Maybe this has already been asked, but I couldn’t find it.
How do I update the installation?
If i try to check for an update it just says I’m on the latest release.
Do I have to create a fresh installation from the updated image?
Maybe because there’s no new version…
If you want to test a dev version : volumio.github.io/docs/FAQs/Upd … nance.html
The version I have installed is 1.008, and the latest .img that is available in the ‘getting started’ thread is 1.018.
I was kind of expecting that it would update itself
It should update…
Have you made some changes?
Not that I can think of.
I have it running over wireless, so obviously I had to configure that.
And I have added some local music via a SMB share, but otherwise its pretty standard stuff.
