Using current Volumio 3 D90SE MQA indicator never gets set, it continues to indicate PCM. I had a Pro-ject prebox s2 digital working fine with MQA previously. I had to dump the prebox s2 since it had started creating distortion when using the hdmi input. BTW, the D90SE sounds a lot bit better than the prebox s2.
We are about to release an upadate which will fix this
Thanks. I’ll try to wait patiently.
