Spotify and webradio
Hello
I`m pretty new at this so now I need your help,
I have problem to play spotify and webradio @ RPI3, Suptronic X920 DAC and Volumio v2.348
The first day I started up my raspberry pi3 with suptronic dac x920 i had no problems at all, I install the spotify plugin, and it works
I add spotify songs and song from my plexmediaserver, I also played some radiochannels,
but the day after spotify stopt working, I can see the
directorys in webUi and android app same in webradio I can see the webradio directory but when I choose one, nothing happens, and it seems to that my raspberry pi locks for couple of second or is the app, same thing happens when i access webUI from computer, nothings happen.
But play files from my plexmediaserver works like a charm, one more thing, when I try to login from ssh into my pi I can be logged in for like 15 seconds
then the PI throw me out.
So wich logs do you need, ? and yes I have tried to boot my rpi3 several times.
If it’s reproducible behaviour you could ssh in and run ‘sudo journalctl -f’ before the problem occurs, and leave it running until after the problem has happened. Check the log for anything suspicious.
Ok, thanks I will try, and beg for I can stay inside ssh without been kicked out.
It would be better if you could actually capture the problem occurring in the system logs as explained above, but failing this you could report the entire log volumio.github.io/docs/User_Man … oting.html AFTER the problem has occurred. Do a reboot before trying this.
I try this tonight, maybe it not happens anymore cos after my first post i did a factory reset in volumio so I just have to put my Rpi back online again,
ps I have it connected to WIFI not cable.
okey now lets see at timestamp Jan 31 19:54:31 musikpaj volumio[1048]: info: No input data: I tried to fetch webradio and after that
I also try to play from spotify, the thing is now i can see tracks in my own favourite list, but as you can see the spotify api gives just errors back
I have checked my username and password for spotify and that is correct.
In this log i also played som music from my plexmediaserver, why the rpi looked for available networks in the middle of the log I dont know.
I can also tell that the rpi3 is very close to my router and has full strength in wifi.
Jan 31 19:54:42 musikpaj volumio[1048]: info: CoreCommandRouter::executeOnPlugin: webradio , handleBrowseUri
Jan 31 19:54:46 musikpaj volumio[1048]: info: CoreCommandRouter::executeOnPlugin: webradio , handleBrowseUri
Jan 31 19:54:46 musikpaj volumio[1048]: info: Getting webradio selection
Jan 31 19:56:17 musikpaj volumio[1048]: info: CoreCommandRouter::volumioGetState
Jan 31 19:56:17 musikpaj volumio[1048]: info: [1517428577396] CoreStateMachine::getState
Jan 31 19:56:17 musikpaj volumio[1048]: info: [1517428577396] CorePlayQueue::getTrack 0
Jan 31 19:56:17 musikpaj volumio[1048]: [1517428577396] ---------------------------- Client requests Volumio state
Jan 31 19:56:17 musikpaj volumio[1048]: info: [1517428577398] InterfaceWebUI::pushState
Jan 31 19:56:17 musikpaj volumio[1048]: info: [1517428577400] ------------------------------ 5ms
Jan 31 19:56:19 musikpaj volumio[1048]: info:
Jan 31 19:56:19 musikpaj volumio[1048]: [1517428579218] ---------------------------- Client requests Menu Items
Jan 31 19:56:19 musikpaj volumio[1048]: info: [1517428579233] ------------------------------ 15ms
Jan 31 19:56:19 musikpaj volumio[1048]: info: CoreCommandRouter::executeOnPlugin: multiroom , getMultiroom
Jan 31 19:56:19 musikpaj volumio[1048]: Plugin multiroom or method getMultiroom not found
Jan 31 19:56:19 musikpaj volumio[1048]: info: [1517428579240] Listing playlists
Jan 31 19:56:19 musikpaj volumio[1048]: info: CoreCommandRouter::volumioGetBrowseSources
Jan 31 19:56:19 musikpaj volumio[1048]: info: CoreCommandRouter::volumioGetQueue
Jan 31 19:56:19 musikpaj volumio[1048]: info: [1517428579251] CoreStateMachine::getQueue
Jan 31 19:56:19 musikpaj volumio[1048]: info: [1517428579251] CorePlayQueue::getQueue
Jan 31 19:56:19 musikpaj volumio[1048]: [1517428579251] ---------------------------- Client requests Volumio queue
Jan 31 19:56:19 musikpaj volumio[1048]: info: [1517428579252] InterfaceWebUI::pushQueue
Jan 31 19:56:19 musikpaj volumio[1048]: info: [1517428579255] ------------------------------ 5ms
Jan 31 19:56:19 musikpaj volumio[1048]: [1517428579258] ---------------------------- Client requests Menu Items
Jan 31 19:56:19 musikpaj volumio[1048]: [1517428579261] ---------------------------- Client requests Menu Items
Jan 31 19:56:19 musikpaj volumio[1048]: info: [1517428579272] ------------------------------ 14ms
Jan 31 19:56:19 musikpaj volumio[1048]: info: [1517428579286] ------------------------------ 25ms
Jan 31 19:56:22 musikpaj volumio[1106]: 2018-01-31 19:56:22 [SPTF] 19:56:22.479 I [ap:1752] Connecting to AP ap.spotify.com:4070
Jan 31 19:56:27 musikpaj volumio[1106]: 2018-01-31 19:56:27 [SPTF] 19:56:27.485 E [ap:1694] AP Socket Error: Timeout reached (20000)
Jan 31 19:56:27 musikpaj volumio[1106]: 2018-01-31 19:56:27 [SPTF] 19:56:27.485 E [ap:3953] Connection error:  117
Jan 31 19:56:27 musikpaj volumio[1106]: 2018-01-31 19:56:27 [WARN] Connection error: Cannot connect to Spotify
Jan 31 19:56:45 musikpaj volumio[1048]: info: CoreCommandRouter::executeOnPlugin: webradio , handleBrowseUri
Jan 31 19:56:49 musikpaj volumio[1048]: info: CoreCommandRouter::executeOnPlugin: webradio , handleBrowseUri
Jan 31 19:57:24 musikpaj volumio[1048]: info: CoreCommandRouter::executeOnPlugin: webradio , handleBrowseUri
Jan 31 19:57:46 musikpaj volumio[1048]: (node:1048) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 8): Error
Jan 31 19:57:46 musikpaj volumio[1048]: (node:1048) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 9): Error
Jan 31 19:57:53 musikpaj volumio[1048]: info: CoreCommandRouter::volumioGetState
Jan 31 19:57:53 musikpaj volumio[1048]: info: [1517428673741] CoreStateMachine::getState
Jan 31 19:57:53 musikpaj volumio[1048]: info: [1517428673741] CorePlayQueue::getTrack 0
Jan 31 19:57:53 musikpaj volumio[1048]: [1517428673741] ---------------------------- Client requests Volumio state
Jan 31 19:57:53 musikpaj volumio[1048]: info: [1517428673742] InterfaceWebUI::pushState
Jan 31 19:57:53 musikpaj volumio[1048]: info: [1517428673744] ------------------------------ 4ms
Jan 31 19:57:55 musikpaj volumio[1048]: info:
Jan 31 19:57:55 musikpaj volumio[1048]: [1517428675504] ---------------------------- Client requests Menu Items
Jan 31 19:57:55 musikpaj volumio[1048]: info: [1517428675520] ------------------------------ 16ms
Jan 31 19:57:55 musikpaj volumio[1048]: info: CoreCommandRouter::executeOnPlugin: multiroom , getMultiroom
Jan 31 19:57:55 musikpaj volumio[1048]: Plugin multiroom or method getMultiroom not found
Jan 31 19:57:55 musikpaj volumio[1048]: info: [1517428675530] Listing playlists
Jan 31 19:57:55 musikpaj volumio[1048]: info: CoreCommandRouter::volumioGetBrowseSources
Jan 31 19:57:55 musikpaj volumio[1048]: info: CoreCommandRouter::volumioGetQueue
Jan 31 19:57:55 musikpaj volumio[1048]: info: [1517428675540] CoreStateMachine::getQueue
Jan 31 19:57:55 musikpaj volumio[1048]: info: [1517428675540] CorePlayQueue::getQueue
Jan 31 19:57:55 musikpaj volumio[1048]: [1517428675541] ---------------------------- Client requests Volumio queue
Jan 31 19:57:55 musikpaj volumio[1048]: info: [1517428675542] InterfaceWebUI::pushQueue
Jan 31 19:57:55 musikpaj volumio[1048]: info: [1517428675543] ------------------------------ 4ms
Jan 31 19:57:55 musikpaj volumio[1048]: [1517428675546] ---------------------------- Client requests Menu Items
Jan 31 19:57:55 musikpaj volumio[1048]: [1517428675549] ---------------------------- Client requests Menu Items
Jan 31 19:57:55 musikpaj volumio[1048]: info: [1517428675562] ------------------------------ 16ms
Jan 31 19:57:55 musikpaj volumio[1048]: info: [1517428675572] ------------------------------ 23ms
Jan 31 19:58:18 musikpaj volumio[1048]: info: CoreCommandRouter::executeOnPlugin: upnp_browser , handleBrowseUri
Jan 31 19:58:23 musikpaj volumio[1048]: info: CoreCommandRouter::executeOnPlugin: upnp_browser , handleBrowseUri
Jan 31 19:58:23 musikpaj volumio[1048]: info: No input data
Jan 31 19:58:26 musikpaj volumio[1048]: info: CoreCommandRouter::executeOnPlugin: upnp_browser , handleBrowseUri
Jan 31 19:58:26 musikpaj volumio[1048]: info: No input data
Jan 31 19:58:29 musikpaj volumio[1048]: info: CoreCommandRouter::executeOnPlugin: upnp_browser , handleBrowseUri
Jan 31 19:58:31 musikpaj volumio[1048]: info: CoreCommandRouter::executeOnPlugin: upnp_browser , handleBrowseUri
Jan 31 19:58:36 musikpaj volumio[1048]: info: CoreCommandRouter::executeOnPlugin: upnp_browser , handleBrowseUri
Jan 31 19:58:36 musikpaj volumio[1048]: info: No input data
Jan 31 19:58:41 musikpaj volumio[1048]: info: CoreCommandRouter::executeOnPlugin: upnp_browser , handleBrowseUri
Jan 31 19:58:46 musikpaj volumio[1048]: info: CoreCommandRouter::volumioAddQueueItems
Jan 31 19:58:46 musikpaj volumio[1048]: info: [1517428726174] CoreStateMachine::addQueueItems
Jan 31 19:58:46 musikpaj volumio[1048]: info: [1517428726175] CorePlayQueue::addQueueItems
Jan 31 19:58:46 musikpaj volumio[1048]: info: Adding Item to queue: upnp/http://192.168.8.105:32469/ContentDirectory/b6d69b83-876f-c05a-7c9b-57b0c7858485/control.xml@03a3a47084b5ca424c08
Jan 31 19:58:46 musikpaj volumio[1048]: info: Exploding uri upnp/http://192.168.8.105:32469/ContentDirectory/b6d69b83-876f-c05a-7c9b-57b0c7858485/control.xml@03a3a47084b5ca424c08 in service upnp_browser
Jan 31 19:58:46 musikpaj volumio[1048]: info: [1517428726244] CorePlayQueue::saveQueue
Jan 31 19:58:46 musikpaj volumio[1048]: info: CoreCommandRouter::volumioPushQueue
Jan 31 19:58:46 musikpaj volumio[1048]: info: [1517428726251] interfaceApi::pushQueue
Jan 31 19:58:46 musikpaj volumio[1048]: info: [1517428726252] InterfaceWebUI::pushQueue
Jan 31 19:58:46 musikpaj volumio[1048]: info: [1517428726256] CoreStateMachine::updateTrackBlock
Jan 31 19:58:46 musikpaj volumio[1048]: info: [1517428726258] CorePlayQueue::getTrackBlock
Jan 31 19:58:46 musikpaj volumio[1048]: info: CoreCommandRouter::volumioPlay
Jan 31 19:58:46 musikpaj volumio[1048]: UNSET VOLATILE
Jan 31 19:58:46 musikpaj volumio[1048]: info: [1517428726262] CoreStateMachine::play index 1
Jan 31 19:58:46 musikpaj volumio[1048]: info: [1517428726264] CoreStateMachine::setConsumeUpdateService undefined
Jan 31 19:58:46 musikpaj volumio[1048]: info: [1517428726267] CoreStateMachine::stop
Jan 31 19:58:46 musikpaj volumio[1048]: info: [1517428726267] CoreStateMachine::setConsumeUpdateService undefined
Jan 31 19:58:46 musikpaj volumio[1048]: info: [1517428726269] CoreStateMachine::play index undefined
Jan 31 19:58:46 musikpaj volumio[1048]: info: [1517428726270] CoreStateMachine::setConsumeUpdateService undefined
Jan 31 19:58:46 musikpaj volumio[1048]: info: [1517428726271] CorePlayQueue::getTrack 1
Jan 31 19:58:46 musikpaj volumio[1048]: info: [1517428726272] CoreStateMachine::startPlaybackTimer
Jan 31 19:58:46 musikpaj volumio[1048]: info: [1517428726273] CorePlayQueue::getTrack 1
Jan 31 19:58:46 musikpaj volumio[1048]: info: [1517428726275] ControllerUPNPBrowser::clearAddPlayTrack
Jan 31 19:58:46 musikpaj volumio[1048]: info: [1517428726277] ControllerMpd::sendMpdCommand stop
Jan 31 19:58:46 musikpaj volumio[1048]: info: [1517428726284] sending command...
