VERSION: 2.502 large drive won't show after reboot
Music library is blank after restart after VERSION: 2.502 updated. Previously it took approximately 5 minutes for attached USB to show up. It is now stays blank after an hour.
If I choose to shut down the options will momentarily appear as it’s shutting down so it seems that there is a file that isn’t releasing or finishing
Not an issue with smaller USB flash drive or smaller Network attached drive but will not show if 3TB hard drive is attached after reboot.
It wan’t show up as a DLNA destination until the restart finishes so it’s only able to play Spotify until I unplug the hard drive and restart. I can then plug in the hard drive and it will index all the files and work as expected until another reboot.
It will show the hard rive as a networked attached drive using windows 10 but not in the GUI after reboot.
What can I provide to assist to identify the bug?
