I have spotify addons 1.3.5 and volumio spotify connect 2 installed.
I Try to play from volumio gui on my phone or pc there is an Icon for spotify but it wont play anything. Selections are there. Is there another way to access spotify?
Probably a silly question - but you did properly enter your credentials and set up things from the plugin menu?
Also, for better help, create a log and share - volumio.github.io/docs/User_Man … oting.html
I have the problem solved.There was an issue with my acct.I did not know until I tried from another computer which provided more info on the problem than the spotify plugin did on the volumio interface.
Anyway thank you to ALL that helped me get this working.Volumio ROCK ON!
