Hi all,
Just installed latest volumio on a rpi 3B+ with justboom dac, works great.
My only issue is with the upnp renderer, i just cannot get any client to find it.
Setup:
Mobile phone directly connected to the volumio wifi hotspot (so no router/L2 switch)
upmpdcli is listening on udp 1900 and the traffic is reaching the volumio box, however the renderer does not show up (tried a couple of android clients, no luck). Nothing obviously wrong in the logs.
Any hint?
Thank you.
volumio@multimedia:~$ sudo tcpdump -i wlan0 port 1900
tcpdump: verbose output suppressed, use -v or -vv for full protocol decode
listening on wlan0, link-type EN10MB (Ethernet), capture size 262144 bytes
14:09:02.700257 IP 192.168.211.2.48706 > 239.255.255.250.1900: UDP, length 128
14:09:02.700512 IP 192.168.211.2.48706 > 239.255.255.250.1900: UDP, length 133
14:09:02.700616 IP 192.168.211.2.48706 > 239.255.255.250.1900: UDP, length 123
volumio@multimedia:~$ sudo netstat -lnupe
Active Internet connections (only servers)
Proto Recv-Q Send-Q Local Address Foreign Address State User Inode PID/Program name
udp 0 0 0.0.0.0:1900 0.0.0.0:* 1000 18875 1074/upmpdcli
udp 0 0 0.0.0.0:5555 0.0.0.0:* 1000 20840 890/node
udp 0 0 0.0.0.0:54713 0.0.0.0:* 1000 20365 890/node
udp 0 0 0.0.0.0:53 0.0.0.0:* 0 15893 900/dnsmasq
udp 0 0 0.0.0.0:67 0.0.0.0:* 0 15168 906/dhcpd
udp 0 0 0.0.0.0:57424 0.0.0.0:* 103 12175 610/rpc.statd
udp 0 0 0.0.0.0:111 0.0.0.0:* 0 12129 600/rpcbind
udp 0 0 192.168.211.1:123 0.0.0.0:* 100 15313 729/ntpd
udp 0 0 192.168.50.10:123 0.0.0.0:* 0 12993 729/ntpd
udp 0 0 127.0.0.1:123 0.0.0.0:* 0 12992 729/ntpd
udp 0 0 0.0.0.0:123 0.0.0.0:* 0 12986 729/ntpd
udp 0 0 192.168.211.255:137 0.0.0.0:* 0 22461 845/nmbd
udp 0 0 192.168.211.1:137 0.0.0.0:* 0 22460 845/nmbd
udp 0 0 192.168.50.255:137 0.0.0.0:* 0 16540 845/nmbd
udp 0 0 192.168.50.10:137 0.0.0.0:* 0 16539 845/nmbd
udp 0 0 0.0.0.0:137 0.0.0.0:* 0 16536 845/nmbd
udp 0 0 192.168.211.255:138 0.0.0.0:* 0 22463 845/nmbd
udp 0 0 192.168.211.1:138 0.0.0.0:* 0 22462 845/nmbd
udp 0 0 192.168.50.255:138 0.0.0.0:* 0 16542 845/nmbd
udp 0 0 192.168.50.10:138 0.0.0.0:* 0 16541 845/nmbd
udp 0 0 0.0.0.0:138 0.0.0.0:* 0 16537 845/nmbd
udp 0 0 0.0.0.0:50865 0.0.0.0:* 104 14585 660/avahi-daemon: r
udp 0 0 127.0.0.1:46805 0.0.0.0:* 1000 18873 1074/upmpdcli
udp 0 0 0.0.0.0:5353 0.0.0.0:* 104 14583 660/avahi-daemon: r
udp 0 0 0.0.0.0:46846 0.0.0.0:* 0 17474 906/dhcpd
udp 0 0 0.0.0.0:775 0.0.0.0:* 0 12136 600/rpcbind
udp 0 0 0.0.0.0:38158 0.0.0.0:* 1000 20366 890/node
udp 0 0 127.0.0.1:786 0.0.0.0:* 0 12168 610/rpc.statd
udp6 0 0 :::60362 :::* 104 14586 660/avahi-daemon: r
udp6 0 0 :::53 :::* 0 15895 900/dnsmasq
udp6 0 0 :::111 :::* 0 12138 600/rpcbind
udp6 0 0 :::123 :::* 0 12987 729/ntpd
udp6 0 0 :::5353 :::* 104 14584 660/avahi-daemon: r
udp6 0 0 :::775 :::* 0 12139 600/rpcbind
udp6 0 0 :::15138 :::* 0 17475 906/dhcpd
udp6 0 0 :::52532 :::* 103 12179 610/rpc.statd
2019-04-08T13:52:18.806Z - info: Loading plugin "upnp"...
2019-04-08T13:52:18.814Z - info: [1554731538813] Starting Upmpd Daemon
2019-04-08T13:52:18.815Z - info: CoreCommandRouter::executeOnPlugin: system , registerCallback
2019-04-08T13:52:18.818Z - info: Loading plugin "my_music"...
2019-04-08T13:52:18.826Z - info: Loading plugin "mpd"...
2019-04-08T13:52:20.053Z - info: Loading plugin "upnp_browser"...
2019-04-08T13:52:21.172Z - info: Loading plugin "networkfs"...
