Use parallel connection on 16x2 lcd and pydpiper
Hi wheaten! Mind me i am successfully install RPLCD on rpi3b+ before i proceed to the next step. How or what should i execute to open a existing python script and do import the rplcd?
Thanks,
You want to edit an existing python script?
Use nano on the device or use Filezilla with Notepad++ or Winscp with Notepad++
I mean, open the python script using command so i could import rplcd.
As per said this (Getting Started — RPLCD 1.3.0 documentation) thr next step after conneting wire via i2c
Initializing the LCD
Setup: I²C
First, import the RPLCD library from your Python script.
How should i execute command to open an python script or a python3 script and import rplcd
Sorry for being arrogant, i just want to learn.
Thank you so much wheaten.
Support how-to program Python is not part of this forum.
Maybe someone here has time to do it, otherwise use google.
No no no, i mean what command should i type to open python 3 scripts
pyhton3 /path_to_script/scriptname.py
Thank you wheaten.