Jan 31 19:58:46 musikpaj volumio[1048]: info: [1517428726294] parsing response...
Jan 31 19:58:46 musikpaj volumio[1048]: info: [1517428726296] ControllerMpd::sendMpdCommand clear
Jan 31 19:58:46 musikpaj volumio[1048]: info: [1517428726297] sending command...
Jan 31 19:58:46 musikpaj volumio[1048]: [1517428726301] ---------------------------- MPD announces system playlist update
Jan 31 19:58:46 musikpaj volumio[1048]: info: Ignoring MPD Status Update
Jan 31 19:58:46 musikpaj volumio[1048]: info: [1517428726305] parsing response...
Jan 31 19:58:46 musikpaj volumio[1048]: info: [1517428726306] ControllerMpd::sendMpdCommand load "http://192.168.8.105:32469/object/03a3a47084b5ca424c08/file.mp3"
Jan 31 19:58:46 musikpaj volumio[1048]: info: [1517428726309] sending command...
Jan 31 19:58:46 musikpaj volumio[1048]: info: [1517428726314] ------------------------------ 13ms
Jan 31 19:58:50 musikpaj volumio[1106]: 2018-01-31 19:58:50 [SPTF] 19:58:50.501 I [ap:1752] Connecting to AP ap.spotify.com:443
Jan 31 19:58:54 musikpaj volumio[1048]: info: [1517428734108] ControllerMpd::sendMpdCommand add "http://192.168.8.105:32469/object/03a3a47084b5ca424c08/file.mp3"
Jan 31 19:58:54 musikpaj volumio[1048]: info: [1517428734109] sending command...
Jan 31 19:58:54 musikpaj volumio[1048]: [1517428734113] ---------------------------- MPD announces system playlist update
Jan 31 19:58:54 musikpaj volumio[1048]: info: Ignoring MPD Status Update
Jan 31 19:58:54 musikpaj volumio[1048]: info: [1517428734115] parsing response...
Jan 31 19:58:54 musikpaj volumio[1048]: info: [1517428734116] CoreStateMachine::setConsumeUpdateService mpd
Jan 31 19:58:54 musikpaj volumio[1048]: info: [1517428734117] ControllerMpd::sendMpdCommand play
Jan 31 19:58:54 musikpaj volumio[1048]: info: [1517428734118] sending command...
Jan 31 19:58:54 musikpaj volumio[1048]: info: [1517428734130] ------------------------------ 17ms
Jan 31 19:58:54 musikpaj volumio[1048]: info: [1517428734131] parsing response...
Jan 31 19:58:54 musikpaj volumio[1048]: [1517428734245] ---------------------------- MPD announces state update: player
Jan 31 19:58:54 musikpaj kernel: pcm512x 1-004c: No SCLK, using BCLK: -2
Jan 31 19:58:54 musikpaj volumio[1048]: info: [1517428734249] ControllerMpd::getState
Jan 31 19:58:54 musikpaj volumio[1048]: info: [1517428734250] ControllerMpd::sendMpdCommand status
Jan 31 19:58:54 musikpaj volumio[1048]: info: [1517428734251] sending command...
Jan 31 19:58:54 musikpaj volumio[1048]: [1517428734253] ---------------------------- MPD announces state update: player
Jan 31 19:58:54 musikpaj volumio[1048]: info: [1517428734254] ControllerMpd::getState
Jan 31 19:58:54 musikpaj volumio[1048]: info: [1517428734255] ControllerMpd::sendMpdCommand status
Jan 31 19:58:54 musikpaj volumio[1048]: info: [1517428734256] parsing response...
Jan 31 19:58:54 musikpaj volumio[1048]: info: [1517428734258] sending command...
Jan 31 19:58:54 musikpaj volumio[1048]: info: [1517428734261] ControllerMpd::parseState
Jan 31 19:58:54 musikpaj volumio[1048]: info: [1517428734263] ControllerMpd::sendMpdCommand playlistinfo
Jan 31 19:58:54 musikpaj volumio[1048]: info: [1517428734264] sending command...
Jan 31 19:58:54 musikpaj volumio[1048]: info: [1517428734267] parsing response...
Jan 31 19:58:54 musikpaj volumio[1048]: info: [1517428734268] parsing response...
Jan 31 19:58:54 musikpaj volumio[1048]: info: [1517428734269] ControllerMpd::parseState
Jan 31 19:58:54 musikpaj volumio[1048]: info: [1517428734270] ControllerMpd::sendMpdCommand playlistinfo
Jan 31 19:58:54 musikpaj volumio[1048]: info: [1517428734272] ControllerMpd::parseTrackInfo
Jan 31 19:58:54 musikpaj volumio[1048]: info: [1517428734274] sending command...
Jan 31 19:58:54 musikpaj volumio[1048]: info: [1517428734276] ControllerMpd::pushState
Jan 31 19:58:54 musikpaj volumio[1048]: info: CoreCommandRouter::servicePushState
Jan 31 19:58:54 musikpaj volumio[1048]: info: [1517428734286] CoreStateMachine::syncState
Jan 31 19:58:54 musikpaj volumio[1048]: info: [1517428734287] CorePlayQueue::getTrack 1
Jan 31 19:58:54 musikpaj volumio[1048]: info: STATE SERVICE {"status":"play","position":0,"seek":487,"duration":482,"samplerate":"44.1 KHz","bitdepth":"24 bit","channels":2,"random":false,"updatedb":false,"repeat":false,"isStreaming":false,"title":"file.mp3","artist":null,"album":null,"uri":"http://192.168.8.105:32469/object/03a3a47084b5ca424c08/file.mp3","trackType":"mp3"}
Jan 31 19:58:54 musikpaj volumio[1048]: info: CURRENT POSITION 1
Jan 31 19:58:54 musikpaj volumio[1048]: info: [1517428734289] CoreStateMachine::syncState   stateService play
Jan 31 19:58:54 musikpaj volumio[1048]: info: [1517428734290] CoreStateMachine::syncState   currentStatus stop
Jan 31 19:58:54 musikpaj volumio[1048]: info: [1517428734292] CoreStateMachine::pushState
Jan 31 19:58:54 musikpaj volumio[1048]: info: [1517428734293] CoreStateMachine::getState
Jan 31 19:58:54 musikpaj volumio[1048]: info: CoreCommandRouter::volumioPushState
Jan 31 19:58:54 musikpaj volumio[1048]: info: CoreCommandRouter::executeOnPlugin: volumiodiscovery , saveDeviceInfo
Jan 31 19:58:54 musikpaj volumio[1048]: info: [1517428734304] interfaceApi::pushState
Jan 31 19:58:54 musikpaj volumio[1048]: info: [1517428734305] InterfaceWebUI::pushState
Jan 31 19:58:54 musikpaj volumio[1048]: info: [1517428734314] ------------------------------ 69ms
Jan 31 19:58:54 musikpaj volumio[1048]: info: Pushing Favourites {"service":"mpd","favourite":false}
Jan 31 19:58:54 musikpaj volumio[1048]: info: [1517428734322] parsing response...
Jan 31 19:58:54 musikpaj volumio[1048]: info: [1517428734323] ControllerMpd::parseTrackInfo
Jan 31 19:58:54 musikpaj volumio[1048]: info: [1517428734324] ControllerMpd::pushState
Jan 31 19:58:54 musikpaj volumio[1048]: info: [1517428734326] CoreStateMachine::syncState
Jan 31 19:58:54 musikpaj volumio[1048]: info: [1517428734327] CorePlayQueue::getTrack 1
Jan 31 19:58:54 musikpaj volumio[1048]: info: [1517428734330] CoreStateMachine::syncState   stateService play
Jan 31 19:58:54 musikpaj volumio[1048]: info: [1517428734330] CoreStateMachine::syncState   currentStatus play
Jan 31 19:58:54 musikpaj volumio[1048]: info: [1517428734331] Received an update from plaugin. extracting info from payload
Jan 31 19:58:54 musikpaj volumio[1048]: info: [1517428734332] CoreStateMachine::pushState
Jan 31 19:58:54 musikpaj volumio[1048]: info: [1517428734333] CoreStateMachine::getState
Jan 31 19:58:54 musikpaj volumio[1048]: info: [1517428734336] interfaceApi::pushState
Jan 31 19:58:54 musikpaj volumio[1048]: info: [1517428734337] InterfaceWebUI::pushState
Jan 31 19:58:54 musikpaj volumio[1048]: info: [1517428734342] CoreStateMachine::pushState
Jan 31 19:58:54 musikpaj volumio[1048]: info: [1517428734343] CoreStateMachine::getState
Jan 31 19:58:54 musikpaj volumio[1048]: info: [1517428734346] interfaceApi::pushState
Jan 31 19:58:54 musikpaj volumio[1048]: info: [1517428734347] InterfaceWebUI::pushState
Jan 31 19:58:54 musikpaj volumio[1048]: info: [1517428734353] ------------------------------ 100ms
Jan 31 19:58:54 musikpaj volumio[1048]: info: Pushing Favourites {"service":"mpd","uri":"http://192.168.8.105:32469/object/03a3a47084b5ca424c08/file.mp3","favourite":false}
Jan 31 19:58:55 musikpaj volumio[1106]: 2018-01-31 19:58:55 [SPTF] 19:58:55.506 E [ap:1694] AP Socket Error: Timeout reached (20000)
Jan 31 19:58:55 musikpaj volumio[1106]: 2018-01-31 19:58:55 [SPTF] 19:58:55.506 E [ap:3953] Connection error:  117
Jan 31 19:58:55 musikpaj volumio[1106]: 2018-01-31 19:58:55 [WARN] Connection error: Cannot connect to Spotify
Jan 31 19:59:25 musikpaj volumio[1048]: info: CoreCommandRouter::volumioGetState
Jan 31 19:59:25 musikpaj volumio[1048]: info: [1517428765050] CoreStateMachine::getState
Jan 31 19:59:25 musikpaj volumio[1048]: [1517428765051] ---------------------------- Client requests Volumio state
Jan 31 19:59:25 musikpaj volumio[1048]: info: [1517428765052] InterfaceWebUI::pushState
Jan 31 19:59:25 musikpaj volumio[1048]: info: [1517428765055] ------------------------------ 6ms
Jan 31 19:59:25 musikpaj volumio[1048]: [1517428765077] ---------------------------- Client requests Menu Items
Jan 31 19:59:25 musikpaj volumio[1048]: info: CoreCommandRouter::executeOnPlugin: multiroom , getMultiroom
Jan 31 19:59:25 musikpaj volumio[1048]: Plugin multiroom or method getMultiroom not found
Jan 31 19:59:25 musikpaj volumio[1048]: info: [1517428765079] Listing playlists
Jan 31 19:59:25 musikpaj volumio[1048]: info: CoreCommandRouter::volumioGetBrowseSources
Jan 31 19:59:25 musikpaj volumio[1048]: info: CoreCommandRouter::volumioGetQueue
Jan 31 19:59:25 musikpaj volumio[1048]: info: [1517428765083] CoreStateMachine::getQueue
Jan 31 19:59:25 musikpaj volumio[1048]: info: [1517428765084] CorePlayQueue::getQueue
Jan 31 19:59:25 musikpaj volumio[1048]: [1517428765085] ---------------------------- Client requests Volumio queue
Jan 31 19:59:25 musikpaj volumio[1048]: [1517428765086] ---------------------------- Client requests Menu Items
Jan 31 19:59:25 musikpaj volumio[1048]: [1517428765087] ---------------------------- Client requests Menu Items
Jan 31 19:59:25 musikpaj volumio[1048]: info: [1517428765090] InterfaceWebUI::pushQueue
Jan 31 19:59:25 musikpaj volumio[1048]: info: [1517428765093] ------------------------------ 11ms
Jan 31 19:59:25 musikpaj volumio[1048]: info: [1517428765108] ------------------------------ 31ms
Jan 31 19:59:25 musikpaj volumio[1048]: info: [1517428765115] ------------------------------ 29ms
Jan 31 19:59:25 musikpaj volumio[1048]: info: [1517428765123] ------------------------------ 36ms
Jan 31 19:59:58 musikpaj volumio[1048]: info:
Jan 31 19:59:58 musikpaj volumio[1048]: [1517428798242] ---------------------------- Client requests Volumio pause
Jan 31 19:59:58 musikpaj volumio[1048]: info: CoreCommandRouter::volumioPause
Jan 31 19:59:58 musikpaj volumio[1048]: info: [1517428798245] CoreStateMachine::pause
Jan 31 19:59:58 musikpaj volumio[1048]: info: [1517428798247] CoreStateMachine::stPlaybackTimer
Jan 31 19:59:58 musikpaj volumio[1048]: info: [1517428798249] CoreStateMachine::servicePause
Jan 31 19:59:58 musikpaj volumio[1048]: info: [1517428798250] CorePlayQueue::getTrack 1
Jan 31 19:59:58 musikpaj volumio[1048]: info: CoreCommandRouter::servicePause
Jan 31 19:59:58 musikpaj volumio[1048]: info: [1517428798253] ControllerUPNPBrowser::pause
Jan 31 19:59:58 musikpaj volumio[1048]: info: [1517428798254] ControllerMpd::sendMpdCommand pause
Jan 31 19:59:58 musikpaj volumio[1048]: info: [1517428798255] sending command...
Jan 31 19:59:58 musikpaj volumio[1048]: info: [1517428798347] parsing response...
Jan 31 19:59:58 musikpaj volumio[1048]: info: [1517428798348] ------------------------------ 106ms
Jan 31 19:59:58 musikpaj volumio[1048]: [1517428798350] ---------------------------- MPD announces state update: player
Jan 31 19:59:58 musikpaj volumio[1048]: info: [1517428798351] ControllerMpd::getState
Jan 31 19:59:58 musikpaj volumio[1048]: info: [1517428798354] ControllerMpd::sendMpdCommand status
Jan 31 19:59:58 musikpaj volumio[1048]: info: [1517428798355] sending command...
Jan 31 19:59:58 musikpaj volumio[1048]: info: [1517428798357] parsing response...
Jan 31 19:59:58 musikpaj volumio[1048]: info: [1517428798358] ControllerMpd::parseState
Jan 31 19:59:58 musikpaj volumio[1048]: info: [1517428798359] ControllerMpd::sendMpdCommand playlistinfo
Jan 31 19:59:58 musikpaj volumio[1048]: info: [1517428798360] sending command...
Jan 31 19:59:58 musikpaj volumio[1048]: info: [1517428798363] parsing response...
Jan 31 19:59:58 musikpaj volumio[1048]: info: [1517428798363] ControllerMpd::parseTrackInfo
Jan 31 19:59:58 musikpaj volumio[1048]: info: [1517428798364] ControllerMpd::pushState
Jan 31 19:59:58 musikpaj volumio[1048]: info: CoreCommandRouter::servicePushState
Jan 31 19:59:58 musikpaj volumio[1048]: info: [1517428798366] CoreStateMachine::syncState
Jan 31 19:59:58 musikpaj volumio[1048]: info: [1517428798367] CorePlayQueue::getTrack 1
Jan 31 19:59:58 musikpaj volumio[1048]: info: STATE SERVICE {"status":"pause","position":0,"seek":64481,"duration":482,"samplerate":"44.1 KHz","bitdepth":"24 bit","channels":2,"random":false,"updatedb":false,"repeat":false,"isStreaming":false,"title":"file.mp3","artist":null,"album":null,"uri":"http://192.168.8.105:32469/object/03a3a47084b5ca424c08/file.mp3","trackType":"mp3"}
Jan 31 19:59:58 musikpaj volumio[1048]: info: CURRENT POSITION 1
Jan 31 19:59:58 musikpaj volumio[1048]: info: [1517428798370] CoreStateMachine::syncState   stateService pause
Jan 31 19:59:58 musikpaj volumio[1048]: info: [1517428798371] CoreStateMachine::syncState   currentStatus pause
Jan 31 19:59:58 musikpaj volumio[1048]: info: [1517428798372] CoreStateMachine::pushState
Jan 31 19:59:58 musikpaj volumio[1048]: info: [1517428798373] CoreStateMachine::getState
Jan 31 19:59:58 musikpaj volumio[1048]: info: CoreCommandRouter::volumioPushState
Jan 31 19:59:58 musikpaj volumio[1048]: info: CoreCommandRouter::executeOnPlugin: volumiodiscovery , saveDeviceInfo
Jan 31 19:59:58 musikpaj volumio[1048]: info: [1517428798377] interfaceApi::pushState
Jan 31 19:59:58 musikpaj volumio[1048]: info: [1517428798378] InterfaceWebUI::pushState
Jan 31 19:59:58 musikpaj volumio[1048]: info: [1517428798382] CoreStateMachine::stPlaybackTimer
Jan 31 19:59:58 musikpaj volumio[1048]: info: [1517428798386] ------------------------------ 36ms
Jan 31 19:59:58 musikpaj volumio[1048]: info: Pushing Favourites {"service":"mpd","uri":"http://192.168.8.105:32469/object/03a3a47084b5ca424c08/file.mp3","favourite":false}
Jan 31 20:00:04 musikpaj volumio[1048]: info: CoreCommandRouter::getUIConfigOnPlugin
Jan 31 20:00:04 musikpaj volumio[1048]: info: CoreCommandRouter::executeOnPlugin: i2s_dacs , getI2sOptions
Jan 31 20:00:04 musikpaj volumio[1048]: info: CoreCommandRouter::executeOnPlugin: system , getConfigParam
Jan 31 20:00:04 musikpaj volumio[1048]: info: CoreCommandRouter::executeOnPlugin: i2s_dacs , getI2sStatus
Jan 31 20:00:04 musikpaj volumio[1048]: info: CoreCommandRouter::executeOnPlugin: mpd , getConfigParam
Jan 31 20:00:24 musikpaj volumio[1048]: info: CoreCommandRouter::getUIConfigOnPlugin
Jan 31 20:00:24 musikpaj volumio[1048]: info: CoreCommandRouter::executeOnPlugin: albumart , getConfigParam
Jan 31 20:00:24 musikpaj volumio[1048]: info: CoreCommandRouter::executeOnPlugin: mpd , getConfigParam
Jan 31 20:00:25 musikpaj volumio[1048]: info: CoreCommandRouter::executeOnPlugin: mpd , getMyCollectionStats
Jan 31 20:00:25 musikpaj volumio[1048]: info: CoreCommandRouter::executeOnPlugin: networkfs , listShares
Jan 31 20:00:29 musikpaj volumio[1048]: info: CoreCommandRouter::executeOnPlugin: mpd , getMyCollectionStats
Jan 31 20:00:33 musikpaj volumio[1048]: info: CoreCommandRouter::executeOnPlugin: mpd , getMyCollectionStats
Jan 31 20:00:37 musikpaj volumio[1048]: info: CoreCommandRouter::executeOnPlugin: mpd , getMyCollectionStats
Jan 31 20:00:41 musikpaj volumio[1048]: info: CoreCommandRouter::executeOnPlugin: mpd , getMyCollectionStats
Jan 31 20:00:45 musikpaj volumio[1048]: info: CoreCommandRouter::executeOnPlugin: mpd , getMyCollectionStats
Jan 31 20:00:49 musikpaj volumio[1048]: info: CoreCommandRouter::executeOnPlugin: mpd , getMyCollectionStats
Jan 31 20:00:53 musikpaj volumio[1048]: info: CoreCommandRouter::executeOnPlugin: mpd , getMyCollectionStats
Jan 31 20:00:54 musikpaj volumio[1048]: info: CoreCommandRouter::getUIConfigOnPlugin
Jan 31 20:00:55 musikpaj volumio[1048]: info: CoreCommandRouter::executeOnPlugin: network , getInfoNetwork
Jan 31 20:00:55 musikpaj sudo[7429]: volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/sbin/ethtool eth0
Jan 31 20:00:55 musikpaj sudo[7429]: pam_unix(sudo:session): session opened for user root by (uid=0)
Jan 31 20:00:55 musikpaj sudo[7429]: pam_unix(sudo:session): session closed for user root
Jan 31 20:00:55 musikpaj sudo[7442]: volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/sbin/iwconfig wlan0
Jan 31 20:00:55 musikpaj sudo[7442]: pam_unix(sudo:session): session opened for user root by (uid=0)
Jan 31 20:00:55 musikpaj sudo[7442]: pam_unix(sudo:session): session closed for user root
Jan 31 20:00:55 musikpaj sudo[7456]: volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/sbin/iwconfig wlan0
Jan 31 20:00:55 musikpaj sudo[7456]: pam_unix(sudo:session): session opened for user root by (uid=0)
Jan 31 20:00:55 musikpaj sudo[7456]: pam_unix(sudo:session): session closed for user root
Jan 31 20:00:55 musikpaj sudo[7467]: volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/sbin/iwconfig wlan0
Jan 31 20:00:55 musikpaj sudo[7467]: pam_unix(sudo:session): session opened for user root by (uid=0)
Jan 31 20:00:55 musikpaj sudo[7467]: pam_unix(sudo:session): session closed for user root
Jan 31 20:00:56 musikpaj sudo[7480]: volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/sbin/ifconfig eth0
Jan 31 20:00:56 musikpaj volumio[1048]: info: CoreCommandRouter::executeOnPlugin: network , getWirelessNetworks
Jan 31 20:00:56 musikpaj sudo[7480]: pam_unix(sudo:session): session opened for user root by (uid=0)
Jan 31 20:00:56 musikpaj sudo[7483]: volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/sbin/ifconfig wlan0
Jan 31 20:00:56 musikpaj sudo[7480]: pam_unix(sudo:session): session closed for user root
Jan 31 20:00:56 musikpaj sudo[7483]: pam_unix(sudo:session): session opened for user root by (uid=0)
Jan 31 20:00:56 musikpaj sudo[7483]: pam_unix(sudo:session): session closed for user root
Jan 31 20:00:56 musikpaj sudo[7499]: volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/sbin/iwlist wlan0 scan
Jan 31 20:00:56 musikpaj sudo[7499]: pam_unix(sudo:session): session opened for user root by (uid=0)
Jan 31 20:00:56 musikpaj wpa_supplicant[988]: nl80211: Drv Event 33 (NL80211_CMD_TRIGGER_SCAN) received for wlan0
Jan 31 20:00:56 musikpaj wpa_supplicant[988]: wlan0: nl80211: Scan trigger
Jan 31 20:00:56 musikpaj wpa_supplicant[988]: wlan0: Event SCAN_STARTED (49) received
Jan 31 20:00:56 musikpaj wpa_supplicant[988]: wlan0: External program started a scan
Jan 31 20:00:57 musikpaj wpa_supplicant[988]: nl80211: Drv Event 34 (NL80211_CMD_NEW_SCAN_RESULTS) received for wlan0
Jan 31 20:00:57 musikpaj wpa_supplicant[988]: wlan0: nl80211: New scan results available
Jan 31 20:00:57 musikpaj wpa_supplicant[988]: nl80211: Scan probed for SSID ''
Jan 31 20:00:57 musikpaj wpa_supplicant[988]: nl80211: Scan included frequencies: 2412 2417 2422 2427 2432 2437 2442 2447 2452 2457 2462
Jan 31 20:00:57 musikpaj wpa_supplicant[988]: wlan0: Event SCAN_RESULTS (3) received
Jan 31 20:00:57 musikpaj wpa_supplicant[988]: wlan0: Scan completed in 0.714612 seconds
Jan 31 20:00:57 musikpaj wpa_supplicant[988]: nl80211: Associated on 2462 MHz
Jan 31 20:00:57 musikpaj wpa_supplicant[988]: nl80211: Associated with 44:6e:e5:3b:45:dd
Jan 31 20:00:57 musikpaj wpa_supplicant[988]: nl80211: Received scan results (6 BSSes)
Jan 31 20:00:57 musikpaj wpa_supplicant[988]: nl80211: Scan results indicate BSS status with 44:6e:e5:3b:45:dd as associated
Jan 31 20:00:57 musikpaj wpa_supplicant[988]: wlan0: BSS: Start scan result update 2
Jan 31 20:00:57 musikpaj wpa_supplicant[988]: wlan0: BSS: Add new id 5 BSSID b0:e1:7e:f3:46:ce SSID '3Bredband-2.4G-46CE'
Jan 31 20:00:57 musikpaj wpa_supplicant[988]: wlan0: BSS: Add new id 6 BSSID 8c:25:05:e0:a9:69 SSID '3MobilWiFi-4G-A969'
Jan 31 20:00:57 musikpaj wpa_supplicant[988]: wlan0: BSS: Add new id 7 BSSID 54:e6:fc:be:83:ca SSID 'Lottas'
Jan 31 20:00:57 musikpaj wpa_supplicant[988]: wlan0: BSS: Add new id 8 BSSID 00:25:92:ef:9c:90 SSID 'AWF320_9C90'
Jan 31 20:00:57 musikpaj wpa_supplicant[988]: wlan0: BSS: Add new id 9 BSSID 9c:97:26:74:ac:db SSID 'TeliaGateway9C-97-26-74-AC-DB'
Jan 31 20:00:57 musikpaj wpa_supplicant[988]: BSS: last_scan_res_used=6/32
Jan 31 20:00:57 musikpaj wpa_supplicant[988]: wlan0: New scan results available (own=0 ext=1)
Jan 31 20:00:57 musikpaj wpa_supplicant[988]: wlan0: Do not use results from externally requested scan operation for network selection
Jan 31 20:00:57 musikpaj wpa_supplicant[988]: RTM_NEWLINK: ifi_index=3 ifname=wlan0 wext ifi_family=0 ifi_flags=0x11043 ([UP][RUNNING][LOWER_UP])
Jan 31 20:00:57 musikpaj sudo[7499]: pam_unix(sudo:session): session closed for user root
Jan 31 20:00:58 musikpaj volumio[1048]: info: CoreCommandRouter::volumioGetState
Jan 31 20:00:58 musikpaj volumio[1048]: info: [1517428858960] CoreStateMachine::getState
Jan 31 20:00:58 musikpaj volumio[1048]: [1517428858961] ---------------------------- Client requests Volumio state
Jan 31 20:00:58 musikpaj volumio[1048]: info: [1517428858963] InterfaceWebUI::pushState
Jan 31 20:00:58 musikpaj volumio[1048]: info: [1517428858967] ------------------------------ 8ms
Jan 31 20:01:04 musikpaj volumio[1048]: info:
Jan 31 20:01:04 musikpaj volumio[1048]: [1517428864635] ---------------------------- Client requests Menu Items
