Other than the addition of stuff as Tidal (which I do not use), are there other advantages to upgrade to Volumio 2502?
Can I upgrade from within Volumio or do I need to make a new install?
Fine to update from Volumio … no one is forcing you to use the new features in MyVolumio However, in additional to the current ones, there are some interesting looking features on the horizon.
