Switching from 3 to 4…
Have a reasonable Volumio setup(RPi 4, DACPro HD) and it runs OK on Vol3, but I saw the Vol4 and the new UI, and jumped. All looked good until I tried to play something, then got the ‘could not stream to the selected output device’. Nothing I did would shake Vol4 from that error message, until I thought better of my time and put the Vol3 SD card back into the RPi. Is this just me or is it a known problem?
did you select the proper I2S DAC in the playback options, and then reboot?
Oh yes, any number of times as I did and redid the setup, just to weed out whatever I’d got wrong. I couldn’t find any fault with the settings, so I threw up my hands and put the Vol3 SD card back in. Checked that, and it looked just the same as the Vol4 settings, but it worked and Vol4 didn’t. Stumped, and I’ll wait and watch some more.
Hey @Chris_Mitchell,
I think we (community) do not have enough information about your system, build version, network etc, to help you effectively. We are dealing with a vague excerpt similar to a “Doctor, I sneezed - now I need prescription”.
This is the actual minimum that we, correction - I need, to start looking into problem affecting your system:
If you have premium, try moving playback to Play here and back again. I had a DAC issue fixed this way. Worth a try.