Jan 31 20:01:04 musikpaj volumio[1048]: info: [1517428864647] ------------------------------ 12ms
Jan 31 20:01:04 musikpaj volumio[1048]: info: CoreCommandRouter::executeOnPlugin: multiroom , getMultiroom
Jan 31 20:01:04 musikpaj volumio[1048]: Plugin multiroom or method getMultiroom not found
Jan 31 20:01:04 musikpaj volumio[1048]: info: [1517428864657] Listing playlists
Jan 31 20:01:04 musikpaj volumio[1048]: info: CoreCommandRouter::volumioGetBrowseSources
Jan 31 20:01:04 musikpaj volumio[1048]: info: CoreCommandRouter::volumioGetQueue
Jan 31 20:01:04 musikpaj volumio[1048]: info: [1517428864670] CoreStateMachine::getQueue
Jan 31 20:01:04 musikpaj volumio[1048]: info: [1517428864671] CorePlayQueue::getQueue
Jan 31 20:01:04 musikpaj volumio[1048]: [1517428864671] ---------------------------- Client requests Volumio queue
Jan 31 20:01:04 musikpaj volumio[1048]: info: [1517428864672] InterfaceWebUI::pushQueue
Jan 31 20:01:04 musikpaj volumio[1048]: info: [1517428864674] ------------------------------ 4ms
Jan 31 20:01:04 musikpaj volumio[1048]: [1517428864675] ---------------------------- Client requests Menu Items
Jan 31 20:01:04 musikpaj volumio[1048]: [1517428864678] ---------------------------- Client requests Menu Items
Jan 31 20:01:04 musikpaj volumio[1048]: info: [1517428864687] ------------------------------ 13ms
Jan 31 20:01:04 musikpaj volumio[1048]: info: [1517428864701] ------------------------------ 23ms
Jan 31 20:01:18 musikpaj volumio[1106]: 2018-01-31 20:01:18 [SPTF] 20:01:18.027 I [ap:1752] Connecting to AP ap.spotify.com:80
Jan 31 20:01:23 musikpaj volumio[1106]: 2018-01-31 20:01:23 [SPTF] 20:01:23.032 E [ap:1694] AP Socket Error: Timeout reached (20000)
Jan 31 20:01:23 musikpaj volumio[1106]: 2018-01-31 20:01:23 [SPTF] 20:01:23.032 E [ap:3953] Connection error:  117
Jan 31 20:01:23 musikpaj volumio[1106]: 2018-01-31 20:01:23 [WARN] Connection error: Cannot connect to Spotify
Jan 31 20:01:31 musikpaj volumio[1048]: info:
Jan 31 20:01:31 musikpaj volumio[1048]: [1517428891545] ---------------------------- Client requests Volumio play
Jan 31 20:01:31 musikpaj volumio[1048]: info: CoreCommandRouter::volumioPlay
Jan 31 20:01:31 musikpaj volumio[1048]: UNSET VOLATILE
Jan 31 20:01:31 musikpaj volumio[1048]: info: [1517428891547] CoreStateMachine::play index undefined
Jan 31 20:01:31 musikpaj volumio[1048]: info: [1517428891547] CoreStateMachine::setConsumeUpdateService undefined
Jan 31 20:01:31 musikpaj volumio[1048]: info: [1517428891548] CorePlayQueue::getTrack 1
Jan 31 20:01:31 musikpaj volumio[1048]: info: [1517428891548] CoreStateMachine::startPlaybackTimer
Jan 31 20:01:31 musikpaj volumio[1048]: info: [1517428891549] CorePlayQueue::getTrack 1
Jan 31 20:01:31 musikpaj volumio[1048]: info: [1517428891549] ControllerUPNPBrowser::resume
Jan 31 20:01:31 musikpaj volumio[1048]: info: [1517428891550] ControllerMpd::sendMpdCommand play
Jan 31 20:01:31 musikpaj volumio[1048]: info: [1517428891559] sending command...
Jan 31 20:01:31 musikpaj volumio[1048]: info: [1517428891561] ------------------------------ 16ms
Jan 31 20:01:31 musikpaj kernel: pcm512x 1-004c: No SCLK, using BCLK: -2
And now in this log I moved my RPI to its actual place it has now 2 bars in wifi strength ( yes I stopped the music pressed shut down and waited for the green light to stop blin before i pulled the plug)
as you can see here in this log it has differnt erros than the first log, and I just did same thing, tried to play webradio and tried with spotify and played
a song from my plexmediaserver and thats worked as before. an extra thing I did was to disable the built in hotspot in volumio.
-- Logs begin at Wed 2018-01-31 20:47:17 UTC. --
Jan 31 20:48:52 musikpaj systemd[1524]: Reached target Basic System.
Jan 31 20:48:52 musikpaj systemd[1524]: Starting Default.
Jan 31 20:48:52 musikpaj systemd[1524]: Reached target Default.
Jan 31 20:48:52 musikpaj systemd[1524]: Startup finished in 43ms.
Jan 31 20:48:52 musikpaj systemd[1]: Started User Manager for UID 1000.
Jan 31 20:48:52 musikpaj sshd[1213]: lastlog_openseek: Couldn't stat /var/log/la        stlog: No such file or directory
Jan 31 20:49:24 musikpaj ntpd_intres[725]: host name not found: 1.debian.pool.nt        p.org
Jan 31 20:49:32 musikpaj sudo[1804]: volumio : TTY=pts/0 ; PWD=/home/volumio ; U        SER=root ; COMMAND=/bin/journalctl -f
Jan 31 20:49:32 musikpaj sudo[1804]: pam_unix(sudo:session): session opened for        user root by volumio(uid=0)
Jan 31 20:49:35 musikpaj volumio[923]: info: CoreCommandRouter::volumioGetState
Jan 31 20:49:35 musikpaj volumio[923]: info: [1517431775730] CoreStateMachine::g        etState
Jan 31 20:49:35 musikpaj volumio[923]: info: [1517431775730] CorePlayQueue::getT        rack 0
Jan 31 20:49:35 musikpaj volumio[923]: [1517431775731] -------------------------        --- Client requests Volumio state
Jan 31 20:49:35 musikpaj volumio[923]: info: [1517431775734] InterfaceWebUI::pus        hState
Jan 31 20:49:35 musikpaj volumio[923]: info: [1517431775753] -------------------        ----------- 24ms
Jan 31 20:49:35 musikpaj volumio[923]: [1517431775759] -------------------------        --- Client requests Menu Items
Jan 31 20:49:35 musikpaj volumio[923]: info: CoreCommandRouter::executeOnPlugin:        multiroom , getMultiroom
Jan 31 20:49:35 musikpaj volumio[923]: Plugin multiroom or method getMultiroom n        ot found
Jan 31 20:49:35 musikpaj volumio[923]: info: [1517431775776] Listing playlists
Jan 31 20:49:35 musikpaj volumio[923]: info: CoreCommandRouter::volumioGetBrowse        Sources
Jan 31 20:49:35 musikpaj volumio[923]: info: CoreCommandRouter::volumioGetQueue
Jan 31 20:49:35 musikpaj volumio[923]: info: [1517431775781] CoreStateMachine::g        etQueue
Jan 31 20:49:35 musikpaj volumio[923]: info: [1517431775782] CorePlayQueue::getQ        ueue
Jan 31 20:49:35 musikpaj volumio[923]: [1517431775783] -------------------------        --- Client requests Volumio queue
Jan 31 20:49:35 musikpaj volumio[923]: [1517431775785] -------------------------        --- Client requests Menu Items
Jan 31 20:49:35 musikpaj volumio[923]: [1517431775786] -------------------------        --- Client requests Menu Items
Jan 31 20:49:35 musikpaj volumio[923]: info: [1517431775791] InterfaceWebUI::pus        hQueue
Jan 31 20:49:35 musikpaj volumio[923]: info: [1517431775794] -------------------        ----------- 14ms
Jan 31 20:49:35 musikpaj volumio[923]: info: [1517431775866] -------------------        ----------- 107ms
Jan 31 20:49:35 musikpaj volumio[923]: info: [1517431775877] -------------------        ----------- 92ms
Jan 31 20:49:35 musikpaj volumio[923]: info: [1517431775885] -------------------        ----------- 99ms
Jan 31 20:49:52 musikpaj volumio[923]: info: Cannot call home: Error: Command failed: /usr/bin/curl -X POST --data-binary "device=pi&variante=volumio&version=2.348&uuid=db34e0a9ef7350fae6bc66c7bfac3999" http://updates.volumio.org:7070/downloader-v1/track-device
Jan 31 20:49:52 musikpaj volumio[923]: % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
Jan 31 20:49:52 musikpaj volumio[923]: Dload  Upload   Total   Spent    Left  Speed
Jan 31 20:49:52 musikpaj volumio[923]: [1.9K blob data]
Jan 31 20:49:52 musikpaj volumio[923]: [460B blob data]
Jan 31 20:49:52 musikpaj volumio[923]: retrying in 5 seconds, trial 1
Jan 31 20:49:52 musikpaj volumio[923]: Volumio Calling Home
Jan 31 20:50:20 musikpaj ntpd_intres[725]: host name not found: 2.debian.pool.ntp.org
Jan 31 20:50:37 musikpaj wpa_supplicant[858]: wlan0: BSS: Remove id 0 BSSID b0:e1:7e:f3:46:ce SSID '3Bredband-2.4G-46CE' due to wpa_bss_flush_by_age
Jan 31 20:50:37 musikpaj wpa_supplicant[858]: wlan0: BSS: Remove id 2 BSSID 0c:51:01:e4:79:d0 SSID 'Urbans Wi-Fi' due to wpa_bss_flush_by_age
Jan 31 20:50:37 musikpaj wpa_supplicant[858]: wlan0: BSS: Remove id 3 BSSID 64:a5:c3:68:fb:68 SSID 'Urbans Wi-Fi' due to wpa_bss_flush_by_age
Jan 31 20:50:37 musikpaj wpa_supplicant[858]: wlan0: BSS: Remove id 4 BSSID 0c:96:bf:4d:1c:b1 SSID 'Not' due to wpa_bss_flush_by_age
Jan 31 20:50:38 musikpaj volumio[923]: info: CoreCommandRouter::volumioGetState
Jan 31 20:50:38 musikpaj volumio[923]: info: [1517431838077] CoreStateMachine::getState
Jan 31 20:50:38 musikpaj volumio[923]: info: [1517431838078] CorePlayQueue::getTrack 0
Jan 31 20:50:38 musikpaj volumio[923]: [1517431838079] ---------------------------- Client requests Volumio state
Jan 31 20:50:38 musikpaj volumio[923]: info: [1517431838080] InterfaceWebUI::pushState
Jan 31 20:50:38 musikpaj volumio[923]: info: [1517431838099] ------------------------------ 22ms
Jan 31 20:50:38 musikpaj volumio[923]: [1517431838133] ---------------------------- Client requests Menu Items
Jan 31 20:50:38 musikpaj volumio[923]: info: CoreCommandRouter::executeOnPlugin: appearance , getUiSettings
Jan 31 20:50:38 musikpaj volumio[923]: info: [1517431838149] ------------------------------ 16ms
Jan 31 20:50:38 musikpaj volumio[923]: info: CoreCommandRouter::executeOnPlugin: wizard , getShowWizard
Jan 31 20:50:38 musikpaj volumio[923]: info: CoreCommandRouter::executeOnPlugin: system , getShowWizard
Jan 31 20:50:38 musikpaj volumio[923]: info: CoreCommandRouter::executeOnPlugin: multiroom , getMultiroom
Jan 31 20:50:38 musikpaj volumio[923]: Plugin multiroom or method getMultiroom not found
Jan 31 20:50:38 musikpaj volumio[923]: info: [1517431838208] Listing playlists
Jan 31 20:50:47 musikpaj volumio[923]: info: CoreCommandRouter::getUIConfigOnPlugin
Jan 31 20:50:48 musikpaj volumio[923]: info: CoreCommandRouter::executeOnPlugin: network , getInfoNetwork
Jan 31 20:50:48 musikpaj sudo[2350]: volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/sbin/ethtool eth0
Jan 31 20:50:48 musikpaj sudo[2350]: pam_unix(sudo:session): session opened for user root by (uid=0)
Jan 31 20:50:48 musikpaj sudo[2350]: pam_unix(sudo:session): session closed for user root
Jan 31 20:50:48 musikpaj sudo[2363]: volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/sbin/iwconfig wlan0
Jan 31 20:50:48 musikpaj sudo[2363]: pam_unix(sudo:session): session opened for user root by (uid=0)
Jan 31 20:50:48 musikpaj sudo[2363]: pam_unix(sudo:session): session closed for user root
Jan 31 20:50:48 musikpaj sudo[2377]: volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/sbin/iwconfig wlan0
Jan 31 20:50:48 musikpaj sudo[2377]: pam_unix(sudo:session): session opened for user root by (uid=0)
