Beta version starting soon…
EDIT: Due to unforeseen technical issues, the Volumio 4 versions for the N2 and C4 v4 will be delayed until further notice.
Reserved
As it appears, the M1S works with Volumio 4 without any problems sofar on a locally compiled image.
As this will cause no more any extra work getting it ready for the “myVolumio” addition, we can safely add it to the “intended Odroid Volumio 4 community porting” list.
Can you upload the Volumio 4 image for the Odroidn2 here?
I’m afraid it is not that easy. First, there aren’t any community portings published yet.
Second, I did start on V4 with Odroid N2/C4, but due to technical issues with the kernels used for V3, I am forced to rebuild N2/C4 Odroid plarform support for V4 from scratch.
I’ll be honest, there is no guarantee.
It will probably work, best case perhaps not for everyone, especially re. start/stop power button.
ETA: not for a while, end Q1 2026 earliest.
Oh, okay. Thank you for your very interesting information about Project V4 and Odroid N2/C4. We wish you continued success and all the best. It will be exciting to see how the project progresses.
