Spotify not working for the last month
Been using Volumio with the Spotify plugin (ver 1.3.5) for quite a while now and it’s been flawless up until around a month ago, The problem is I’m logged in and can select genres etc. down to album level but from that point selecting anything in the menu provides no response. I’ve updated twice since the problem started and am now on the latest Volumio version (2.565) but the problem remains.
Everything works as expected if I log-in and play tracks on the Spotify website.
Thanks in advance for any help provided…
Hi There, Spotify made some non-backward compatible changes to their playlist API a few weeks ago. To get Spotify working properly again look at this thread, viewing the most recent messages first, and you’ll see how you can update your Spotify plugin’s index.js file. If you are not familiar with using Linux command line tools you’ll want to find a friend who can do this for you.
can-use-spotify-volumio-t11966.html
An updated plugin should be part of an upcoming Volumio release in the next few weeks.
Thanks for taking the time to reply, Because of the Spotify problem I’ve started using BubbleUPnP with Tidal and Volumio as renderer, it works great so I’m not going to take the risk of breaking my setup…Think I’ll wait until the updated plugin is released.
Thanks again.