Jan 31 20:50:48 musikpaj sudo[2377]: pam_unix(sudo:session): session closed for user root
Jan 31 20:50:48 musikpaj sudo[2388]: volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/sbin/iwconfig wlan0
Jan 31 20:50:48 musikpaj sudo[2388]: pam_unix(sudo:session): session opened for user root by (uid=0)
Jan 31 20:50:48 musikpaj sudo[2388]: pam_unix(sudo:session): session closed for user root
Jan 31 20:50:49 musikpaj sudo[2401]: volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/sbin/ifconfig eth0
Jan 31 20:50:49 musikpaj sudo[2401]: pam_unix(sudo:session): session opened for user root by (uid=0)
Jan 31 20:50:49 musikpaj volumio[923]: info: CoreCommandRouter::executeOnPlugin: network , getWirelessNetworks
Jan 31 20:50:49 musikpaj sudo[2403]: volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/sbin/ifconfig wlan0
Jan 31 20:50:49 musikpaj sudo[2401]: pam_unix(sudo:session): session closed for user root
Jan 31 20:50:49 musikpaj sudo[2403]: pam_unix(sudo:session): session opened for user root by (uid=0)
Jan 31 20:50:49 musikpaj sudo[2403]: pam_unix(sudo:session): session closed for user root
Jan 31 20:50:49 musikpaj sudo[2423]: volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/sbin/iwlist wlan0 scan
Jan 31 20:50:49 musikpaj sudo[2423]: pam_unix(sudo:session): session opened for user root by (uid=0)
Jan 31 20:50:49 musikpaj wpa_supplicant[858]: nl80211: Drv Event 33 (NL80211_CMD_TRIGGER_SCAN) received for wlan0
Jan 31 20:50:49 musikpaj wpa_supplicant[858]: wlan0: nl80211: Scan trigger
Jan 31 20:50:49 musikpaj wpa_supplicant[858]: wlan0: Event SCAN_STARTED (49) received
Jan 31 20:50:49 musikpaj wpa_supplicant[858]: wlan0: External program started a scan
Jan 31 20:50:50 musikpaj wpa_supplicant[858]: RTM_NEWLINK: ifi_index=3 ifname=wlan0 wext ifi_family=0 ifi_flags=0x11043 ([UP][RUNNING][LOWER_UP])
Jan 31 20:50:50 musikpaj wpa_supplicant[858]: nl80211: Drv Event 34 (NL80211_CMD_NEW_SCAN_RESULTS) received for wlan0
Jan 31 20:50:50 musikpaj wpa_supplicant[858]: wlan0: nl80211: New scan results available
Jan 31 20:50:50 musikpaj wpa_supplicant[858]: nl80211: Scan probed for SSID ''
Jan 31 20:50:50 musikpaj wpa_supplicant[858]: nl80211: Scan included frequencies: 2412 2417 2422 2427 2432 2437 2442 2447 2452 2457 2462
Jan 31 20:50:50 musikpaj wpa_supplicant[858]: wlan0: Event SCAN_RESULTS (3) received
Jan 31 20:50:50 musikpaj wpa_supplicant[858]: wlan0: Scan completed in 0.717842 seconds
Jan 31 20:50:50 musikpaj wpa_supplicant[858]: nl80211: Associated on 2462 MHz
Jan 31 20:50:50 musikpaj wpa_supplicant[858]: nl80211: Associated with 44:6e:e5:3b:45:dd
Jan 31 20:50:50 musikpaj wpa_supplicant[858]: nl80211: Received scan results (4 BSSes)
Jan 31 20:50:50 musikpaj wpa_supplicant[858]: nl80211: Scan results indicate BSS status with 44:6e:e5:3b:45:dd as associated
Jan 31 20:50:50 musikpaj wpa_supplicant[858]: wlan0: BSS: Start scan result update 2
Jan 31 20:50:50 musikpaj wpa_supplicant[858]: wlan0: BSS: Add new id 5 BSSID b0:e1:7e:f3:46:ce SSID '3Bredband-2.4G-46CE'
Jan 31 20:50:50 musikpaj wpa_supplicant[858]: wlan0: BSS: Add new id 6 BSSID 0c:96:bf:4d:1c:b1 SSID 'Not'
Jan 31 20:50:50 musikpaj wpa_supplicant[858]: wlan0: BSS: Add new id 7 BSSID 0c:51:01:e4:79:d0 SSID 'Urbans Wi-Fi'
Jan 31 20:50:50 musikpaj wpa_supplicant[858]: BSS: last_scan_res_used=4/32
Jan 31 20:50:50 musikpaj wpa_supplicant[858]: wlan0: New scan results available (own=0 ext=1)
Jan 31 20:50:50 musikpaj wpa_supplicant[858]: wlan0: Do not use results from externally requested scan operation for network selection
Jan 31 20:50:50 musikpaj sudo[2423]: pam_unix(sudo:session): session closed for user root
Jan 31 20:50:59 musikpaj volumio[923]: info: Cannot call home: Error: Command failed: /usr/bin/curl -X POST --data-binary "device=pi&variante=volumio&version=2.348&uuid=db34e0a9ef7350fae6bc66c7bfac3999" http://updates.volumio.org:7070/downloader-v1/track-device
Jan 31 20:50:59 musikpaj volumio[923]: % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
Jan 31 20:50:59 musikpaj volumio[923]: Dload  Upload   Total   Spent    Left  Speed
Jan 31 20:50:59 musikpaj volumio[923]: [1.9K blob data]
Jan 31 20:50:59 musikpaj volumio[923]: [381B blob data]
Jan 31 20:50:59 musikpaj volumio[923]: retrying in 5 seconds, trial 2
Jan 31 20:50:59 musikpaj volumio[923]: Volumio Calling Home
Jan 31 20:51:16 musikpaj ntpd_intres[725]: host name not found: 3.debian.pool.ntp.org
Jan 31 20:51:36 musikpaj volumio[923]: info: CoreCommandRouter::volumioGetState
Jan 31 20:51:36 musikpaj volumio[923]: info: [1517431896109] CoreStateMachine::getState
Jan 31 20:51:36 musikpaj volumio[923]: info: [1517431896110] CorePlayQueue::getTrack 0
Jan 31 20:51:36 musikpaj volumio[923]: [1517431896110] ---------------------------- Client requests Volumio state
Jan 31 20:51:36 musikpaj volumio[923]: info: [1517431896111] InterfaceWebUI::pushState
Jan 31 20:51:36 musikpaj volumio[923]: info: [1517431896128] ------------------------------ 20ms
Jan 31 20:51:38 musikpaj volumio[923]: info: CoreCommandRouter::volumioGetBrowseSources
Jan 31 20:51:38 musikpaj volumio[923]: info: CoreCommandRouter::volumioGetQueue
Jan 31 20:51:38 musikpaj volumio[923]: info: [1517431898930] CoreStateMachine::getQueue
Jan 31 20:51:38 musikpaj volumio[923]: info: [1517431898931] CorePlayQueue::getQueue
Jan 31 20:51:38 musikpaj volumio[923]: [1517431898931] ---------------------------- Client requests Volumio queue
Jan 31 20:51:38 musikpaj volumio[923]: info: [1517431898932] InterfaceWebUI::pushQueue
Jan 31 20:51:38 musikpaj volumio[923]: info: [1517431898934] ------------------------------ 4ms
Jan 31 20:51:45 musikpaj volumio[923]: info: CoreCommandRouter::executeOnPlugin: webradio , handleBrowseUri
Jan 31 20:51:45 musikpaj volumio[923]: info: CoreCommandRouter::executeOnPlugin: system , getSystemVersion
Jan 31 20:51:51 musikpaj volumio[923]: info: CoreCommandRouter::executeOnPlugin: webradio , handleBrowseUri
Jan 31 20:51:53 musikpaj volumio[923]: info:
Jan 31 20:51:53 musikpaj volumio[923]: [1517431913787] ---------------------------- Client requests Menu Items
Jan 31 20:51:53 musikpaj volumio[923]: info: [1517431913830] ------------------------------ 43ms
Jan 31 20:51:53 musikpaj volumio[923]: info: CoreCommandRouter::executeOnPlugin: multiroom , getMultiroom
Jan 31 20:51:53 musikpaj volumio[923]: Plugin multiroom or method getMultiroom not found
Jan 31 20:51:53 musikpaj volumio[923]: info: [1517431913840] Listing playlists
Jan 31 20:51:53 musikpaj volumio[923]: info: CoreCommandRouter::volumioGetBrowseSources
Jan 31 20:51:53 musikpaj volumio[923]: info: CoreCommandRouter::volumioGetQueue
Jan 31 20:51:53 musikpaj volumio[923]: info: [1517431913852] CoreStateMachine::getQueue
Jan 31 20:51:53 musikpaj volumio[923]: info: [1517431913853] CorePlayQueue::getQueue
Jan 31 20:51:53 musikpaj volumio[923]: [1517431913853] ---------------------------- Client requests Volumio queue
Jan 31 20:51:53 musikpaj volumio[923]: info: [1517431913854] InterfaceWebUI::pushQueue
Jan 31 20:51:53 musikpaj volumio[923]: info: [1517431913856] ------------------------------ 5ms
Jan 31 20:51:53 musikpaj volumio[923]: [1517431913860] ---------------------------- Client requests Menu Items
Jan 31 20:51:53 musikpaj volumio[923]: [1517431913864] ---------------------------- Client requests Menu Items
Jan 31 20:51:53 musikpaj volumio[923]: info: [1517431913889] ------------------------------ 29ms
Jan 31 20:51:53 musikpaj volumio[923]: info: [1517431913901] ------------------------------ 37ms
Jan 31 20:52:44 musikpaj volumio[923]: info: CoreCommandRouter::volumioGetState
Jan 31 20:52:44 musikpaj volumio[923]: info: [1517431964145] CoreStateMachine::g        etState
Jan 31 20:52:44 musikpaj volumio[923]: info: [1517431964145] CorePlayQueue::getT        rack 0
Jan 31 20:52:44 musikpaj volumio[923]: [1517431964146] -------------------------        --- Client requests Volumio state
Jan 31 20:52:44 musikpaj volumio[923]: info: [1517431964147] InterfaceWebUI::pus        hState
Jan 31 20:52:44 musikpaj volumio[923]: info: [1517431964174] -------------------        ----------- 30ms
Jan 31 20:52:44 musikpaj volumio[923]: [1517431964186] -------------------------        --- Client requests Menu Items
Jan 31 20:52:44 musikpaj volumio[923]: info: CoreCommandRouter::executeOnPlugin:        appearance , getUiSettings
Jan 31 20:52:44 musikpaj volumio[923]: info: [1517431964209] -------------------        ----------- 23ms
Jan 31 20:52:44 musikpaj volumio[923]: info: CoreCommandRouter::executeOnPlugin:        wizard , getShowWizard
Jan 31 20:52:44 musikpaj volumio[923]: info: CoreCommandRouter::executeOnPlugin:        system , getShowWizard
Jan 31 20:52:44 musikpaj volumio[923]: info: No input data
Jan 31 20:52:44 musikpaj volumio[923]: info: CoreCommandRouter::executeOnPlugin:        multiroom , getMultiroom
Jan 31 20:52:44 musikpaj volumio[923]: Plugin multiroom or method getMultiroom n        ot found
Jan 31 20:52:44 musikpaj volumio[923]: info: [1517431964284] Listing playlists
Jan 31 20:52:47 musikpaj volumio[923]: (node:923) UnhandledPromiseRejectionWarni        ng: Unhandled promise rejection (rejection id: 1): Error
Jan 31 20:53:02 musikpaj volumio[923]: info: CoreCommandRouter::volumioGetBrowseSources
Jan 31 20:53:02 musikpaj volumio[923]: info: CoreCommandRouter::volumioGetQueue
Jan 31 20:53:02 musikpaj volumio[923]: info: [1517431982248] CoreStateMachine::getQueue
Jan 31 20:53:02 musikpaj volumio[923]: info: [1517431982249] CorePlayQueue::getQueue
Jan 31 20:53:02 musikpaj volumio[923]: [1517431982251] ---------------------------- Client requests Volumio queue
Jan 31 20:53:02 musikpaj volumio[923]: info: [1517431982254] InterfaceWebUI::pushQueue
Jan 31 20:53:02 musikpaj volumio[923]: info: [1517431982257] ------------------------------ 12ms
Jan 31 20:53:02 musikpaj volumio[923]: info: No input data
Jan 31 20:53:10 musikpaj volumio[923]: info: CoreCommandRouter::executeOnPlugin: webradio , handleBrowseUri
Jan 31 20:53:10 musikpaj volumio[923]: info: CoreCommandRouter::executeOnPlugin: system , getSystemVersion
Jan 31 20:53:15 musikpaj volumio[923]: info: CoreCommandRouter::executeOnPlugin: webradio , handleBrowseUri
Jan 31 20:53:51 musikpaj volumio[923]: info: CoreCommandRouter::volumioGetState
Jan 31 20:53:51 musikpaj volumio[923]: info: [1517432031481] CoreStateMachine::getState
Jan 31 20:53:51 musikpaj volumio[923]: info: [1517432031483] CorePlayQueue::getTrack 0
