Track Restarts On Volume Change
I have a strange issue in that when I change the volume (via either a Rotary Encoder using the RotaryEncoder II plugin or a IR device using the IR plugin) the track restarts.
Volume change works as it should do, however it resets to the beginning of the current playing track.
Any suggesions on what it could be?
Thanks in advance.
