Tidal - [EXPLICIT] marking
Hi, I’m enjoying Tidal via myvolumio very much though I do have one query. Everything I stream; even the Classical genre is, marked as [EXPLICIT].
I have taken this up with Tidal who said to logout & reboot which didn’t work. I have also carried out a complete new install of myvolumio and opened another account with Tidal however the [EXPLICIT] marking still shows up on everything I stream.
Is there anything further that I should do.
Thanks in advance
shipahoy
I’m also really annoyed by this marking. Appears on whatever I play. Should IMO not appear on anything.
EDIT: I forgot to mention that I also really enjoy the Tidal integration - works great.
Thanks for the feedback. We will investigate and fix if that’s allowed by TIDAL tos :wink:
You asked it, we did it!
The new version (1.029) contains this fix.
We’re almost done with beta testing, thanks guys… Soon MyVolumio will be integrated into regular volumio!
Great work! :slight_smile:
