Good evening
Among the icons in the Artists section, Volumio doesn’t display or download images for some groups (perhaps unknown to the database?).
Is there a way to add them manually?
Thank you all
Good evening
Thank you all
I use mp3tag, a free app that allows you to add metadata, including album art to your files.
Here in Australia, we have plenty of small bands without much international recognition, they often don’t get a band image in Volumio. Last I heard, Volumio was getting band images from a web radio repository (maybe LastFM).
That’s not the same thing. The band images aren’t usually album cover art. Also, adding the cover art as metadata in the music files doesn’t give an album image in the Volumio interface, that is the role of the cover.jpg/album.jpg files in the album folder alongside the music files.
Actually, I asked how to get the group icons in the Artists section. Not the album images—I already have those.
Thanks. I already use Mp3Tag. But the problem is in the Artists section—not the Albums section.
