Super fast audio
I had to re-image my PI4 running Volumio. Ever since audio plays super fast. I’m guessing I don’t have my DAC setup properly. I’m using a Raspberry Pi HiFi DAC HAT PCM5122. I have it setup as “HiFiBerry DAC Plus”. I’ve tried a few other options with the same results. I’ve tried Volumio versions 2.917 and 3.512.
Any recommendations would be appreciated!
forget 2.917…
what is your sources for music?
try to enable resampling
reimaged with 3.512. I tried enabling resampling, same issue. I’m just trying to play webradio.
Found the correct DAC driver. Thanks for your help!
