Hi could someone tell me what the code is for playing a playlist using the triggerhappy config file ?
Just this one feature im missing.
I would think you have to use the curl feature ? No programming skills so im lost.
Thanks in advance.
Thanks in advance.
Have a look here maybe of some use.
You can send those command from the address bar of a browser or using curl from a command prompt / script etc
I did but couldn’t find anything related.
If I just got an example I can adjust it to my playlist.
In Moode player,
mpc load “playlist”
is used.
Will this work in Volumio ?
Ever so sorry…my link didnt show. REST api is what you should be looking at.
You can load playlist via the web browser address bar or or using curl from a command prompt / script etc
Thanks !
Just a note. As this got me when I first started using it.
If you are sending those commands via the web browser address bar then they will work as is.
But… if you are sending via command prompt or SSH and the command contains an & symbol you will need to wrap that particular command in quotation marks otherwise it will not work.
ie.
volumio.local/api/v1/commands/?cmd=playplaylist&name=Rock
Via command prompt should be
volumio.local/api/v1/commands/?cmd="playplaylist&name=Rock"
Sadly, i cant get this working.
Keyboard is attached to my player.
I tried different combos, these dont work
KEY_B 2 /usr/bin/curl localhost:3000/api/v1/commands/?cmd=“playplaylist&name=2023”
KEY_B 2 curl localhost:3000/api/v1/commands/?cmd=“playplaylist&name=2023”
KEY_B 2 /usr/bin/curl -i --header “Content-Type: application/json” localhost:3000/api/v1/commands/?cmd=“playplaylist&name=2023”
help
Triggerhappy (never used it) from a quick google is a keyboard hotkey program…right?
But first things first.
Get the commands working in the command window first.
Are you running Volumio on the same machine as you are sending the commands ?
These work for me if I SSH into the machine, which is the same as being on the same machine
curl localhost:3000/api/v1/commands/?cmd=“playplaylist&name=stuff”
curl 127.0.0.1:3000/api/v1/commands/?cmd=“playplaylist&name=stuff”
or even the Volumio machines own ip address will work.
curl 192.168.0.19:3000/api/v1/commands/?cmd=“playplaylist&name=stuff”
But if you are trying to do this from a remote machine ie my windows PC command prompt…then
only this works
curl 192.168.0.19/api/v1/commands/?cmd=“playplaylist&name=stuff”
The ip shown needs to be the ip of the machine you are trying to reach.
When you get it working from the command prompt then you should configure the triggerhappy program.
But remember… if you are sending from a browser address bar then you dont need the quotation marks or curl. Does the tiggerhappy program send in the same mannor ?
Might be worth trying command without special characters also to see whether its those causing the issue.
Good luck
Yes Triggerhappy is a hotkey program. Great add to my players
Thanks for the tips, the curl command works form a different laptop on my network.
Now i need to get it working from the player itself as my mini keyboard is attached to the player.
Ok so the curl command only works in Windows cmd.
In Linux terninal i get the same error as on ssh to the player.
{“Error”:“command not recognized”}
Ok if i type this command ;
curl localhost:3000/api/v1/commands/?cmd=playplaylist&name=2
i got this reply but nothing happens with my player ;
$ {“time”:1706729781883,“response”:“playplaylist Success”}
[2]+ Done curl localhost:3000/api/v1/commands/?cmd=playplaylist
Thats some progress, i guess
