After the boos as a preliminary setup activity I tried the usual “apt-get update” and “apt-get upgrade”.
The prompt of the latter shows that about 300 packages are out of date.
I quitted the command, but the question is now: should I update or not?
I think there is a problem in /etc/apt/sources.list.
deb http://http.debian.net/debian jessie main non-free
deb-src http://http.debian.net/debian wheezy main non-free
This means that the reference Debian distribution used by apt-get is Jessie, whilst it seems that Volumio is built on previuos distribution i.e. Wheezy. This causes the request to upgrade over 300 packages.
I tried to upgrade and fortunately apt-get is savvy enough to keep back many packages:
The following packages have been kept back:
base-passwd bind9-host bsdutils dbus dmsetup init-system-helpers initscripts
iproute iptables iputils-ping isc-dhcp-client isc-dhcp-common libbind9-90
libdevmapper1.02.1 libhtml-parser-perl libio-socket-ssl-perl libisc95
libisccfg90 liblocale-gettext-perl liblwres90 libnet-ssleay-perl
libpam-modules libpam-modules-bin libpam0g libpulse0 libsasl2-2
libsemanage-common libsemanage1 libsocket6-perl libssh2-1
libtext-charwidth-perl libtext-iconv-perl libusb-1.0-0 libva1 libxslt1.1
login minidlna mount mpd nginx nginx-common nginx-full ntfs-3g
openssh-client openssh-server passwd perl perl-base perl-modules php-apc
php5 php5-cli php5-common php5-curl php5-fpm php5-sqlite procps sudo sysv-rc
sysvinit sysvinit-utils udev util-linux wget zd1211-firmware
0 upgraded, 0 newly installed, 0 to remove and 65 not upgraded.
It however updates many others packages (about 250) which are mainly libraries.
The net result is that, surprisingly, everything seems to work: the web interface works perfectly and the music flows from the speakers.
I also upgraded the kernel to the 3.4.105 version, taken from the Igor Pecovnik’s site.
I have a similar problem on Raspberry Pi after update and upgrade, with this sources.list:
deb http://repo.volumio.org/apt/ jessie main contrib non-free rpi
deb http://mirrordirector.raspbian.org/raspbian/ jessie main non-free rpi
deb-src http://mirrordirector.raspbian.org/raspbian/ wheezy main non-free rpi
because I was trying to install the python md module. Now, the WI does not work any more.
Some questions:
I was also wondering about the entries referencing Jessie and Wheezy in sources.list. Is that intentional? Why?
Can you elaborate a bit more what happened with the update, and how it can be fixed? Configurations of nginx, mpd and php-fpm were mentioned, why haven’t the the configs not been saved by the update process?
The easiest, fastest way to fix the system is reflash the SD card.
Upgrades to volumio via apt-get isn’t supported, writing an how to resurrect after apt-get upgrade etc. takes a lot of time, time that is used for bug fixes and features for volumio.
What you could try, after reflashing the SD, is to change jessie into wheezy. I did try this once and the upgrades didn’t affect the installation, but be sure to keep current when asked.
