Hello
I have just bought Raspberry PI3. I flashed Volumio as described. I have used it before with at my friends house with airplay and everything worked fine.
Now I am trying to run it at home at music plays 10-15 sec and then interrupts with different clickings and noise. However playing from laptop using Itunes is ok. I also tried runeaudio and the issue was the same. Honestly I found volumio more user friendly so I hope to fix the problem here.
Second problem is I can not mount the drive from my laptop (Win7) as a NAS to play the music from it. If anyone can help me with? My volumio sees only a public folder of my documents and doesn’t see my D drive regardless I shared it through the settings.
Thank you in advance.
K