Jan 31 20:53:51 musikpaj volumio[923]: [1517432031485] ---------------------------- Client requests Volumio state
Jan 31 20:53:51 musikpaj volumio[923]: info: [1517432031489] InterfaceWebUI::pushState
Jan 31 20:53:51 musikpaj volumio[923]: info: [1517432031508] ------------------------------ 29ms
Jan 31 20:53:57 musikpaj wpa_supplicant[858]: wlan0: BSS: Remove id 5 BSSID b0:e1:7e:f3:46:ce SSID '3Bredband-2.4G-46CE' due to wpa_bss_flush_by_age
Jan 31 20:53:57 musikpaj wpa_supplicant[858]: wlan0: BSS: Remove id 6 BSSID 0c:96:bf:4d:1c:b1 SSID 'Not' due to wpa_bss_flush_by_age
Jan 31 20:53:57 musikpaj wpa_supplicant[858]: wlan0: BSS: Remove id 7 BSSID 0c:51:01:e4:79:d0 SSID 'Urbans Wi-Fi' due to wpa_bss_flush_by_age
Jan 31 20:54:11 musikpaj volumio[923]: (node:923) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 2): Error
Jan 31 20:54:14 musikpaj ntpd_intres[725]: host name not found: 0.debian.pool.ntp.org
Jan 31 20:54:26 musikpaj volumio[923]: info: CoreCommandRouter::getUIConfigOnPlugin
Jan 31 20:54:26 musikpaj volumio[923]: info: CoreCommandRouter::executeOnPlugin: network , getInfoNetwork
Jan 31 20:54:26 musikpaj sudo[3952]: volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/sbin/ethtool eth0
Jan 31 20:54:26 musikpaj sudo[3952]: pam_unix(sudo:session): session opened for user root by (uid=0)
Jan 31 20:54:26 musikpaj sudo[3952]: pam_unix(sudo:session): session closed for user root
Jan 31 20:54:26 musikpaj sudo[3965]: volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/sbin/iwconfig wlan0
Jan 31 20:54:26 musikpaj sudo[3965]: pam_unix(sudo:session): session opened for user root by (uid=0)
Jan 31 20:54:26 musikpaj sudo[3965]: pam_unix(sudo:session): session closed for user root
Jan 31 20:54:26 musikpaj sudo[3979]: volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/sbin/iwconfig wlan0
Jan 31 20:54:26 musikpaj sudo[3979]: pam_unix(sudo:session): session opened for user root by (uid=0)
Jan 31 20:54:26 musikpaj sudo[3979]: pam_unix(sudo:session): session closed for user root
Jan 31 20:54:26 musikpaj sudo[3990]: volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/sbin/iwconfig wlan0
Jan 31 20:54:26 musikpaj sudo[3990]: pam_unix(sudo:session): session opened for user root by (uid=0)
Jan 31 20:54:26 musikpaj sudo[3990]: pam_unix(sudo:session): session closed for user root
Jan 31 20:54:28 musikpaj sudo[4003]: volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/sbin/ifconfig eth0
Jan 31 20:54:28 musikpaj volumio[923]: info: CoreCommandRouter::executeOnPlugin: network , getWirelessNetworks
Jan 31 20:54:28 musikpaj sudo[4003]: pam_unix(sudo:session): session opened for user root by (uid=0)
Jan 31 20:54:28 musikpaj sudo[4008]: volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/sbin/ifconfig wlan0
Jan 31 20:54:28 musikpaj sudo[4003]: pam_unix(sudo:session): session closed for user root
Jan 31 20:54:28 musikpaj sudo[4008]: pam_unix(sudo:session): session opened for user root by (uid=0)
Jan 31 20:54:28 musikpaj sudo[4008]: pam_unix(sudo:session): session closed for user root
Jan 31 20:54:28 musikpaj sudo[4020]: volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/sbin/iwlist wlan0 scan
Jan 31 20:54:28 musikpaj sudo[4020]: pam_unix(sudo:session): session opened for user root by (uid=0)
Jan 31 20:54:28 musikpaj wpa_supplicant[858]: nl80211: Drv Event 33 (NL80211_CMD_TRIGGER_SCAN) received for wlan0
Jan 31 20:54:28 musikpaj wpa_supplicant[858]: wlan0: nl80211: Scan trigger
Jan 31 20:54:28 musikpaj wpa_supplicant[858]: wlan0: Event SCAN_STARTED (49) received
Jan 31 20:54:28 musikpaj wpa_supplicant[858]: wlan0: External program started a scan
Jan 31 20:54:28 musikpaj wpa_supplicant[858]: RTM_NEWLINK: ifi_index=3 ifname=wlan0 wext ifi_family=0 ifi_flags=0x11043 ([UP][RUNNING][LOWER_UP])
Jan 31 20:54:28 musikpaj wpa_supplicant[858]: nl80211: Drv Event 34 (NL80211_CMD_NEW_SCAN_RESULTS) received for wlan0
Jan 31 20:54:28 musikpaj wpa_supplicant[858]: wlan0: nl80211: New scan results available
Jan 31 20:54:28 musikpaj wpa_supplicant[858]: nl80211: Scan probed for SSID ''
Jan 31 20:54:28 musikpaj wpa_supplicant[858]: nl80211: Scan included frequencies: 2412 2417 2422 2427 2432 2437 2442 2447 2452 2457 2462
Jan 31 20:54:28 musikpaj wpa_supplicant[858]: wlan0: Event SCAN_RESULTS (3) received
Jan 31 20:54:28 musikpaj wpa_supplicant[858]: wlan0: Scan completed in 0.711057 seconds
Jan 31 20:54:28 musikpaj wpa_supplicant[858]: nl80211: Associated on 2462 MHz
Jan 31 20:54:28 musikpaj wpa_supplicant[858]: nl80211: Associated with 44:6e:e5:3b:45:dd
Jan 31 20:54:28 musikpaj wpa_supplicant[858]: nl80211: Received scan results (6 BSSes)
Jan 31 20:54:28 musikpaj wpa_supplicant[858]: nl80211: Scan results indicate BSS status with 44:6e:e5:3b:45:dd as associated
Jan 31 20:54:28 musikpaj wpa_supplicant[858]: wlan0: BSS: Start scan result update 3
Jan 31 20:54:28 musikpaj wpa_supplicant[858]: wlan0: BSS: Add new id 8 BSSID b0:e1:7e:f3:46:ce SSID '3Bredband-2.4G-46CE'
Jan 31 20:54:28 musikpaj wpa_supplicant[858]: wlan0: BSS: Add new id 9 BSSID 64:a5:c3:68:fb:68 SSID 'Urbans Wi-Fi'
Jan 31 20:54:28 musikpaj wpa_supplicant[858]: wlan0: BSS: Add new id 10 BSSID 0c:51:01:e4:79:d0 SSID 'Urbans Wi-Fi'
Jan 31 20:54:28 musikpaj wpa_supplicant[858]: wlan0: BSS: Add new id 11 BSSID 0c:96:bf:4d:1c:b1 SSID 'Not'
Jan 31 20:54:28 musikpaj wpa_supplicant[858]: wlan0: BSS: Add new id 12 BSSID f2:9f:c2:3d:04:e5 SSID 'Xercise_gast'
Jan 31 20:54:28 musikpaj wpa_supplicant[858]: BSS: last_scan_res_used=6/32
Jan 31 20:54:28 musikpaj wpa_supplicant[858]: wlan0: New scan results available (own=0 ext=1)
Jan 31 20:54:28 musikpaj wpa_supplicant[858]: wlan0: Do not use results from externally requested scan operation for network selection
Jan 31 20:54:28 musikpaj sudo[4020]: pam_unix(sudo:session): session closed for user root
Jan 31 20:54:36 musikpaj volumio[923]: info:
Jan 31 20:54:36 musikpaj volumio[923]: [1517432076940] ---------------------------- Client requests Menu Items
Jan 31 20:54:36 musikpaj volumio[923]: info: [1517432076982] ------------------------------ 42ms
Jan 31 20:54:36 musikpaj volumio[923]: info: CoreCommandRouter::executeOnPlugin: multiroom , getMultiroom
Jan 31 20:54:36 musikpaj volumio[923]: Plugin multiroom or method getMultiroom not found
Jan 31 20:54:36 musikpaj volumio[923]: info: [1517432076997] Listing playlists
Jan 31 20:54:37 musikpaj volumio[923]: info: CoreCommandRouter::volumioGetBrowseSources
Jan 31 20:54:37 musikpaj volumio[923]: info: CoreCommandRouter::volumioGetQueue
Jan 31 20:54:37 musikpaj volumio[923]: info: [1517432077012] CoreStateMachine::getQueue
Jan 31 20:54:37 musikpaj volumio[923]: info: [1517432077014] CorePlayQueue::getQueue
Jan 31 20:54:37 musikpaj volumio[923]: [1517432077016] ---------------------------- Client requests Volumio queue
Jan 31 20:54:37 musikpaj volumio[923]: info: [1517432077019] InterfaceWebUI::pushQueue
Jan 31 20:54:37 musikpaj volumio[923]: info: [1517432077021] ------------------------------ 11ms
Jan 31 20:54:37 musikpaj volumio[923]: [1517432077024] ---------------------------- Client requests Menu Items
Jan 31 20:54:37 musikpaj volumio[923]: [1517432077029] ---------------------------- Client requests Menu Items
Jan 31 20:54:37 musikpaj volumio[923]: info: [1517432077039] ------------------------------ 15ms
Jan 31 20:54:37 musikpaj volumio[923]: info: [1517432077070] ------------------------------ 41ms
Jan 31 20:55:03 musikpaj volumio[923]: info: CoreCommandRouter::executeOnPlugin: spop , handleBrowseUri
Jan 31 20:55:08 musikpaj volumio[923]: info: CoreCommandRouter::executeOnPlugin: spop , handleBrowseUri
Jan 31 20:55:08 musikpaj volumio[923]: info: [1517432108992] ControllerSpop::sendSpopCommand
Jan 31 20:55:08 musikpaj volumio[923]: info: ADDING DEFER FOR COMMAND ls
Jan 31 20:55:09 musikpaj volumio[923]: info: SPOP command error:
Jan 31 20:55:09 musikpaj volumio[923]: info:  Error: This socket has been ended by the other party
Jan 31 20:55:09 musikpaj volumio[923]: at Socket.writeAfterFIN [as write] (net.js:290:12)
Jan 31 20:55:09 musikpaj volumio[923]: at applyWithContext (/data/plugins/music_service/spop/node_modules/fast.js/function/applyWithContext.js:15:22)
Jan 31 20:55:09 musikpaj volumio[923]: at /data/plugins/music_service/spop/node_modules/fast.js/function/bind.js:63:14
Jan 31 20:55:09 musikpaj volumio[923]: at onBoundPromise (/data/plugins/music_service/spop/node_modules/kew/kew.js:834:10)
Jan 31 20:55:09 musikpaj volumio[923]: at ncall (/data/plugins/music_service/spop/node_modules/kew/kew.js:816:44)
Jan 31 20:55:09 musikpaj volumio[923]: at Object.nfcall (/data/plugins/music_service/spop/node_modules/kew/kew.js:803:16)
Jan 31 20:55:09 musikpaj volumio[923]: at Promise._successFn (/data/plugins/music_service/spop/index.js:1207:16)
Jan 31 20:55:09 musikpaj volumio[923]: at nextTickCallback (/data/plugins/music_service/spop/node_modules/kew/kew.js:47:28)
Jan 31 20:55:09 musikpaj volumio[923]: at _combinedTickCallback (internal/process/next_tick.js:73:7)
Jan 31 20:55:09 musikpaj volumio[923]: at process._tickCallback (internal/process/next_tick.js:104:9)
Jan 31 20:55:10 musikpaj ntpd_intres[725]: host name not found: 1.debian.pool.ntp.org
Jan 31 20:55:46 musikpaj volumio[923]: info: CoreCommandRouter::executeOnPlugin: spop , handleBrowseUri
Jan 31 20:55:46 musikpaj volumio[923]: info: [1517432146215] ControllerSpop::sendSpopCommand
Jan 31 20:55:46 musikpaj volumio[923]: info: ADDING DEFER FOR COMMAND ls
Jan 31 20:55:46 musikpaj volumio[923]: info: SPOP command error:
Jan 31 20:55:46 musikpaj volumio[923]: info:  Error: This socket has been ended by the other party
Jan 31 20:55:46 musikpaj volumio[923]: at Socket.writeAfterFIN [as write] (net.js:290:12)
Jan 31 20:55:46 musikpaj volumio[923]: at applyWithContext (/data/plugins/music_service/spop/node_modules/fast.js/function/applyWithContext.js:15:22)
Jan 31 20:55:46 musikpaj volumio[923]: at /data/plugins/music_service/spop/node_modules/fast.js/function/bind.js:63:14
Jan 31 20:55:46 musikpaj volumio[923]: at onBoundPromise (/data/plugins/music_service/spop/node_modules/kew/kew.js:834:10)
Jan 31 20:55:46 musikpaj volumio[923]: at ncall (/data/plugins/music_service/spop/node_modules/kew/kew.js:816:44)
Jan 31 20:55:46 musikpaj volumio[923]: at Object.nfcall (/data/plugins/music_service/spop/node_modules/kew/kew.js:803:16)
