Turn on a LED when Volumio UI is ready
Hey @lelsteph,
Numerous plugins are waiting for system ready before performing action. Did you check how this is programmed in any plugin? Let’s start with letter A.
Hello
Thank you so much!
So the trick is: const systemStatus = process.env.VOLUMIO_SYSTEM_STATUS;?
Where is, all of the available properties and function documented?
Thanks!
Hey @lelsteph,
It takes time, but entire backend is opensource.
I do suggest to understand build system, backend role and plugins relation with the entire ecosystem.
Thank You!!
