Strange behaviour after update to v3.39x
I have two players in different rooms. Updated both recently from v3.233 on different days, updated one to v3.396 dated 4 Dec, 2022, waited for a few days to see everything worked OK and then updated the next one, which went to v3.398 dated 7 Dec, 2022. Here’s the strange behavior:
  • I can no longer use the “Switch device”image button in the Manifest interface to control either device as neither can find the other device. This worked fine in the earlier versions and is not a big deal as I only have two players and I can open another browser window or use the iOs/android apps where both are visible but I was curious if anyone else is seeing this behavior. Incidentally “Switch device” doesn’t work on the apps either.
  • The player on v3.396 cannot be updated to v3.398. It says that there are “No updates available”. Again not a big deal, as I believe any changes will be incremental and there is another update waiting to go to beta release, just curious why.
Regards,
Hi, you’re testing development updates.
I suggest to disable test mode and not update to those dev updates, since we are experimenting with some new functionalities.
Thanks for your report anyway.
:+1:t4:
