My device is a Volumio Mini86 with System Version 2.368 and Spotify plugin for Volumio2 Updated: 18-2-2018.
After activating the plugin, Volumio does not appear in the list of Spotify Connect devices on my iMac (Spotify 1.0.74.380.g1fcff12a) or my iPhone. Previously, it worked if I configured my email address in the plugin settings (but not my Spotify username). AirPlay still streams as expected.
In case it is helpful, here is the log after activating the plugin. Thank you for looking into it.
Feb 22 01:34:41 volumio volumio[833]: info: Enabling plugin spop
Feb 22 01:34:41 volumio volumio[833]: info: Loading plugin “spop”…
Feb 22 01:34:41 volumio volumio[833]: info: Applying required configuration parameters for plugin spop
Feb 22 01:34:41 volumio volumio[833]: info: PLUGIN START: spop
Feb 22 01:34:41 volumio sudo[23803]: volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/bin/systemctl start spop.service
Feb 22 01:34:41 volumio sudo[23803]: pam_unix(sudo:session): session opened for user root by (uid=0)
Feb 22 01:34:42 volumio systemd[1]: Configuration file /lib/systemd/system/spop.service is marked executable. Please remove executable permission bits. Proceeding anyway.
Feb 22 01:34:42 volumio systemd[1]: Starting Spotify Daemon…
Feb 22 01:34:42 volumio systemd[1]: Started Spotify Daemon.
Feb 22 01:34:42 volumio sudo[23803]: pam_unix(sudo:session): session closed for user root
Feb 22 01:34:42 volumio volumio[833]: info: SpopD Daemon Started
Feb 22 01:34:42 volumio volumio[23805]: 2018-02-22 01:34:42 [SPTF] 01:34:42.204 I [ap:1752] Connecting to AP ap.spotify.com:4070
Feb 22 01:34:42 volumio volumio[23805]: 2018-02-22 01:34:42 [SPTF] 01:34:42.220 I [offline-mgr:2084] Storage has been cleaned
Feb 22 01:34:42 volumio volumio[23805]: 2018-02-22 01:34:42 [SPTF] 01:34:42.280 I [ap:1226] Connected to AP: 104.154.127.218:4070
Feb 22 01:34:42 volumio volumio[23805]: 2018-02-22 01:34:42 [SPTF] 01:34:42.927 E [ap:4172] ChannelError(1, 1, link-tracks)
Feb 22 01:34:43 volumio volumio[23805]: 2018-02-22 01:34:43 [SPTF] 01:34:43.163 E [ap:4172] ChannelError(1, 1, link-tracks)
Feb 22 01:34:43 volumio volumio[23805]: 2018-02-22 01:34:43 [SPTF] 01:34:43.256 E [ap:4172] ChannelError(1, 1, link-tracks)
Feb 22 01:34:43 volumio volumio[23805]: 2018-02-22 01:34:43 [SPTF] 01:34:43.282 E [ap:4172] ChannelError(17, 1, playlist)
Feb 22 01:34:43 volumio volumio[23805]: 2018-02-22 01:34:43 [SPTF] 01:34:43.282 E [ap:4172] ChannelError(16, 1, playlist)
Feb 22 01:34:43 volumio volumio[23805]: 2018-02-22 01:34:43 [SPTF] 01:34:43.282 E [ap:4172] ChannelError(18, 1, playlist)
Feb 22 01:34:43 volumio volumio[23805]: 2018-02-22 01:34:43 [SPTF] 01:34:43.351 E [ap:4172] ChannelError(1, 1, link-tracks)
Feb 22 01:34:46 volumio volumio[23805]: 2018-02-22 01:34:46 [SPTF] 01:34:46.415 E [ap:4172] ChannelError(3, 0, playlist)
Feb 22 01:34:46 volumio volumio[23805]: 2018-02-22 01:34:46 [SPTF] 01:34:46.463 E [ap:4172] ChannelError(2, 0, playlist)
Feb 22 01:34:47 volumio volumio[833]: info: Connecting to daemon
Feb 22 01:34:47 volumio volumio[833]: info: CoreCommandRouter::volumioAddToBrowseSources[object Object]
Feb 22 01:34:47 volumio volumio[833]: info: [1519263287012] CoreMusicLibrary::Adding element Spotify
Feb 22 01:34:47 volumio volumio[833]: info: Done.
