Prior to downloading Volumio, I had installed OSMC on my Raspberry Pi 3. I also purchased the OSMC RF Remote which worked fine.
I notice that Volumio supports the Justboom IR Remote and I suspect that the OSMC RF Remote is made by the same manufacturer since it seems very similar. I would like to be able to use the RF remote with Volumio. Can anyone give me some pointers to how I might accomplish this?
I have done some device related software over the years so I’m not totally afraid of diving into some code. If someone could give me a head start, I’d appreciate it.
Thanks,
Rick
