Until recently I have been able to access my Synology NAS from my PI running Volumio. Until I encountered a crash. I can no longer access the NAS. I get an error message; see the photo.
Please advise.
Kind regards, Henry
Please advise.
Kind regards, Henry
I guess after the crash you did a new install and forgot to add the proper NFS version?
Try in options:
nfsvers=2
or nfsvers=3
Depending on what your NAS is accepeting.
Hi Wheaton. I guess so. How do I do this, I am a novice.
Hi Wheaton,
Thanks, but no luck. Would appreciate any suggestions.
Henry
Are you sure that the path to share is correct? Normally it doesn’t contain Volume info.
I would expect something like:
Thanks Wheaten. That did the trick.
Kind regards,
Henry
I am have from july 2024 the same errror message, please give
NAS synology settings
i) nfs 2or 3
ii) user settings
https://help.volumio.com/help/how-to-add-music-from-a-shared-folder-on-a-synology
Volumio nfs settings??