Feb 22 01:34:47 volumio volumio[833]: info: FIRST BRANCH
Feb 22 01:34:47 volumio volumio[833]: info: Spotify access token expires at 1519266887010
Feb 22 01:34:47 volumio volumio[833]: info: Spotify access token is BQBSq_lysAWMUCQcH0Jv7SA1mDDdPpIlve4mDOt667VLuCneDk9iVPk_5wlcad3o3SOtjHBhSlYBhtn81r0
Feb 22 01:34:47 volumio volumio[833]: info: Spotify credentials grant success
Feb 22 01:34:51 volumio volumio[23805]: 2018-02-22 01:34:51 [SPTF] 01:34:51.525 E [ap:4172] ChannelError(1, 1, playlist)
Feb 22 01:34:55 volumio volumio[23805]: 2018-02-22 01:34:55 [SPTF] 01:34:55.548 E [ap:4172] ChannelError(0, 1, playlist)
Feb 22 01:34:55 volumio volumio[23805]: 2018-02-22 01:34:55 [SPTF] 01:34:55.766 E [ap:4172] ChannelError(2, 1, playlist)
Feb 22 01:35:10 volumio volumio[23805]: 2018-02-22 01:35:10 [SPTF] 01:35:10.836 E [ap:4172] ChannelError(1, 1, playlist)
Feb 22 01:35:10 volumio volumio[23805]: 2018-02-22 01:35:10 [SPTF] 01:35:10.836 E [ap:4172] ChannelError(0, 1, playlist)
Feb 22 01:35:15 volumio volumio[23805]: 2018-02-22 01:35:15 [SPTF] 01:35:15.897 E [ap:4172] ChannelError(0, 1, playlist)
Feb 22 01:35:35 volumio volumio[23805]: 2018-02-22 01:35:35 [SPTF] 01:35:35.968 E [ap:4172] ChannelError(0, 1, playlist)
Feb 22 01:35:51 volumio volumio[23805]: 2018-02-22 01:35:51 [SPTF] 01:35:51.075 E [ap:4172] ChannelError(0, 1, playlist)
Feb 22 01:35:56 volumio volumio[23805]: 2018-02-22 01:35:56 [SPTF] 01:35:56.137 E [ap:4172] ChannelError(0, 1, playlist)
Feb 22 01:36:50 volumio volumio[23805]: 2018-02-22 01:36:50 [SPTF] 01:36:50.027 E [ap:4172] ChannelError(0, 1, playlist)
Feb 22 01:36:50 volumio volumio[23805]: 2018-02-22 01:36:50 [SPTF] 01:36:50.090 E [ap:4172] ChannelError(0, 1, playlist)
Feb 22 01:36:57 volumio volumio[23805]: 2018-02-22 01:36:57 [SPTF] 01:36:57.447 E [ap:4172] ChannelError(0, 1, playlist)
Feb 22 01:38:32 volumio volumio[23805]: 2018-02-22 01:38:32 [SPTF] 01:38:32.555 E [ap:4172] ChannelError(0, 1, playlist)
Feb 22 01:38:32 volumio volumio[23805]: 2018-02-22 01:38:32 [SPTF] 01:38:32.555 E [ap:4172] ChannelError(1, 1, playlist)
Feb 22 01:38:37 volumio volumio[23805]: 2018-02-22 01:38:37 [SPTF] 01:38:37.699 E [ap:4172] ChannelError(0, 1, playlist)
Feb 22 01:42:03 volumio volumio[23805]: 2018-02-22 01:42:03 [SPTF] 01:42:03.012 E [ap:4172] ChannelError(0, 1, playlist)
Feb 22 01:42:28 volumio volumio[23805]: 2018-02-22 01:42:28 [SPTF] 01:42:28.116 E [ap:4172] ChannelError(0, 1, playlist)
Feb 22 01:42:48 volumio volumio[23805]: 2018-02-22 01:42:48 [SPTF] 01:42:48.178 E [ap:4172] ChannelError(0, 1, playlist)
Feb 22 01:47:24 volumio volumio[833]: info: CoreCommandRouter::getUIConfigOnPlugin
Feb 22 01:47:24 volumio volumio[833]: info: CoreCommandRouter::executeOnPlugin: appearance , getConfigParam
Feb 22 01:47:24 volumio volumio[833]: info: Received Get System Version
Feb 22 01:47:24 volumio volumio[833]: info: CoreCommandRouter::executeOnPlugin: system , getSystemVersion
Feb 22 01:50:58 volumio volumio[23805]: 2018-02-22 01:50:58 [SPTF] 01:50:58.190 E [ap:4172] ChannelError(0, 1, playlist)
Feb 22 01:51:13 volumio volumio[23805]: 2018-02-22 01:51:13 [SPTF] 01:51:13.251 E [ap:4172] ChannelError(0, 1, playlist)
Feb 22 01:51:23 volumio volumio[23805]: 2018-02-22 01:51:23 [SPTF] 01:51:23.310 E [ap:4172] ChannelError(0, 1, playlist)
Feb 22 01:53:43 volumio volumio[833]: info: CoreCommandRouter::volumioGetState
Feb 22 01:53:43 volumio volumio[833]: info: CoreStateMachine::getState
Feb 22 01:53:43 volumio volumio[833]: info: CorePlayQueue::getTrack 0
Feb 22 01:53:44 volumio volumio[833]: info: CoreCommandRouter::executeOnPlugin: appearance , getUiSettings
Feb 22 01:53:44 volumio volumio[833]: info: CoreCommandRouter::executeOnPlugin: wizard , getShowWizard
Feb 22 01:53:44 volumio volumio[833]: info: CoreCommandRouter::executeOnPlugin: system , getShowWizard
Feb 22 01:53:44 volumio volumio[833]: info: CoreCommandRouter::executeOnPlugin: multiroom , getMultiroom
Feb 22 01:53:44 volumio volumio[833]: Plugin multiroom or method getMultiroom not found
Feb 22 01:53:44 volumio volumio[833]: info: Listing playlists
Feb 22 01:54:14 volumio volumio[833]: info: CoreCommandRouter::getUIConfigOnPlugin
Feb 22 01:54:14 volumio volumio[833]: info: CoreCommandRouter::executeOnPlugin: appearance , getConfigParam
Feb 22 01:54:15 volumio volumio[833]: info: Received Get System Version
Feb 22 01:54:15 volumio volumio[833]: info: CoreCommandRouter::executeOnPlugin: system , getSystemVersion
Feb 22 01:54:20 volumio volumio[833]: info: [{“prettyName”:“Spotify”,“name”:“spop”,“category”:“music_service”,“version”:“1.3.5”,“icon”:“fa-spotify”,“enabled”:true,“active”:true}]
Feb 22 02:01:01 volumio volumio[833]: info: Following Redirect to: volumio.github.io/volumio-plugin … ugins.json
Feb 22 02:01:08 volumio volumio[833]: info: CoreCommandRouter::getUIConfigOnPlugin
Feb 22 02:04:58 volumio volumio[23805]: 2018-02-22 02:04:58 [SPTF] 02:04:58.639 E [ap:4172] ChannelError(0, 1, playlist)
