Hi There
Ive got a reoccurring problem where Im playing hi-res 195 / 24 via tidal from my new rivoplus with lineo5. The first song plays at hi res then volumio switches to 44.1 / 16. Yet Amp shows stream at 195. This happened as playing Joni Mitchel -Hejira and also new album by Bill Callahan - My days of 58. Ive read this as topic from a couple of years ago. Have carried out a couple removals then sign into tidal. Have also re started and re sign into volumio as well. Neither have fixed issue.
Hi Simon, Simon here. I was also confused by this, but if you search further on the forum, you’ll find more recent posts on this very issue. It is known, so hopefully will be fixed at some point. In the meantime, your music is actually playing at the correct bitrate, so you can trust your DAC’s information.
Simon
