When I try to install the Tunein plugin via the plugin section of the web interface I get an error message I’m using the latest version 2.389. Is there a way to install this via command line?
Cheers
Richard
Downloading plugin at volumio.github.io/volumio-plugin … _radio.zip
END DOWNLOAD: volumio.github.io/volumio-plugin … _radio.zip
Creating folder on disk
Unpacking plugin
Checking for duplicate plugin
Copying Plugin into location
Installing dependencies
The following error occurred when installing the plugin: Error