Jan 31 20:55:46 musikpaj volumio[923]: at Promise._successFn (/data/plugins/music_service/spop/index.js:1207:16)
Jan 31 20:55:46 musikpaj volumio[923]: at nextTickCallback (/data/plugins/music_service/spop/node_modules/kew/kew.js:47:28)
Jan 31 20:55:46 musikpaj volumio[923]: at _combinedTickCallback (internal/process/next_tick.js:73:7)
Jan 31 20:55:46 musikpaj volumio[923]: at process._tickCallback (internal/process/next_tick.js:104:9)
Jan 31 20:56:06 musikpaj volumio[923]: info: CoreCommandRouter::volumioGetState
Jan 31 20:56:06 musikpaj volumio[923]: info: [1517432166066] CoreStateMachine::getState
Jan 31 20:56:06 musikpaj volumio[923]: info: [1517432166067] CorePlayQueue::getTrack 0
Jan 31 20:56:06 musikpaj volumio[923]: [1517432166068] ---------------------------- Client requests Volumio state
Jan 31 20:56:06 musikpaj volumio[923]: info: [1517432166069] InterfaceWebUI::pushState
Jan 31 20:56:06 musikpaj volumio[923]: info: [1517432166087] ------------------------------ 21ms
Jan 31 20:56:06 musikpaj ntpd_intres[725]: host name not found: 2.debian.pool.ntp.org
Jan 31 20:56:06 musikpaj volumio[923]: [1517432166959] ---------------------------- Client requests Menu Items
Jan 31 20:56:06 musikpaj volumio[923]: info: [1517432166976] ------------------------------ 17ms
Jan 31 20:56:07 musikpaj volumio[923]: info: CoreCommandRouter::executeOnPlugin: multiroom , getMultiroom
Jan 31 20:56:07 musikpaj volumio[923]: Plugin multiroom or method getMultiroom not found
Jan 31 20:56:07 musikpaj volumio[923]: info: [1517432167003] Listing playlists
Jan 31 20:56:07 musikpaj volumio[923]: info: CoreCommandRouter::volumioGetBrowseSources
Jan 31 20:56:07 musikpaj volumio[923]: info: CoreCommandRouter::volumioGetQueue
Jan 31 20:56:07 musikpaj volumio[923]: info: [1517432167012] CoreStateMachine::getQueue
Jan 31 20:56:07 musikpaj volumio[923]: info: [1517432167013] CorePlayQueue::getQueue
Jan 31 20:56:07 musikpaj volumio[923]: [1517432167013] ---------------------------- Client requests Volumio queue
Jan 31 20:56:07 musikpaj volumio[923]: info: [1517432167014] InterfaceWebUI::pushQueue
Jan 31 20:56:07 musikpaj volumio[923]: info: [1517432167016] ------------------------------ 5ms
Jan 31 20:56:07 musikpaj volumio[923]: [1517432167018] ---------------------------- Client requests Menu Items
Jan 31 20:56:07 musikpaj volumio[923]: [1517432167024] ---------------------------- Client requests Menu Items
Jan 31 20:56:07 musikpaj volumio[923]: info: [1517432167043] ------------------------------ 26ms
Jan 31 20:56:07 musikpaj volumio[923]: info: [1517432167056] ------------------------------ 32ms
Jan 31 20:56:13 musikpaj volumio[923]: info: CoreCommandRouter::executeOnPlugin: spop , handleBrowseUri
Jan 31 20:56:27 musikpaj volumio[923]: info: CoreCommandRouter::executeOnPlugin: spop , handleBrowseUri
Jan 31 20:56:35 musikpaj volumio[923]: info: CoreCommandRouter::executeOnPlugin: spop , handleBrowseUri
Jan 31 20:56:35 musikpaj volumio[923]: info: [1517432195671] ControllerSpop::sendSpopCommand
Jan 31 20:56:35 musikpaj volumio[923]: info: ADDING DEFER FOR COMMAND ls
Jan 31 20:56:35 musikpaj volumio[923]: info: SPOP command error:
Jan 31 20:56:35 musikpaj volumio[923]: info:  Error: This socket has been ended by the other party
Jan 31 20:56:35 musikpaj volumio[923]: at Socket.writeAfterFIN [as write] (net.js:290:12)
Jan 31 20:56:35 musikpaj volumio[923]: at applyWithContext (/data/plugins/music_service/spop/node_modules/fast.js/function/applyWithContext.js:15:22)
Jan 31 20:56:35 musikpaj volumio[923]: at /data/plugins/music_service/spop/node_modules/fast.js/function/bind.js:63:14
Jan 31 20:56:35 musikpaj volumio[923]: at onBoundPromise (/data/plugins/music_service/spop/node_modules/kew/kew.js:834:10)
Jan 31 20:56:35 musikpaj volumio[923]: at ncall (/data/plugins/music_service/spop/node_modules/kew/kew.js:816:44)
Jan 31 20:56:35 musikpaj volumio[923]: at Object.nfcall (/data/plugins/music_service/spop/node_modules/kew/kew.js:803:16)
Jan 31 20:56:35 musikpaj volumio[923]: at Promise._successFn (/data/plugins/music_service/spop/index.js:1207:16)
Jan 31 20:56:35 musikpaj volumio[923]: at nextTickCallback (/data/plugins/music_service/spop/node_modules/kew/kew.js:47:28)
Jan 31 20:56:35 musikpaj volumio[923]: at _combinedTickCallback (internal/process/next_tick.js:73:7)
Jan 31 20:56:35 musikpaj volumio[923]: at process._tickCallback (internal/process/next_tick.js:104:9)
Jan 31 20:57:00 musikpaj volumio[923]: info: CoreCommandRouter::executeOnPlugin: upnp_browser , handleBrowseUri
Jan 31 20:57:01 musikpaj volumio[923]: info: CoreCommandRouter::executeOnPlugin: upnp_browser , handleBrowseUri
Jan 31 20:57:02 musikpaj volumio[923]: info: No input data
Jan 31 20:57:02 musikpaj ntpd_intres[725]: host name not found: 3.debian.pool.ntp.org
Jan 31 20:57:03 musikpaj volumio[923]: info: CoreCommandRouter::executeOnPlugin: upnp_browser , handleBrowseUri
Jan 31 20:57:03 musikpaj volumio[923]: info: No input data
Jan 31 20:57:05 musikpaj volumio[923]: info: CoreCommandRouter::executeOnPlugin: upnp_browser , handleBrowseUri
Jan 31 20:57:07 musikpaj volumio[923]: info: CoreCommandRouter::executeOnPlugin: upnp_browser , handleBrowseUri
Jan 31 20:57:10 musikpaj volumio[923]: info: CoreCommandRouter::executeOnPlugin: upnp_browser , handleBrowseUri
Jan 31 20:57:10 musikpaj volumio[923]: info: No input data
Jan 31 20:57:12 musikpaj volumio[923]: info: CoreCommandRouter::executeOnPlugin: upnp_browser , handleBrowseUri
Jan 31 20:57:17 musikpaj volumio[923]: info: CoreCommandRouter::volumioAddQueueItems
Jan 31 20:57:17 musikpaj volumio[923]: info: [1517432237898] CoreStateMachine::addQueueItems
Jan 31 20:57:17 musikpaj volumio[923]: info: [1517432237900] CorePlayQueue::addQueueItems
Jan 31 20:57:17 musikpaj volumio[923]: info: Adding Item to queue: upnp/http://192.168.8.105:32469/ContentDirectory/b6d69b83-876f-c05a-7c9b-57b0c7858485/control.xml@a0928d7411a743d7d87f
Jan 31 20:57:17 musikpaj volumio[923]: info: Exploding uri upnp/http://192.168.8.105:32469/ContentDirectory/b6d69b83-876f-c05a-7c9b-57b0c7858485/control.xml@a0928d7411a743d7d87f in service upnp_browser
Jan 31 20:57:17 musikpaj volumio[923]: info: [1517432237974] CorePlayQueue::saveQueue
Jan 31 20:57:17 musikpaj volumio[923]: info: CoreCommandRouter::volumioPushQueue
Jan 31 20:57:17 musikpaj volumio[923]: info: [1517432237978] interfaceApi::pushQueue
Jan 31 20:57:17 musikpaj volumio[923]: info: [1517432237979] InterfaceWebUI::pushQueue
Jan 31 20:57:17 musikpaj volumio[923]: info: [1517432237987] CoreStateMachine::updateTrackBlock
Jan 31 20:57:17 musikpaj volumio[923]: info: [1517432237988] CorePlayQueue::getTrackBlock
Jan 31 20:57:17 musikpaj volumio[923]: info: CoreCommandRouter::volumioPlay
Jan 31 20:57:17 musikpaj volumio[923]: UNSET VOLATILE
Jan 31 20:57:17 musikpaj volumio[923]: info: [1517432237992] CoreStateMachine::play index 0
Jan 31 20:57:17 musikpaj volumio[923]: info: [1517432237993] CoreStateMachine::setConsumeUpdateService undefined
Jan 31 20:57:17 musikpaj volumio[923]: info: [1517432237996] CoreStateMachine::stop
Jan 31 20:57:18 musikpaj volumio[923]: info: [1517432237997] CoreStateMachine::setConsumeUpdateService undefined
Jan 31 20:57:18 musikpaj volumio[923]: UNSET VOLATILE
Jan 31 20:57:18 musikpaj volumio[923]: info: [1517432237998] CoreStateMachine::play index undefined
Jan 31 20:57:18 musikpaj volumio[923]: info: [1517432237999] CoreStateMachine::setConsumeUpdateService undefined
Jan 31 20:57:18 musikpaj volumio[923]: info: [1517432238000] CorePlayQueue::getTrack 0
Jan 31 20:57:18 musikpaj volumio[923]: info: [1517432238002] CoreStateMachine::startPlaybackTimer
Jan 31 20:57:18 musikpaj volumio[923]: info: [1517432238003] CorePlayQueue::getTrack 0
Jan 31 20:57:18 musikpaj volumio[923]: info: [1517432238006] ControllerUPNPBrowser::clearAddPlayTrack
Jan 31 20:57:18 musikpaj volumio[923]: info: [1517432238007] ControllerMpd::sendMpdCommand stop
Jan 31 20:57:18 musikpaj volumio[923]: info: [1517432238015] sending command...
Jan 31 20:57:18 musikpaj volumio[923]: info: [1517432238026] parsing response...
Jan 31 20:57:18 musikpaj volumio[923]: info: [1517432238028] ControllerMpd::sendMpdCommand clear
Jan 31 20:57:18 musikpaj volumio[923]: info: [1517432238029] sending command...
Jan 31 20:57:18 musikpaj volumio[923]: [1517432238032] ---------------------------- MPD announces system playlist update
Jan 31 20:57:18 musikpaj volumio[923]: info: Ignoring MPD Status Update
Jan 31 20:57:18 musikpaj volumio[923]: info: [1517432238035] parsing response...
Jan 31 20:57:18 musikpaj volumio[923]: info: [1517432238037] ControllerMpd::sendMpdCommand load "http://192.168.8.105:32469/object/a0928d7411a743d7d87f/file.mp3"
Jan 31 20:57:18 musikpaj volumio[923]: info: [1517432238038] sending command...
Jan 31 20:57:18 musikpaj volumio[923]: info: [1517432238042] ------------------------------ 10ms
Jan 31 20:57:18 musikpaj volumio[923]: info: [1517432238103] ControllerMpd::sendMpdCommand add "http://192.168.8.105:32469/object/a0928d7411a743d7d87f/file.mp3"
Jan 31 20:57:18 musikpaj volumio[923]: info: [1517432238103] sending command...
Jan 31 20:57:18 musikpaj volumio[923]: [1517432238105] ---------------------------- MPD announces system playlist update
Jan 31 20:57:18 musikpaj volumio[923]: info: [1517432238107] parsing response...
Jan 31 20:57:18 musikpaj volumio[923]: info: [1517432238108] CoreStateMachine::setConsumeUpdateService mpd
Jan 31 20:57:18 musikpaj volumio[923]: info: [1517432238109] ControllerMpd::sendMpdCommand play
Jan 31 20:57:18 musikpaj volumio[923]: info: [1517432238110] sending command...
Jan 31 20:57:18 musikpaj volumio[923]: info: [1517432238117] ------------------------------ 12ms
Jan 31 20:57:18 musikpaj volumio[923]: info: [1517432238118] parsing response...
Jan 31 20:57:18 musikpaj volumio[923]: [1517432238209] ---------------------------- MPD announces state update: player
Jan 31 20:57:18 musikpaj kernel: pcm512x 1-004c: No SCLK, using BCLK: -2
Jan 31 20:57:18 musikpaj volumio[923]: info: [1517432238212] ControllerMpd::getState
Jan 31 20:57:18 musikpaj volumio[923]: info: [1517432238213] ControllerMpd::sendMpdCommand status
Jan 31 20:57:18 musikpaj volumio[923]: info: [1517432238214] sending command...
Jan 31 20:57:18 musikpaj volumio[923]: [1517432238217] ---------------------------- MPD announces state update: player
Jan 31 20:57:18 musikpaj volumio[923]: info: [1517432238222] parsing response...
