I ran the update to 2.361 and the icon for the Spotify (addon) disappeared from the browse window.
I reset user settings and installed the addin again - still no Spotify icon.
I reimaged the card on my RPi with the latest version and, after successfully installing the addon its still not there.
The install of the addin appears to go fine and it shows as installed and active and I have installed the correct user details for Spotify.
Edit: Reverted to 2.348 and it works properly again. (Its almost as if Spotify addon is not being énabled in 2.361 even though it says its enabled)
I’m new with Volumio. I tried to install the Spotify Plugin. When i look for the installed Plugins, the Spotify Plugin is marked as installed and active.
Credentials OK.
But the Spotify Icon is not visible.
Second try with the Volumio Image 2.348: same problems
Something changed in the Implementation of the Plugin?
Edit----- After upgrade my Spotify Account to Premium — Plugin Works.
Wouldn’t be better to show a disabled Spotify Icon with a Hint, that a Premium Account is needed?
