Sometimes Volumio 3.378 crashes with no error. I am running on rpi3B. I am going to log.
The system does not log this problem. It is really not nice that system crashes every day.
did you enable logging?
https://volumio.github.io/docs/User_Manual/Sending_logs_for_troubleshooting.html
I enabled live logging and that does not work with this issue.
Here is the log link: http://logs.volumio.org/volumio/TJwkNsi.html
When the system crashes with no reason I have to turn of device and restart, rebooting does not help
is this a log of a crashed system? as indeed nothing much to worry about.
Maybe crash is wrong explaining. The system stops responding now and then, than I have to turn off the rpi.
Which plugin are you using when the issue occurs?
I think most of the time it happens when using webradio. I am not sure it happens on other plugins, situations.
This seems to happen for the track: https://n01a.on.revma.com/6wa52xb1pg0uv?firstname=Reinier
Which is a Peter Gabriel song. This seems to be giving MPD some headaches reading.
Do you recall which plugin is it? This plugin seems not to be well written, it does not advertise its service.
the track is Planet Rock link maybe only with that channel there problem. It is the webradiostation section(plugin?) in Volumio
