Support for USB CD player
After a few weeks of beta testing, our NanoSound CD plug-in is now ready released!
Follow instructions here to download and install: https://nanomesher.com/nanosound-cd-support/
The free version has all the playback functions with no upsampling. If you like it and would like to upgrade to upsampling and audio extraction features. Please consider upgrade to the full version https://nanomesher.com/nanosoundcd
Also, We now have our dedicated NanoSound CD topic here
Features:
  • Works with any Audio DAC or internal sound device supported by volumio
  • Works and tested with Raspberry Pi and Asus Tinker board (It should work with other volumio platforms, let us know if you have tested them)
  • CD Playback with up to 4x upsampling (44.1 to 176.4khz)
  • Choice of 4x, 2x and no upsampling for improved audio quality
  • Lossless WAV or FLAC audio extraction with AccurateRip support to ensure extracted files are bit perfect!
  • Auto download and tagging of album info
  • Multi-language support
  • Save to Internal, or NAS or USB drive
  • Fully integrated with Volumio
I’ve gone through some arduous steps to finally getting the plugin to work with some wonderful help from nanosound. After flashing and installing a new sd card in my Allo DigiOne (plug-ins We’re not loading properly with the original card), the CD player/ripper is now working. Now I’m having that similar issue with ripping CDs to usb? It aborts the rip whenever I try to set the path to usb. It will rip to the SD card, but I don’t want to send to there for storage.
Nanosound has yet to respond to this one, can anyone here help?
Hi, thanks for your feedback. We managed to reproduce the issue with saving to USB flash and found a solution. We will release a new version early next week with the fix.
thank you.
Saving to USB has been fixed in latest version of NanoSound CD. Simply enter “USB” in extract to settings.
cheers
