Track Order and Naming
I am new to Volumio and quite like what I have seen so far, having tried other systems to create a music server and given them up as too cumbersome to use.
However, I do have a couple of questions.
I can list the contents of a directory and they appear to be ordered in accordance with the track number in the tags. But click in the directory and select ‘Add to queue’ and they are added in a random order. Not good if it is a classical piece you wish to play in order.
Is there something I am missing in the settings that would ensure the correct play order as a full directory is added to the queue, or is it necessary to load each track in turn in the correct sequence to achieve this. If this is necessary, then I would of course create a PlayList.
Also I see a small number of tracks that don’t display the name correctly even though it is in the tags. Is anyone able to explain what may be causing this.
