Unable to access / select multiform devices
A bit of a strange problem:
I recently added a second Volumio device (Allo Digi One + Allo Boss Dac). If I use the web interface I can see the two Volumio devices (Kitchen and Living Room) as soon as the page loads. I can select one of the two and then start playing music. In order to go back and select a different device I have to click on ‘Volumio’ at the top left of the web page. No other way I can find to switch between devices. Is that normal?
A bit more troublesome than the above… the iOS Volumio app does not seem to allow me to switch between Volumio devices. I think I am supposed to be able to scroll down somehow and see the two devices but I am unable to. Is there something I am missing?
Many thanks
Yiannis
I can’t replicate this sorry. I can click directly on whichever device I want to control. Which version of Volumio are you using?
Goodmorning and thank you for checking on this :slight_smile:
I am running version 2.565 (released March 12th).
Just to double check I am not doing something wrong… Where in the app should I be looking in order select between two Volumio devices?
Should I be using the ‘playback’ page (please see attachment) and then scrolling down to find the devices?
Many thanks
On my PC, you can see the 3 devices towards the bottom of the screen. I simply click on the one of interest. On my mobile it is a similar story, but obviously I need to scroll down to find the devices.
On the mobile, do you scroll down within the ‘playback’ screen?
Many thanks
