I have my Raspberry Pi 3 with Volumio connected to the Eleduino 7" touchscreen and I can see the login prompt and actually login fine to the RPi.
I found the touchscreen plugin from the main Volumio menu and was successful in installing it and making it active. However, when I start the RPi, I just get the Volumio login prompt and no GUI. Is there some other step or process that I need to do to get the Volumio GUI to show up on the touchscreen?
Thanks,
Rick
