Support for JustBoom Smart Remote
At the moment I was using a Justboom remote control via IR, I also have a “JustBoom Smart Remote” with USB receiver at home, will it be possible to use it with Volumio? e. g. Kodi already works with it.
justboom.co/product/justboom-smart-remote/
Advantage of this remote control is that you don’t need to have a visual contact to the Volumio as it is with IR.
Arrrrrrgh I think you nailed my issue with your question!!!
I am building a kit with Pi3 and Volumio2 and bought the JustBoom Smart Remote, unfortunately it is not working and I was wondering why… I’m so gutted :blush:
Hi, I have the same problem, would a plugin for just remote smartboom be possible ?, thanks …
I’d love too! Haven’t been and to find one yet
Hi, is it not possible to create a plugin for this Justboom smart remote ?, Thanks …
