Update v3.634 - UNSTABLE ALPHA BUILD?
Hi - Why does this update have the last line, UNSTABLE ALPHA BUILD - DO NOT INSTALL?
Am I missing something? thanks
Update v3.634
FIXES
  • Fix for mpd crashing with wrongly formatted cue files
  • Restore install-to-disk on x86 and ThinkerBoard
    NEW ADDITIONS
  • Bump MPD to 0.23.15-3
  • Add extra codecs
  • UNSTABLE ALPHA BUILD - DO NOT INSTALL
this is still a test build so not a released build, testing only…
do you have test mode switched on in /dev? that’s why…
Please disable test mode as indicated by DVO.
These build are there to address certain issues and should only be installed on Volumio’s ask. If you decide to run them, accept that things might be broken or not working as expected.
thankyou!
