Simple question - does the Spotify plugin work with the latest version?
I can’t get it to work - should it?
Thanks,
Thanks,
Which Spotify plugin? Simple answer: yes (all Spotify plugins seem to work for me).
Thanks for the reply - I am trying to get the plug-in that appears in the Plug-in menu working.
So far without success - If it should work I will keep trying.
I am using RPi0w and a justBoom DAC, everything else works wonderfully just can’t get Spotify to work.
I can get spotify using Kodi and the Kodi plugin on another RPi, just can’t get it to work with Volumio.
Probably there is something wrong with that plugin, I also have problem with it, my problem is that the spotify thing in volumio doesnt get access to
the spotify server.
( I also have som problem with the built in volumio webradio channels)
The Plug in is working for me, also the Spotify Connect app (separate download zipfile and upload as App needed) works perfect. After setting Spotify’s user name and password in the Volumio menu, there will be a slider where you can set the App On or Off. Only works with a paid Spotify account.account!!!)
