USB DAC in Volumio on Pi Zero W
I’m trying to get my DAC Magic Plus recognized by Volumio but even the aplay -l doesn’t lists it, neither does lsusb -t
volumio@volumiopizero:~$ lsusb -t
/: Bus 01.Port 1: Dev 1, Class=root_hub, Driver=dwc_otg/1p, 480M
volumio@volumiopizero:~$ aplay -L
null
Discard all samples (playback) or generate zero samples (capture)
pulse
PulseAudio Sound Server
default:CARD=ALSA
bcm2835 ALSA, bcm2835 ALSA
Default Audio Device
sysdefault:CARD=ALSA
dmix:CARD=ALSA,DEV=0
Direct sample mixing device
dmix:CARD=ALSA,DEV=1
bcm2835 ALSA, bcm2835 IEC958/HDMI
dmix:CARD=ALSA,DEV=2
bcm2835 ALSA, bcm2835 IEC958/HDMI1
dsnoop:CARD=ALSA,DEV=0
Direct sample snooping device
dsnoop:CARD=ALSA,DEV=1
dsnoop:CARD=ALSA,DEV=2
hw:CARD=ALSA,DEV=0
Direct hardware device without any conversions
hw:CARD=ALSA,DEV=1
hw:CARD=ALSA,DEV=2
plughw:CARD=ALSA,DEV=0
Hardware device with all software conversions
plughw:CARD=ALSA,DEV=1
plughw:CARD=ALSA,DEV=2
default:CARD=Headphones
bcm2835 Headphones, bcm2835 Headphones
sysdefault:CARD=Headphones
dmix:CARD=Headphones,DEV=0
dsnoop:CARD=Headphones,DEV=0
hw:CARD=Headphones,DEV=0
plughw:CARD=Headphones,DEV=0
It seems to me that the Pi isn’t even initializing the DAC drivers. FYI, I’m using a RPi Zero W, feeding it power through Ext port of the DAC and feeding the Type B port of the DAC with Micro USB Data port.
Never mind, looks like a faulty Micro USB to Type A converter was causing the issue. Replaced it with another and rebooted the Zero and when Volumio loaded, it automatically recognized the DAC.
