Trying to upgrade RP3 from Vol3 to Vol4, just boots to Rasp desktop, no volumio.
Yeah no clue what you did, Volumio doesn’t have rasp desktop.
Download Volumio from Get Started - Volumio
Flash the image using Raspberry Pi Imager and boot it.
Thanks Wheaten, I was choosing the first operating system in RP Imager, which is not Volumio. I went down to custom and chose local file, Volumio-4.119-2026-03-24-pi and I end up with a .img file on my SD card. This will not boot my RP3.
You need to extract the img file from the downloaded .zip file and use that in RP Imager.
What should I use to unzip, windows does not recognize as a zip file?
You may have extensions turned off, it’s definitely a zip file, the current one is
Volumio-4.119-2026-03-24-pi.zip
Double-click the downloaded file and it should show you the contents in File Explorer, copy the contents, go back to the folder the zip file is in and right-click, paste.
All good, rebooted my PC and .zip is recognized. Thanks for everyone’s help.
