Volumio 2 on Odroid Boards
For the ones interested, long due update on Odroid N2:
volumio-2.697-2019-12-21-odroidn2
Changelog
  • Supported version
  • Current myVolumio functionality
  • Latest Hardkernel linux kernel (4.9.205)
Hi all,
Since last update (OTA) I can’t stop volumio. No effect when choosing close (ArrĆŖt in French) in the menu. Am I the only one?
Merry Christmas to all!
Edit : I’m using odroid 1
EnvoyƩ de mon Redmi Note 5 en utilisant Tapatalk
Not tried it yet, but I will have a closer look next week
Ok. Thank you.
Hi there,
I’m experiencing the following issue with AirPlay after updating one of my Odroid C1+ boards to the latest 2.692 version of Volumio (the other one stays on 2.166 until I’m confident).
When I start changing tracks, pausing and resuming play, the shairport-sync process dies.
It can take 5 actions (start, pause, resume, change track), sometimes more, but it dies 100% of the times.
Spotify Connect and DLNA are solid, but no luck with AirPlay.
My player is AllConnect on Android.
I uploaded a log, taken soon after a crash, to http://logs.volumio.org/volumio/MKMmB0Z.html, to see if it helps.
Any idea?
Thank you and regards
Antonio
Is there any substantial disadvantage running Volumio on Odroid N2 (vs other platforms) ?
If so which would you recommend for long term ease of use/stability ? I’m all for getting the latest hardware and don’t mind occasional tinkering but would want to be on a platform likely to get the most frequent future maintenance. I didn’t know if the N2 just hadn’t made it’s way to the main downloads due to relative recency (I realize there’s only so much time to port to supported platforms).
@DesertRider
No, it performs very well, has an excellent headphone dac onboard and very good support for USB Audio, incl. DSD-capable devices.
It is also very close to full mainline support, from what I know this should be complete for most Amlogic based devices with kernel 5.6
(expected around April/Mai).
Our policy regarding automatically releasing new versions largely depends on the popularity of a particular platform.
We only automatically build for the most popular ones like PI, X86, C1, C2, Tinkerboard Sparky and Pine because if we don’t, people will ask for it anyway.
We save ourselves the effort of building for the 15+ supported devices when we have an update and rather save that time for things with higher priority.
Whether the Odroid N2 will be added to that list, I cannot say, you are the first one to discuss it here, it seems there is hardly any demand for it at the moment. A real pity, perhaps it is too expensive??
This does not mean I would not support it, but would only build a version on request if somebody feels the need to get an update.
Or if there is a major release or a version of which I think should be created and published.
Updates are always posted in the OP of this thread.
The same rule applies to all other community platform portings, new versions with a major release are very likely, others only on request.
Watch here for progress on Volumio for Odroid-C4, coming soon.
Check out this sneak preview volumio-2.765-2020-05-01-odroidc4
HDMI Audio, SPDIF and USB Audio are working.
No support for HiFi shields yet (planned, waiting for HK to resolve an issue).
Known issue: the list of playback options is incorrect (of course there is no line-out, shield options missing)
This will be corrected when the HiFi shields become available.
Updates on Odroid N2:
Changelog
  • Current Volumio/ myVolumio functionality (incl. meta data discovery)
  • Stock Hardkernel Remote support, incl Power on/off
  • Performance improvements
  • More support for various USB Audio devices
See OP
Are other DACS and Digi’s supported on the ODROID platform? I see in your post that the ODROID DAC plus is not yet currently supported. Do you have an ETA on that?
For Odroid C4: no ETA, I’m waiting for Hardkernel to solve the issue which caused them to revert the Hifi Shield patches.
Only C1/C2/C4 support the Hardkernel DACs.
XU4 and N2 don’t and will never.
N2 is very good with USB Audio, HDMI and line out.
XU4 does well with USB Audio.
The other Audio Out choices for the C4 currently are
  • USB Audio (tested up to DSD 512), no glitches anywhere.
  • SPDIF via coax (tested via pin J7-1 GND, J7-2 SPDIF), working well.
  • HDMI Audio (tested with an HDMI Extractor and a Samsung TV).
The HiFi Shields are good, worth the money, but there are better alternatives.
My advice: in case you don’t already own one of the HiFi Shields, choose a good USB DAC for Odroids.
You would be much more flexible and able to use it on other devices as well
Thank you!
New versions out for ALL Odroid boards.
Includes the latest myVolumio Music Credits feature
Do you know if there is a really good post on getting a 2004A 2X40 LCD with SDL connected and displaying critical info?
No, but you may be able to find some info on the hardkernel.com site (they have a fairly good wiki) or the board forums.
For the volumio info you will find a couple of threads here, mostly PI, but perhaps good as an example.
Odroid C2 last volumio version 2.777
I connect waveshare 7 inch display
But touch don’t work.
Bus 001 Device 005: ID 0eef:0005 D-WAV Scientific Co., Ltd
I try to add usbhid.quirks=0x0eef:0x0005:0x0004 on boot.ini but it does not help.
Maybe missing module ?
Missing module? Looks like it. In case you could help find which module, I’ll add it. Otherwise it is going to be a guess game for me.
Any updated on C4 development?
The current image is fully functional, incl. S/PDIF on header J7.2
Meanwhile HK updated the kernel, I2S is now available.
Both HiFi Shields are on my to-do list, unfortunately there is no time for that at the moment.
I will post a new version when available.
