I used to turn off the hdmi port on my old “b” to decrease the temp by 1C.
The same command does not work on the b+.
What is the command for it?
Thanks.
Thanks.
By turning HDMI off, did you mean to use the following command?
$ sudo /opt/vc/bin/tvservice -o
I usually use -p to turn HDMI on first, then use -o to turn it off. As I run Volumio on RPi 3B+ headless, I have not checked if HDMI displace actually is turned off. But, the command lines did not give me any error messages.
John
It works now. I must typed something else. Thx.