2019-04-08T13:52:21.450Z - info: CoreCommandRouter::executeOnPlugin: system , registerCallback
2019-04-08T13:52:21.451Z - info: Loading plugin "alarm-clock"...
2019-04-08T13:52:21.716Z - info: Loading plugin "airplay_emulation"...
2019-04-08T13:52:21.745Z - info: Starting Shairport Sync
2019-04-08T13:52:21.746Z - info: Loading plugin "last_100"...
2019-04-08T13:52:21.754Z - info: Loading plugin "webradio"...
2019-04-08T13:52:21.772Z - info: Loading plugin "i2s_dacs"...
2019-04-08T13:52:21.783Z - info: I2S DAC not set, start Auto-detection
2019-04-08T13:52:21.801Z - info: Loading plugin "volumiodiscovery"...
2019-04-08T13:52:21.875Z - info: Applying required configuration parameters for plugin volumiodiscovery
2019-04-08T13:52:21.910Z - info: CoreCommandRouter::executeOnPlugin: system , registerCallback
2019-04-08T13:52:21.911Z - info: Loading plugin "youtube"...
2019-04-08T13:52:23.785Z - info: Loading plugin "albumart"...
2019-04-08T13:52:23.811Z - info: Plugin example_plugin is not enabled
2019-04-08T13:52:23.812Z - info: Loading plugin "updater_comm"...
2019-04-08T13:52:23.943Z - info: Plugin mpdemulation is not enabled
2019-04-08T13:52:23.944Z - info: Loading plugin "rest_api"...
2019-04-08T13:52:23.957Z - info: Loading plugin "websocket"...
2019-04-08T13:52:23.988Z - info: ___________ START PLUGINS ___________
2019-04-08T13:52:23.993Z - info: CoreCommandRouter::executeOnPlugin: mpd , getConfigParam
2019-04-08T13:52:23.994Z - info: CoreCommandRouter::volumioAddToBrowseSources[object Object]
2019-04-08T13:52:23.996Z - info: [1554731543995] CoreMusicLibrary::Adding element Media Servers
2019-04-08T13:52:24.023Z - info: CoreCommandRouter::executeOnPlugin: alsa_controller , getConfigParam
2019-04-08T13:52:24.024Z - info: CoreCommandRouter::executeOnPlugin: alsa_controller , getConfigParam
2019-04-08T13:52:24.026Z - info: CoreCommandRouter::volumioAddToBrowseSources[object Object]
2019-04-08T13:52:24.026Z - info: [1554731544026] CoreMusicLibrary::Adding element Last_100
2019-04-08T13:52:24.029Z - info: CoreCommandRouter::volumioAddToBrowseSources[object Object]
2019-04-08T13:52:24.029Z - info: [1554731544029] CoreMusicLibrary::Adding element Webradio
2019-04-08T13:52:24.031Z - info: CoreCommandRouter::executeOnPlugin: system , getSystemVersion
2019-04-08T13:52:24.034Z - info: Youtube::onStart Adding to browse sources
2019-04-08T13:52:24.034Z - info: CoreCommandRouter::volumioAddToBrowseSources[object Object]
2019-04-08T13:52:24.035Z - info: [1554731544034] CoreMusicLibrary::Adding element Youtube
2019-04-08T13:52:24.038Z - info: -------------------------------------------
2019-04-08T13:52:24.039Z - info: ----- MyVolumio plugins startup ----
2019-04-08T13:52:24.039Z - info: -------------------------------------------
2019-04-08T13:52:24.040Z - info: Loading plugins from folder /myvolumio/plugins
2019-04-08T13:52:24.064Z - info: Loading plugins from folder /data/myvolumio/plugins
2019-04-08T13:52:24.066Z - info: Loading plugin "my_volumio"...
2019-04-08T13:52:24.710Z - info: Loading plugin "streaming_services"...
2019-04-08T13:52:25.070Z - info: CoreCommandRouter::executeOnPlugin: system , getConfigParam
2019-04-08T13:52:25.071Z - info: CoreCommandRouter::executeOnPlugin: system , getConfigParam
2019-04-08T13:52:25.107Z - info: Streaming services startup
2019-04-08T13:52:25.142Z - info: Loading i18n strings for locale en
2019-04-08T13:52:25.179Z - info: CoreCommandRouter::executeOnPlugin: mpd , getConfigParam
2019-04-08T13:52:25.182Z - info: CoreCommandRouter::initPlayerControls
2019-04-08T13:52:25.193Z - info: CoreCommandRouter::executeOnPlugin: alsa_controller , getConfigParam
2019-04-08T13:52:25.194Z - info: CoreCommandRouter::executeOnPlugin: alsa_controller , getConfigParam
2019-04-08T13:52:25.195Z - info: CoreCommandRouter::executeOnPlugin: alsa_controller , getConfigParam
2019-04-08T13:52:25.196Z - info: CoreCommandRouter::executeOnPlugin: alsa_controller , getConfigParam
2019-04-08T13:52:25.197Z - info: CoreCommandRouter::executeOnPlugin: alsa_controller , getConfigParam
2019-04-08T13:52:25.198Z - info: CoreCommandRouter::executeOnPlugin: alsa_controller , getConfigParam
2019-04-08T13:52:25.208Z - info: CoreCommandRouter::executeOnPlugin: mpd , getConfigParam
2019-04-08T13:52:25.214Z - info: BOOT COMPLETED
