Two different UI on Volumio
Hi, did anyone try to have two different UI for Volumio?
One via Volumio.local when controlling with smartphone for example and second on connected lcd screen with kiosk as a browser?
Regards
Olek
Wysłane z iPhone za pomocą Tapatalk
yes, that works.
But these will be two different sessions, which means two different UIs.
They will not be synchronous at all points, except the playback tab, that should be OK
Hi, can you please describe how to do it in a simple way?
installing-the-touch-display-plugin-t6032.html
Hi, it is not my case. I have 3.5 lcd working fine in kiosk mode. I was wandering if I can display second instance of UI that I can modify in order to fit 3.5 screen while preserving original one for use with smartphone.
