Super search issues No results and music library empty
I have a Volumio Rivo Plus. When I use the super search it takes about 20 seconds and no results whatever I search. Additionally after the search my music library is empty and I have to restart the Volumio Rivo Plus. I use an external SSD over the USB 3.0 input with about 400gb music files. Is the problem known?
Hey Arminius,
Can you clarify what is that you are seeking help for? Since you are owner of Volumio Rivo Plus - you have already created support ticket and the outcome is not satisfactory?
Can you paste the ticket number that @DED can assess please?
Hey Nerd,
Thanks I don’t know that’s the way over the support ticket. I will create one later.
I currently have the Rivo+ and get the same results. However, if you had a music service such as Tidal or Qobuz super search works fine except local music is not included in the results. I had the same issue on the Primo. I created a ticket last year and just recently cancelled it.
I have the feeling Volumio support is very bad. A device for 1299€ and you get no reply, no help, umbelievable bad!
Hi Arminius,
I received your two tickets early this morning
https://volumio.atlassian.net/browse/GDSC-3802
https://volumio.atlassian.net/browse/GDSC-3803
and wanted to let you know that I have a queue of emails to address. Please be patient, I’ll make sure you receive premium support as soon as possible today.
Thanks for your understanding!
Best regards,
Volumio Support