Jan 31 20:57:18 musikpaj volumio[923]: info: [1517432238225] ControllerMpd::getState
Jan 31 20:57:18 musikpaj volumio[923]: info: [1517432238228] ControllerMpd::sendMpdCommand status
Jan 31 20:57:18 musikpaj volumio[923]: info: [1517432238232] ControllerMpd::parseState
Jan 31 20:57:18 musikpaj volumio[923]: info: [1517432238236] ControllerMpd::sendMpdCommand playlistinfo
Jan 31 20:57:18 musikpaj volumio[923]: info: [1517432238238] sending command...
Jan 31 20:57:18 musikpaj volumio[923]: info: [1517432238242] sending command...
Jan 31 20:57:18 musikpaj volumio[923]: info: [1517432238247] parsing response...
Jan 31 20:57:18 musikpaj volumio[923]: info: [1517432238250] parsing response...
Jan 31 20:57:18 musikpaj volumio[923]: info: [1517432238264] ControllerMpd::parseState
Jan 31 20:57:18 musikpaj volumio[923]: info: [1517432238267] ControllerMpd::sendMpdCommand playlistinfo
Jan 31 20:57:18 musikpaj volumio[923]: info: [1517432238276] ControllerMpd::parseTrackInfo
Jan 31 20:57:18 musikpaj volumio[923]: info: [1517432238280] sending command...
Jan 31 20:57:18 musikpaj volumio[923]: info: [1517432238282] ControllerMpd::pushState
Jan 31 20:57:18 musikpaj volumio[923]: info: CoreCommandRouter::servicePushState
Jan 31 20:57:18 musikpaj volumio[923]: info: [1517432238291] CoreStateMachine::syncState
Jan 31 20:57:18 musikpaj volumio[923]: info: [1517432238293] CorePlayQueue::getTrack 0
Jan 31 20:57:18 musikpaj volumio[923]: info: STATE SERVICE {"status":"play","position":0,"seek":487,"duration":172,"samplerate":"44.1 KHz","bitdepth":"24 bit","channels":2,"random":false,"updatedb":false,"repeat":false,"isStreaming":false,"title":"file.mp3","artist":null,"album":null,"uri":"http://192.168.8.105:32469/object/a0928d7411a743d7d87f/file.mp3","trackType":"mp3"}
Jan 31 20:57:18 musikpaj volumio[923]: info: CURRENT POSITION 0
Jan 31 20:57:18 musikpaj volumio[923]: info: [1517432238300] CoreStateMachine::syncState   stateService play
Jan 31 20:57:18 musikpaj volumio[923]: info: [1517432238302] CoreStateMachine::syncState   currentStatus stop
Jan 31 20:57:18 musikpaj volumio[923]: info: [1517432238304] CoreStateMachine::pushState
Jan 31 20:57:18 musikpaj volumio[923]: info: [1517432238306] CoreStateMachine::getState
Jan 31 20:57:18 musikpaj volumio[923]: info: CoreCommandRouter::volumioPushState
Jan 31 20:57:18 musikpaj volumio[923]: info: CoreCommandRouter::executeOnPlugin: volumiodiscovery , saveDeviceInfo
Jan 31 20:57:18 musikpaj volumio[923]: info: [1517432238313] interfaceApi::pushState
Jan 31 20:57:18 musikpaj volumio[923]: info: [1517432238315] InterfaceWebUI::pushState
Jan 31 20:57:18 musikpaj volumio[923]: info: [1517432238340] ------------------------------ 131ms
Jan 31 20:57:18 musikpaj volumio[923]: info: Pushing Favourites {"service":"mpd","favourite":false}
Jan 31 20:57:18 musikpaj volumio[923]: info: [1517432238352] parsing response...
Jan 31 20:57:18 musikpaj volumio[923]: info: [1517432238353] ControllerMpd::parseTrackInfo
Jan 31 20:57:18 musikpaj volumio[923]: info: [1517432238355] ControllerMpd::pushState
Jan 31 20:57:18 musikpaj volumio[923]: info: [1517432238357] CoreStateMachine::syncState
Jan 31 20:57:18 musikpaj volumio[923]: info: [1517432238359] CorePlayQueue::getTrack 0
Jan 31 20:57:18 musikpaj volumio[923]: info: [1517432238363] CoreStateMachine::syncState   stateService play
Jan 31 20:57:18 musikpaj volumio[923]: info: [1517432238366] CoreStateMachine::syncState   currentStatus play
Jan 31 20:57:18 musikpaj volumio[923]: info: [1517432238367] Received an update from plaugin. extracting info from payload
Jan 31 20:57:18 musikpaj volumio[923]: info: [1517432238369] CoreStateMachine::pushState
Jan 31 20:57:18 musikpaj volumio[923]: info: [1517432238370] CoreStateMachine::getState
Jan 31 20:57:18 musikpaj volumio[923]: info: [1517432238378] interfaceApi::pushState
Jan 31 20:57:18 musikpaj volumio[923]: info: [1517432238379] InterfaceWebUI::pushState
Jan 31 20:57:18 musikpaj volumio[923]: info: [1517432238419] CoreStateMachine::pushState
Jan 31 20:57:18 musikpaj volumio[923]: info: [1517432238421] CoreStateMachine::getState
Jan 31 20:57:18 musikpaj volumio[923]: info: [1517432238427] interfaceApi::pushState
Jan 31 20:57:18 musikpaj volumio[923]: info: [1517432238428] InterfaceWebUI::pushState
Jan 31 20:57:18 musikpaj volumio[923]: info: [1517432238455] ------------------------------ 238ms
Jan 31 20:57:18 musikpaj volumio[923]: info: Pushing Favourites {"service":"mpd","uri":"http://192.168.8.105:32469/object/a0928d7411a743d7d87f/file.mp3","favourite":false}
Jan 31 20:57:29 musikpaj volumio[923]: info:
Jan 31 20:57:29 musikpaj volumio[923]: [1517432249282] ---------------------------- Client requests Volume 49
Jan 31 20:57:29 musikpaj volumio[923]: info: [1517432249285] VolumeController::SetAlsaVolume49
Jan 31 20:57:29 musikpaj volumio[923]: info: [1517432249303] ------------------------------ 21ms
Jan 31 20:57:29 musikpaj volumio[923]: null
Jan 31 20:57:29 musikpaj volumio[923]: info: [1517432249318] VolumeController::Volume 49
Jan 31 20:57:29 musikpaj volumio[923]: info: [1517432249319] CoreStateMachine::pushState
Jan 31 20:57:29 musikpaj volumio[923]: info: [1517432249320] CoreStateMachine::getState
Jan 31 20:57:29 musikpaj volumio[923]: info: CoreCommandRouter::volumioPushState
Jan 31 20:57:29 musikpaj volumio[923]: info: CoreCommandRouter::executeOnPlugin: volumiodiscovery , saveDeviceInfo
Jan 31 20:57:29 musikpaj volumio[923]: info: [1517432249323] interfaceApi::pushState
Jan 31 20:57:29 musikpaj volumio[923]: info: [1517432249324] InterfaceWebUI::pushState
Jan 31 20:57:29 musikpaj volumio[923]: info: Pushing Favourites {"service":"mpd","uri":"http://192.168.8.105:32469/object/a0928d7411a743d7d87f/file.mp3","favourite":false}
Jan 31 20:57:38 musikpaj wpa_supplicant[858]: wlan0: BSS: Remove id 8 BSSID b0:e1:7e:f3:46:ce SSID '3Bredband-2.4G-46CE' due to wpa_bss_flush_by_age
Jan 31 20:57:38 musikpaj wpa_supplicant[858]: wlan0: BSS: Remove id 9 BSSID 64:a5:c3:68:fb:68 SSID 'Urbans Wi-Fi' due to wpa_bss_flush_by_age
Jan 31 20:57:38 musikpaj wpa_supplicant[858]: wlan0: BSS: Remove id 10 BSSID 0c:51:01:e4:79:d0 SSID 'Urbans Wi-Fi' due to wpa_bss_flush_by_age
Jan 31 20:57:38 musikpaj wpa_supplicant[858]: wlan0: BSS: Remove id 11 BSSID 0c:96:bf:4d:1c:b1 SSID 'Not' due to wpa_bss_flush_by_age
Jan 31 20:57:38 musikpaj wpa_supplicant[858]: wlan0: BSS: Remove id 12 BSSID f2:9f:c2:3d:04:e5 SSID 'Xercise_gast' due to wpa_bss_flush_by_age
Jan 31 20:57:41 musikpaj volumio[923]: info:
Jan 31 20:57:41 musikpaj volumio[923]: [1517432261425] ---------------------------- Client requests Volumio pause
Jan 31 20:57:41 musikpaj volumio[923]: info: CoreCommandRouter::volumioPause
Jan 31 20:57:41 musikpaj volumio[923]: info: [1517432261428] CoreStateMachine::pause
Jan 31 20:57:41 musikpaj volumio[923]: info: [1517432261429] CoreStateMachine::stPlaybackTimer
Jan 31 20:57:41 musikpaj volumio[923]: info: [1517432261431] CoreStateMachine::servicePause
Jan 31 20:57:41 musikpaj volumio[923]: info: [1517432261432] CorePlayQueue::getTrack 0
Jan 31 20:57:41 musikpaj volumio[923]: info: CoreCommandRouter::servicePause
Jan 31 20:57:41 musikpaj volumio[923]: info: [1517432261435] ControllerUPNPBrowser::pause
Jan 31 20:57:41 musikpaj volumio[923]: info: [1517432261437] ControllerMpd::sendMpdCommand pause
Jan 31 20:57:41 musikpaj volumio[923]: info: [1517432261439] sending command...
Jan 31 20:57:41 musikpaj volumio[923]: [1517432261516] ---------------------------- MPD announces state update: player
Jan 31 20:57:41 musikpaj volumio[923]: info: [1517432261517] parsing response...
Jan 31 20:57:41 musikpaj volumio[923]: info: [1517432261518] ControllerMpd::getState
Jan 31 20:57:41 musikpaj volumio[923]: info: [1517432261519] ControllerMpd::sendMpdCommand status
Jan 31 20:57:41 musikpaj volumio[923]: info: [1517432261521] ------------------------------ 96ms
Jan 31 20:57:41 musikpaj volumio[923]: info: [1517432261522] sending command...
Jan 31 20:57:41 musikpaj volumio[923]: info: [1517432261526] parsing response...
Jan 31 20:57:41 musikpaj volumio[923]: info: [1517432261527] ControllerMpd::parseState
Jan 31 20:57:41 musikpaj volumio[923]: info: [1517432261528] ControllerMpd::sendMpdCommand playlistinfo
Jan 31 20:57:41 musikpaj volumio[923]: info: [1517432261529] sending command...
Jan 31 20:57:41 musikpaj volumio[923]: info: [1517432261531] parsing response...
Jan 31 20:57:41 musikpaj volumio[923]: info: [1517432261532] ControllerMpd::parseTrackInfo
Jan 31 20:57:41 musikpaj volumio[923]: info: [1517432261533] ControllerMpd::pushState
Jan 31 20:57:41 musikpaj volumio[923]: info: CoreCommandRouter::servicePushState
Jan 31 20:57:41 musikpaj volumio[923]: info: [1517432261535] CoreStateMachine::syncState
Jan 31 20:57:41 musikpaj volumio[923]: info: [1517432261536] CorePlayQueue::getTrack 0
Jan 31 20:57:41 musikpaj volumio[923]: info: STATE SERVICE {"status":"pause","position":0,"seek":23684,"duration":172,"samplerate":"44.1 KHz","bitdepth":"24 bit","channels":2,"random":false,"updatedb":false,"repeat":false,"isStreaming":false,"title":"file.mp3","artist":null,"album":null,"uri":"http://192.168.8.105:32469/object/a0928d7411a743d7d87f/file.mp3","trackType":"mp3"}
Jan 31 20:57:41 musikpaj volumio[923]: info: CURRENT POSITION 0
Jan 31 20:57:41 musikpaj volumio[923]: info: [1517432261538] CoreStateMachine::syncState   stateService pause
Jan 31 20:57:41 musikpaj volumio[923]: info: [1517432261539] CoreStateMachine::syncState   currentStatus pause
Jan 31 20:57:41 musikpaj volumio[923]: info: [1517432261540] CoreStateMachine::pushState
Jan 31 20:57:41 musikpaj volumio[923]: info: [1517432261541] CoreStateMachine::getState
Jan 31 20:57:41 musikpaj volumio[923]: info: CoreCommandRouter::volumioPushState
Jan 31 20:57:41 musikpaj volumio[923]: info: CoreCommandRouter::executeOnPlugin: volumiodiscovery , saveDeviceInfo
Jan 31 20:57:41 musikpaj volumio[923]: info: [1517432261545] interfaceApi::pushState
Jan 31 20:57:41 musikpaj volumio[923]: info: [1517432261546] InterfaceWebUI::pushState
Jan 31 20:57:41 musikpaj volumio[923]: info: [1517432261566] CoreStateMachine::stPlaybackTimer
Jan 31 20:57:41 musikpaj volumio[923]: info: [1517432261569] ------------------------------ 53ms
Jan 31 20:57:41 musikpaj volumio[923]: info: Pushing Favourites {"service":"mpd","uri":"http://192.168.8.105:32469/object/a0928d7411a743d7d87f/file.mp3","favourite":false}
