Use volumio as an alexa speaker
i everyone. I wanted to know if there is a plugin to connect volumio to alexa so that I can direct the alexa audio sources to my volumio systems as with the various echo devices
No such plugin exists. Maybe somone’s coded some kind of workaround themselves. Not likely to be sustainable as Amazon are protective of their APIs.
Years ago someone published a project online allowing you to connect to Alexa using a Pi (not with Volumio). The drawback was that you had to use a button to talk because Amazon had blocked open mike access to third parties.
