Volumio Version: 4.073
Hardware: Raspberry Pi 4
DAC: USB sound card
When I change the volume on the Volumio UI it is not synced with the qobuz-connect client:
- Change the volume in Qobuz connect → Volumio UI will detect the changed volume
- Change the volume in the Volumio UI
- Change the volume via the Qobuz app → Qobuz connect daemon will use the volume which was set in step 1
