reading from the beginning of this thread, somewhere there is a link to an Armbian forum post, showing how to do this. I can’t help with that.
Thanks for the work!
I’ve tested this build with AML S905D tvbox phicomm N1.
There’s a problem with WiFi.Connection to SSID always fails.
The connection to hostapd works fine.
By the way ,the previous build (volumio-2.603-2019-09-03-vim1.img) works all fine on the same N1 tvbox.
As mentioned before, I did not create the Volumio tvbox version, therefore I do not guarantee anything and cannot support it.
balbes150 dropped support ages ago.
The only thing we have left are the kernel and the build sources.
We can only build, not fix anything, you will need to work with what you have.
Thanks very much…
Thanks GK. and I would like to know if volumio is going to release other images for different devices.
Like an android cell phone, so that you can turn it into a portable hifi DSD player.
