Hi there, I have tidal with mastering but every mastered track shows playing at 44.1Khz. How can I confirm it’s playing at the correct rate?
you can only see this on your DAC, if your DAC is capable of showing this. (Bitrate and MQA).
This has been discussed multiple times on this community, use the search function.
You can also find the answer in Volumios Knowledge base - Why has Tidal playing an MQA track, but Volumio shows 44.1kHz 16bit resolution?
